path: root/include/rtc.h
2019-12-06rtc.h: add struct udevice declarationAKASHI Takahiro
Without this change, including rtc.h solely will cause a build error. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-08-22rtc: ds3232/ds3231: Add support to generate 32KHz output for driver moduleChuanhua Han
Add an implementation of the rtc_enable_32khz_output() that uses the driver model i2c APIs. Also put code related to rtc_enable_32khz_output under CONFIG_RTC_ENABLE_32KHZ_OUTPUT. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-31rtc: export rtc_month_days()Heinrich Schuchardt
Export function rtc_month_days() for reuse in the UEFI subsystem. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-12-05dm: rtc: Fix function name in commentPhilipp Tomsich
The documentation comment for dm_rtc_set was referring to dm_rtc_put instead. Fix it. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-07-19drivers: rtc: resolve year 2038 problem in rtc_to_tmHeinrich Schuchardt
Our implementation of rtc_to_tm() cannot handle dates of more than 0x7fffffff seconds after 1970-01-01. Adopt the Linux kernel implementation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-04-10dm: rtc: Add 16-bit read/write supportBin Meng
At present there are only 8-bit and 32-bit read/write routines in the rtc uclass driver. This adds the 16-bit support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-09-01rtc:ds3232/ds3231: Add support to generate 32KHz outputPriyanka Jain
RTC devices can generate 32KHz output if for -DS3232 device, EN32KHz bit and BB32KHz bit are set -DS3231 device, EN32KHz bit is set, BB32KHz bit is don't care Patch adds rtc_enable_32khz_output() which when called will enable 32KHz output on 32KHz pin Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-05dm: rtc: Add a uclass for real-time clocksSimon Glass
Add a uclass for real-time clocks which support getting the current time, setting it and resetting the chip to a known-working state. Some RTCs have additional registers which can be used to store settings, so also provide an interface to these. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: Split structure definition into its own fileSimon Glass
Move the definition of struct rtc_time into a separate file so that sandbox can include it without requiring common.h and the like. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: Rename mktime() and reduce the number of parametersSimon Glass
Most callers unpack the structure and pass each member. It seems better to pass the whole structure instead, as with the C library. Also add an rtc_ prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05dm: rtc: Rename to_tm() to rtc_to_tm() and add error codeSimon Glass
Rename this function so that it is clear that it is provided by the RTC. Also return an error when it cannot function as expected. This is unlikely to occur since it works for dates since 1752 and many RTCs do not support such old dates. Still it is better to be accurate. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05dm: rtc: Rename gregorian day functionSimon Glass
Change this function name to something more descriptive. Also return a failure code if it cannot calculate a correct value. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-24x86: rtc: mc146818: Add helpers to read/write CMOS RAMSimon Glass
On x86 we use CMOS RAM to read and write some settings. Add basic support for this, including access to registers 128-255. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-25rtc: mc146818: Set up RTC at start of daySimon Glass
Provide a function to set up the RTC ready for use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2009-08-25Switch from per-driver to common definition of bin2bcd and bcd2binAlbin Tonnerre
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de>
2009-04-01rtc: remove broken rtc_read and rtc_write declarationsKim Phillips
commit 04e11cf3 "rtc: add support for 4543 RTC (manufactured by e.g. EPSON)" introduces the following build error on boards configuring e.g, the ds1374 rtc: Configuring for MPC837XEMDS board... ds1374.c:103: error: static declaration of 'rtc_read' follows non-static declaration /home/r1aaha/git/u-boot/include/rtc.h:64: error: previous declaration of 'rtc_read' was here ds1374.c:104: error: conflicting types for 'rtc_write' /home/r1aaha/git/u-boot/include/rtc.h:65: error: previous declaration of 'rtc_write' was here this reverts the erroneous chunk. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de> CC: Detlev Zundel <dzu@denx.de> CC: Andreas Pfefferle <ap@denx.de>
2009-03-30rtc: add support for 4543 RTC (manufactured by e.g. EPSON)Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2008-09-07rtc: allow rtc_set to return an error and use it in cmd_dateJean-Christophe PLAGNIOL-VILLARD
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2001-04-09Initial revisionwdenk
