path: root/include/remoteproc.h
2020-01-07remoteproc: elf_loader: Add elf resource table load supportFabien Dessenne
Add rproc_elf_load_rsc_table(), which searches for a resource table in an elf64/elf32 image, and if found, copies it to device memory. Add also the elf32 and elf64 variants of this API. Add a test for this. Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11remoteproc: elf_loader: Introduce rproc_elf_get_boot_addr() apiLokesh Vutla
Introduce rproc_elf_get_boot_addr() that returns the entry point of the elf file. This api auto detects the 64/32 bit elf file and returns the boot addr accordingly. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11remoteproc: elf_loader: Introduce a common elf loader and checker functionsLokesh Vutla
Introduce a common remoteproc elf loader and checker functions that automatically detects the 64 bit elf file or 32 bit elf file and loads/checks the sections accordingly. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-10-11remoteproc: elf-loader: Add 64 bit elf loading supportLokesh Vutla
The current rproc-elf-loader supports loading of only 32 bit elf files. Introduce support for loading of 64 bit elf files in rproc-elf-loader. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-10-11remoteproc: elf_loader: Always check the validity of the image before loadingLokesh Vutla
rproc_elf32_load_image() rely on user to send a valid address for elf loading. Instead do a sanity check on the address passed by user. This will help all rproc elf users to not call sanity_check explicitly before calling elf_loading. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-10-11remoteproc: ops: Add elf section size as input parameter to device_to_virt apiLokesh Vutla
Introduce a new parameter "size" that accepts size of the region to remoteproc ops callback device_to_virt(). This can enforce more checks on the region that device_to_virt() is dealing with. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Fabien Dessenne <fabien.dessenne@st.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-07-24remoteproc: Fix potential build issues with SPL remoteprocSuman Anna
The rproc uclass driver can either be built with SPL_REMOTEPROC or REMOTEPROC, but the function prototypes in remoteproc.h are defined only when CONFIG_REMOTEPROC is defined. This can cause build issues in SPL if CONFIG_REMOTEPROC is not selected. Fix this by replacing the existing precompiler macro usage with CONFIG_IS_ENABLED. Fixes: ddf56bc7e3ef ("drivers: Introduce a simplified remoteproc framework") Signed-off-by: Suman Anna <s-anna@ti.com> Reviewed-by: Nishanth Menon <nm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-22remoteproc: add elf file load supportFabien Dessenne
The current implementation supports only binary file load. Add helpers to support ELF32 format (sanity check, and load). Note that since an ELF32 image is built for the remote processor, the load function uses the device_to_virt ops to translate the addresses. Implement a basic translation for sandbox_testproc. Add related tests. Test result: => ut dm remoteproc_elf Test: dm_test_remoteproc_elf: remoteproc.c Test: dm_test_remoteproc_elf: remoteproc.c (flat tree) Failures: 0 Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-22remoteproc: add device_to_virt opsFabien Dessenne
Introduce the device_to_virt function to allow translation between device address (remote processor view) and virtual address (main processor view). Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-22remoteproc: fix function headersFabien Dessenne
Add full function comment headers. Fix rproc_is_initialized() return value description. Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11remoteproc: Allow for individual remoteproc initializationLokesh Vutla
Existing rproc_init() api tries to initialize all available remoteproc devices. This will fail when there is dependency among available remoteprocs. So introduce a separate api that allows to initialize remoteprocs individually based on id. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
