path: root/include/samsung
2014-02-07board:samsung:common: set envs with board unified informationPiotr Wilczek
This patch sets envs that describe board information. The following envs are set: soc_id, soc_rev, board_rev. Based on this information, if CONFIG_OF_LIBFDT is enabled, the 'fdtfile' env is set as: fdtfile=${soc_family}${soc_id}-${board}.dtb The generated envs are intenionally not saved to persistent storage. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03samsung: misc: Add LCD download menu.Przemyslaw Marczak
This simple LCD menu allows run one of download mode on device without writing on console or for fast and easy upgrade. This feature check user keys combination at boot: - power key + volume up - download menu - power key + volume down - thor mode (without menu) New configs: - CONFIG_LCD_MENU - CONFIG_LCD_MENU_BOARD For proper effect this feature needs following definitions: Power key: - KEY_PWR_PMIC_NAME - (string) pmic which supports power key check Register address: - KEY_PWR_STATUS_REG - KEY_PWR_INTERRUPT_REG Register power key mask: - KEY_PWR_STATUS_MASK - KEY_PWR_INTERRUPT_MASK Gpio numbers: - KEY_PWR_INTERRUPT_MASK - KEY_VOL_DOWN_GPIO Functions needs to be called: - keys_init() - for set proper gpio direction - check_boot_mode() - menu - main function Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03samsung: common: Add file for common functions, draw_logo() cleanup.Przemyslaw Marczak
Changes: new file: - board/samsung/common/misc.c depends on: CONFIG_MISC_COMMON - move draw_logo() to misc.c configs: trats, trats2, universal: - enable CONFIG_MISC_COMMON, - enable CONFIG_MISC_INIT_R, - add misc_init_r() and call draw_logo() in it. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
