path: root/include/sdhci.h
2017-01-25mmc: sdhci: Add support for optional controller specific set_ios_post()Stefan Roese
Some SDHCI drivers might need to do some special controller configuration after the common clock set_ios() function has been called (speed / width configuration). This patch adds a call to the newly created function set_ios_port() when its configured in the host driver. This will be used by the Xenon SDHCI controller driver used on the Marvell Armada 3700 and 7k/8k ARM64 SoCs. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-23mmc: sdhci: Distinguish between base clock and maximum peripheral frequencyStefan Herbrechtsmeier
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. The Linux kernel distinguishes between base clock (max_clk) of the host controller and maximum frequency (f_max) of the card interface. Use the same differentiation and allow the platform to constrain the peripheral interface. Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
2017-01-11mmc: sdhci: remove the SDHCI_QUIRK_NO_SIMULT_VDD_AND_POWERJaehoon Chung
Ther is no usage anywhere. It doesn't need to maintain this bit. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-11mmc: sdhci: use the bitops APIs in sdhci.hJaehoon Chung
The using the bitops is too easy controlling than now. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-11mmc: sdhci: move the callback function into sdhci_opsJaehoon Chung
callback function should be moved into sdhci_ops struct. Other controller can use these ops for controlling clock or their own specific register. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-11mmc: sdhci: remove the SDHCI_QUIRK_NO_CDJaehoon Chung
This quirk doesn't need anymore. It's replaced to get_cd callback function. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-11mmc: sdhci: add the get_cd callback function in sdhci_opsJaehoon Chung
Some SoCs can have their own card dect scheme. Then they may use this get_cd callback function after implementing init in their drivers. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-09-20mmc: sdhci: Add the programmable clock mode supportWenyou Yang
Add the programmable clock mode for the clock generator. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2016-08-15mmc: atmel_sdhci: Convert to the driver model supportWenyou Yang
Convert the driver to the driver model while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-08-05mmc: sdhci: remove the unnecessary arguments for sdhci_setup_cfgJaehoon Chung
Some arguments don't need to pass to sdhci_setup_cfg. Generic variable can be used in sdhci_setup_cfg, and some arguments are already included in sdhci_host struct. It's enough that just pass the board specific things to sdhci_setup_cfg(). After removing the unnecessary arguments, it's more simpler than before. It doesn't consider "Version" and "Capabilities" anymore in each SoC driver. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05mmc: sdhci: remove the unused argument for sdhci_setup_cfgJaehoon Chung
buswidth isn't used anywhere in sdhci_setup_cfg. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-11dm: mmc: sdhci: Support CONFIG_BLK and CONFIG_DM_MMC_OPSSimon Glass
Add support for using driver model for block devices and MMC operations in this driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-25mmc: sdhci: add const qualifier to the name of struct sdhci_hostMasahiro Yamada
This allows to drop annoying (char *) casts when setting the host name of struct sdhci_host. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-01-29dm: mmc: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-03-24mmc: Split mmc struct, rework mmc initialization (v2)Pantelis Antoniou
The way that struct mmc was implemented was a bit of a mess; configuration and internal state all jumbled up in a single structure. On top of that the way initialization is done with mmc_register leads to a lot of duplicated code in drivers. Typically the initialization got something like this in every driver. struct mmc *mmc = malloc(sizeof(struct mmc)); memset(mmc, 0, sizeof(struct mmc); /* fill in fields of mmc struct */ /* store private data pointer */ mmc_register(mmc); By using the new mmc_create call one just passes an mmc config struct and an optional private data pointer like this: struct mmc = mmc_create(&cfg, priv); All in tree drivers have been updated to the new form, and expect mmc_register to go away before long. Changes since v1: * Use calloc instead of manually calling memset. * Mark mmc_register as deprecated. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-12drivers:mmc:sdhci: enable support for DTPiotr Wilczek
This patch enables support for device tree for sdhci driver. Non DT case is still supported. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-17mmc: sdhci: use the SDHCI_QUIRK_USE_WIDE8 for samsung SoCJaehoon Chung
Samsung SoC is supported the WIDE8, even if Controller version is v2.0. So add the SDHCI_QUIRK_USE_WIDE8 for Samsung-SoC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2012-11-27mmc: add no simultaenous power and vddMela Custodio
Bring in the code from Linux kernel. Added to Linux kernel by: commit e08c1694d9e2138204f2b79b73f0f159074ce2f5 Author: Andres Salomon <dilinger@queued.net> Date: Fri Jul 4 10:00:03 2008 -0700 Some HW balks when writing both voltage setting and power up at the same time to SDHCI_POWER_CONTROL register. Signed-off-by: Rommel G Custodio <sessyargc@gmail.com> CC: Andy Fleming <afleming@freescale.com> v2: fix attribution and SOB Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22mmc: sdhci: Add a quirk to add delay during completion of sdhci_send_cmdTushar Behera
MMC host controller requires a delay between every sdhci_send_cmd() execution. In s5p_mmc driver (s5p_sdhci replaces this driver), a delay of 1000us was provided after every mmc_send_cmd() call. Adding a quirk in current sdhci driver to replicate the behaviour. Without this delay, MMC initialization on Origen board fails with following error messages. Timeout for status update! mmc fail to send stop cmd Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-05mmc: s5p_sdhci: add the set_mmc_clk for cmu controlJaehoon Chung
Samsung SoC use the cmu control to set clock. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-05mmc: Add a SDHCI quirk for boards that have no CDJoe Hershberger
Some boards have no Card Detect wired. In that case, set the CD test bits in the standard interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-05-08mmc: add the quirk to use the sdhci for samsung-socJaehoon Chung
To support the Samsung-SoC, added the basically functions. Samsung-SoC didn't used the SDHCI_CTRL_HISPD. And added set_control_reg callback for s3c64xx. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com>
2012-05-08mmc: sdhci: add the quirk for broken r1b responseJaehoon Chung
When response type is R1b, mask value is added the SDHCI_INT_DAT_END. but in while(), didn't check that flag. So sdhci controller didn't work fine. CMD6 didn't always complete. So add the quirks for broken r1b response and add the timeout value to prevent the infinite loop. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com>
2011-11-25mmc: mv_sdhci: Fix host version read for Armada100Ajay Bhargav
sdhci_readw does not work for host version read in Armada100 series SoCs. This patch fix this issue by making a sdhci_readl call to get host version. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-11-03mmc: sdhci: add mmc structure for hostLei Wen
So that sdhci host would tell in the driver that the mmc current attributes. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-11-03mmc: sdhci: fix build warningLei Wen
If CONFIG_MMC_SDHCI_IO_ACCESSORS is defined, the following warning would shows up: include/sdhci.h:224: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:224: warning: its scope is only this definition or declaration, which is probably not what you want include/sdhci.h:225: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:226: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:227: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:228: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:229: warning: 'struct sdhci_host' declared inside parameter list Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-07-15MMC: add sdhci generic frameworkLei Wen
Nowdays, there are plenty of mmc driver in uboot adopt the sd standard host design, aka as sdhci. It is better to centralize the common logic together to better maintenance. Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
