path: root/include/ppc_asm.tmpl
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2010-06-29powerpc: fix wrong comment at GOT definitionsHeiko Schocher
r12 is used for accessing the GOT not r14. Fix this in the comment. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-01-26ppc: Use r12 instead of r14 as GOT pointer.Joakim Tjernlund
r14 is not supposed to be clobbered by functions. Switch to r12 and call GET_GOT when needed. This will allow u-boot to loose the -ffixed-r14 gcc option. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2010-01-26ppc: Loose GOT access in IRQJoakim Tjernlund
Using the GOT in IRQ handlers requires r14 to be -ffixed-r14. Avoid this by relocatate transfer_to_handler too. This will allow to free up r14 later on. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2007-08-14e500 needs ppc_asm.tmp MCK_EXCEPTIONEd Swarthout
Always define MCK_EXCEPTION macro - so e500 can use it too. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-07-19Fix breakage of 8xx boards from recent commit.Rafal Jaworowski
This patch fixes the negative consequences for 8xx of the recent "ppc4xx: Clean up 440 exceptions handling" commit. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2007-06-20Coding style cleanup. Refresh CHANGELOG.Wolfgang Denk
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2002-08-20Initial revisionwdenk
