path: root/include/ram.h
2015-07-21dm: Add support for RAM driversSimon Glass
Add support for a driver which sets up DRAM and can return information about the amount of RAM available. This is a first step towards moving RAM init to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
