path: root/include/ppc4xx.h
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-23ppc4xx: Add function to check and dynamically change PCI sync clockStefan Roese
PPC440EP(x)/PPC440GR(x): In asynchronous PCI mode, the synchronous PCI clock must meet certain requirements. The following equation describes the relationship that must be maintained between the asynchronous PCI clock and synchronous PCI clock. Select an appropriate PCI:PLB ratio to maintain the relationship: AsyncPCIClk - 1MHz <= SyncPCIclock <= (2 * AsyncPCIClk) - 1MHz This patch now adds a function to check and reconfigure the sync PCI clock to meet this requirement. This is in preparation for some AMCC boards (Sequoia/Rainier and Yosemite/Yellowstone) using this function to not violate the PCI clocking rules. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc4xx: respect 80-chars per line in ppc*.h filesNiklaus Giger
After running checkstyle.pl on the three previous patches I noted that in the *.h files there were a lot of long lines. This patch solves this problem. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-05-23ppc4xx: Move definition for PPC4xx NAND FLASH controller to headerStefan Roese
This patch moves the definition for the PPC4xx NAND FLASH controller (NDFC) CONFIG_NAND_NDFC into include/ppc4xx.h. This is needed for the upcoming fix for the ECC byte ordering of the NDFC driver. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2008-10-21ppc4xx: Add routine to retrieve CPU numberAdam Graham
Provide a weak defined routine to retrieve the CPU number for reference boards that have multiple CPU's. Default behavior is the existing single CPU print output. Reference boards with multiple CPU's need to provide a board specific routine. See board/amcc/arches/arches.c for an example. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-05ppc4xx: Update Kilauea to use PPC4xx DDR autocalibration routinesAdam Graham
Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-21ppc4xx: Cleanup of "ppc4xx: Optimize PLB4 Arbiter..." patchStefan Roese
This patch fixes some minor issues introduced with the patch: ppc4xx: Optimize PLB4 Arbiter... from Prodyut Hazarika: - Rework memory-queue and PLB arbiter optimization code, that the local variable is not needed anymore. This removes one #ifdef. - Use consistant spacing in ppc4xx.h header (XXX + 0x01 instead of XXX+ 0x01). This was not introduced by Prodyut, just a copy-paste problem. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-21ppc4xx: Optimize PLB4 Arbiter and Memory Queue settings for PPC440SP/SPe,Prodyut Hazarika
PPC405EX and PPC460EX/GT/SX - Read pipeline depth set to 4 for PPC440SP/SPE, PPC405EX, PPC460EX/GT/SX processors - Moved PLB4 Arbiter register definitions to ppc4xx.h since it is shared across processors (405 and 440/460) - Optimize Memory Queue settings for PPC440SP/SPE and PPC460EX/GT/SX processors - Add register bit definitions for Memory Queue Configuration registers Signed-off-by: Prodyut Hazarika <phazarika@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-06Fix merge problemsStefan Roese
2008-07-18ppc4xx: CPU PPC440x5 on Virtex5 FXRicardo Ribalda Delgado
-This patchs gives support for the embbedded ppc440 on the Virtex5 FPGAs -interrupts.c divided in uic.c and interrupts.c -xilinx_irq.c for xilinx interrupt controller -Include modifications propossed by Stefan Roese Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Acked-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Consolidate PPC4xx UIC definesStefan Roese
This patch is the first step to consolidate the UIC related defines in the 4xx headers. Move header from asm-ppc/ppc4xx-intvec.h to asm-ppc/ppc4xx-uic.h as it will hold all UIC related defines in the next steps. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Consolidate PPC4xx EBC definesStefan Roese
This patch removes all EBC related defines from the PPC4xx headers ppc405.h and ppc440.h and introduces a new header include/asm-ppc/ppc4xx-ebc.h with all those defines. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Add initial 460SX reference board (redwood) config file and defines.Feng Kan
Signed-off-by: Feng Kan <fkan@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Consolidate PPC4xx SDRAM/DDR/DDR2 defines, part1Stefan Roese
This patch removes all SDRAM related defines from the PPC4xx headers ppc405.h and ppc440.h. This is needed since now some 405 PPC's use the same SDRAM controller as 440 systems do (like 405EX and 440SP). It also introduces new defines for the equipped SDRAM controller based on which PPC variant is used. There new defines are: used on 405GR/CR/EP and some Xilinx Virtex boards. used on 440GP/GX/EP/GR. used on 440EPx/GRx. used on 405EX/r/440SP/SPe/460EX/GT. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Enable Primordial Stack for 40x and Unify ECC HandlingGrant Erickson
This patch (Part 1 of 2): * Rolls up a suite of changes to enable correct primordial stack and global data handling when the data cache is used for such a purpose for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS). * Related to the first, unifies DDR2 SDRAM and ECC initialization by eliminating redundant ECC initialization implementations and moving redundant SDRAM initialization out of board code into shared 4xx code. * Enables MCSR visibility on the 405EX(r). * Enables the use of the data cache for initial RAM on both AMCC's Kilauea and Makalu and removes a redundant CFG_POST_MEMORY flag from each board's CONFIG_POST value. - Removed, per Stefan Roese's request, defunct memory.c file for Makalu and rolled sdram_init from it into makalu.c. With respect to the 4xx DDR initialization and ECC unification, there is certainly more work that can and should be done (file renaming, etc.). However, that can be handled at a later date on a second or third pass. As it stands, this patch moves things forward in an incremental yet positive way for those platforms that utilize this code and the features associated with it. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2002-08-06Initial revisionwdenk
