Add support for loading u-boot FIT images over the USB SDP protocol in
the SPL
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
[Various build fixes]
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tested-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Lukasz Majewski <lukma@denx.de>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Add SDP (Serial Downloader Protocol) implementation for U-Boot. The
protocol is used in NXP SoC's boot ROM and allows to download program
images. Beside that, it can also be used to read/write registers and
download complete Device Configuration Data (DCD) sets. This basic
implementation supports downloading images with the imx header format
reading and writing registers.
Reviewed-by: Ćukasz Majewski <lukma@denx.de>
