path: root/include/samsung-usb-phy-uboot.h
2015-06-08samsung: usb: phy: Support for DWC3 PHYLukasz Majewski
New files, namely samsung_usb_phy.c and samsung-usb-phy-uboot.h have been added to u-boot to provide proper PHY handling at Exynos5 SoCs. This code is used thereafter in the board_usb_init() call. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de>
