path: root/include/pwm.h
2017-05-10power: regulator: pwm: support pwm polarity settingKever Yang
The latest kernel PWM drivers enable the polarity settings. When system run from U-Boot to kerenl, if there are differences in polarity set or duty cycle, the PMW will re-init: close -> set polarity and duty cycle -> enable the PWM. The power supply controled by pwm regulator may have voltage shaking, which lead to the system not stable. Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pwm: Add a PWM uclassSimon Glass
Add a uclass that supports Pulse Width Modulation (PWM) devices. It provides methods to enable/disable and configure the device. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-03-27ARM: S5P: pwm driver supportDonghwa Lee
This is common pwm driver of S5P. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
