path: root/include/ppc440.h
2008-01-09Merge branch 'lwmon5-no-ocm'Stefan Roese
2008-01-09ppc4xx: Change LWMON5 to not use OCM for init-ram and POST anymoreStefan Roese
This patch configures the LWMON5 port to use d-cache as init-ram and the unused GPT0_COMP6 as POST WORD storage. Signed-off-by: Stefan Roese <sr@denx.de>
2008-01-05ppc4xx: Update Katmai/44x_spd_ddr2.c code for optimal DDR2 setupStefan Roese
On Katmai the complete auto-calibration somehow doesn't seem to produce the best results, meaning optimal values for RQFD/RFFD. This was discovered by GDA using a high bandwidth scope, analyzing the DDR2 signals. GDA provided a fixed value for RQFD, so now on Katmai "only" RFFD is auto-calibrated. This patch also adds RDCC calibration as mentioned on page 7 of the AMCC PowerPC440SP/SPe DDR2 application note: "DDR1/DDR2 Initialization Sequence and Dynamic Tuning" Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27Add definitions for 440EPx/GRx SDRAM controller to ppc440.hLarry Johnson
This patch adds the Denali SDRAM controller definitions to "ppc440.h". It also fixes two typos in the definitions, so the board-specific "sdram.h" files containing these definitions are also fixed to avoid compiler warnings. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-06ppc4xx: Enable hardware-fix for PCI/DMA errata on AMCC 440SP/SPe boardsStefan Roese
This patch enables the hardware-fix for the PCI/DMA errata's 19+22 by setting the FIXD bit in the SDR0_MFR register. Here a description of the symptoms: Problem Description ------------------------------ If a DMA is performed between memory and PCI with the DMA 1 Controller using prefetch, and as a result uses a special purpose buffer selected by the PCIXn Bridge Options 1 Register (PCIXn_BRDGOPT1[RBP7] - bits 31-29), the first part of the transfer sequence is performed twice. The PPC440SPe PCI Controller requests more data than was needed such that in the case of enforce memory protection, a host CPU exception can occur. No data is corrupted, because data transfer is stopped in the PCI Controller. Prefetch enable is specified by setting DMA Configuration Register (I2O0_DMAx_CFG[DXEPD] - bit 31) to 0. Behavior that may be observed in a running system --------------------------------------------------------------------------- 1. DMA performance is decreased because of the double access on the PCI bus interface. 2. If an illegal access to some address on the PCI bus is detected at the system level, a machine check or similar system error may occur. Workarounds Available ---------------------------------- 1. Do not program prefetch. Note that a prefetch command cannot be programmed without selecting a special purpose buffer. 2. To avoid crossing a physical boundary of the PCI slave device, add 512 bytes of address to the PCI address range. This patch was originally provided by Pravin M. Bathija <pbathija@amcc.com> from AMCC and slighly changed. Signed-off-by: Pravin M. Bathija <pbathija@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-15ppc4xx: Enable 440 GPIO init table CFG_440_GPIO_TABLE for 405 platformsStefan Roese
- Rename CFG_440_GPIO_TABLE to CFG_4xx_GPIO_TABLE - Cleanup of the 4xx GPIO functions - Move some GPIO defines from the cpu headers ppc405.h/ppc440.h into gpio.h Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework 4xx cache supportStefan Roese
New cache handling functions added and all existing functions moved from start.S into seperate cache.S. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add PPC405EX supportStefan Roese
2007-07-31ppc4xx: Update 440EPx lwmon5 board supportStefan Roese
- Clear ECC status regs after ECC POST test - Set dcbz for ECC generation with caches enabled as default - Code cleanup Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2007-07-04resubmit: ppc4xx: Remove sequoia/sequioa.h. Cleanup ppc440.h for PPC440EPXNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@nestal.com>
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-22Extend POST support for PPC440Igor Lisitsin
Added memory, CPU, UART, I2C and SPR POST tests for PPC440. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2007-06-15Merge with /home/stefan/git/u-boot/denx-440-exceptionsStefan Roese
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-15[ppc4xx] Add initial lwmon5 board supportStefan Roese
This patch adds initial support for the Liebherr lwmon5 board euqipped with an AMCC 440EPx PowerPC. Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-11ppc4xx: Add mtcpr/mfcpr access macrosStefan Roese
2007-04-18ppc4xx: Add output for bootrom location to 405EZ portsStefan Roese
Now 405EZ ports also show upon bootup from which boot device they are configured to boot: U-Boot 1.2.0-gd3832e8f-dirty (Apr 18 2007 - 07:47:05) CPU: AMCC PowerPC 405EZ Rev. A at 199.999 MHz (PLB=133, OPB=66, EBC=66 MHz) Bootstrap Option E - Boot ROM Location EBC (32 bits) 16 kB I-Cache 16 kB D-Cache Board: Acadia - AMCC PPC405EZ Evaluation Board Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-24Merge with /home/stefan/git/u-boot/acadiaStefan Roese
2007-03-24[PATCH] Add 4xx GPIO functionsStefan Roese
This patch adds some 4xx GPIO functions. It also moves some of the common code and defines into a common 4xx GPIO header file. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-08Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-03-08ppc4xx: Update 440SP/440SPe DDR SPD setup code to support 440SPStefan Roese
2007-03-06[PATCH] Speed optimization of AMCC Sequoia/Rainier DDR2 setupStefan Roese
As provided by the AMCC applications team, this patch optimizes the DDR2 setup for 166MHz bus speed. The values provided are also save to use on a "normal" 133MHz PLB bus system. Only the refresh counter setup has to be adjusted as done in this patch. For this the NAND booting version had to include the "speed.c" file from the cpu/ppc4xx directory. With this addition the NAND SPL image will just fit into the 4kbytes of program space. gcc version 4.x as provided with ELDK 4.x is needed to generate this optimized code. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-01[PATCH] Update AMCC Katmai 440SPe eval board supportStefan Roese
This patch updates the recently added Katmai board support. The biggest change is the support of ECC DIMM modules in the 440SP(e) SPD DDR2 driver. Please note, that still some problems are left with some memory configurations. See the driver for more details. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
2007-01-05[PATCH] Clear PLB4A0_ACR[WRP] on Sequoia (440EPx)Stefan Roese
This fix will make the MAL burst disabling patch for the Linux EMAC driver obsolete. Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-29[PATCH] include/ppc440.h minor error affecting interruptsStefan Roese
Fixed include/ppc440.c for UIC address Bug Corrects bug affecting the addresses for the universal interrupt controller UIC2 and UIC3 on the PPC440 Epx, GRx, and SPE chips. Signed-off-by: Jeff Mann <mannj@embeddedplanet.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-10Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-09-20Fix comments in include/ppc440.hWolfgang Denk
Patch by Martin Hicks, 16 Jun 2006
2006-09-18Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-08-15Add initial support for the ALPR board from ProdriveStefan Roese
NAND needs some additional testing Patch by Heiko Schocher, 15 Aug 2006
2006-06-30Fix CONFIG_440_GX define usage.Marian Balakowicz
2006-06-30Merge: Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-02Add support for PCS440EP boardStefan Roese
Patch by Stefan Roese, 02 Jun 2006
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
2005-11-22Add support for Prodrive P3P440 board:Stefan Roese
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005
2005-09-25Fix typos in include/ppc440.hWolfgang Denk
Patch by Andrew E Mileski, 04 Feb 2005
2005-08-15Add Sandburst Metrobox and Sandburst Karef board support packages.Stefan Roese
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005
2005-08-08Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux)Stefan Roese
Patch by Stefan Roese, 08 Aug 2005
2005-08-04Add support for AMCC Bamboo PPC440EP eval boardStefan Roese
Patch by Stefan Roese, 04 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2005-04-03Patch by David Adair, 27 Oct 2004:wdenk
Add missing 440GX SDRAM Controller reset
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
