path: root/include/ppc405.h
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06ppc4xx: Add NAND booting support for AMCC Acadia (405EZ) eval boardStefan Roese
This patch adds NAND booting support for the AMCC Acadia eval board. Please make sure to configure jumper J7 to position 2-3 when booting from NOR, and to position 1-2 when booting for NAND. I also added a board command to configure the I2C bootstrap EEPROM values. Right now only 267MHz is support for booting either via NOR or NAND FLASH. Here the usage: => bootstrap 267 nor ;to configure the board for 267MHz NOR booting => bootstrap 267 nand ;to configure the board for 267MHz NNAND booting Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-22ppc4xx: Use do { ... } while (0) for CPR & SDR access macrosStefan Roese
2007-04-18ppc4xx: Add output for bootrom location to 405EZ portsStefan Roese
Now 405EZ ports also show upon bootup from which boot device they are configured to boot: U-Boot 1.2.0-gd3832e8f-dirty (Apr 18 2007 - 07:47:05) CPU: AMCC PowerPC 405EZ Rev. A at 199.999 MHz (PLB=133, OPB=66, EBC=66 MHz) Bootstrap Option E - Boot ROM Location EBC (32 bits) 16 kB I-Cache 16 kB D-Cache Board: Acadia - AMCC PPC405EZ Evaluation Board Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-21[PATCH] Add AMCC PPC405EZ supportStefan Roese
This patch adds support for the new AMCC 405EZ PPC. It is in preparation for the AMCC Acadia board support. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
2007-01-11 Added support for the SOLIDCARD III board from EurodesignHeiko Schocher
2004-12-16Code cleanup.wdenk
2004-12-16new 405ep defines addedstroese
2004-06-06Add support for the second Ethernet interface for the 'PPChameleon' board.wdenk
2003-12-09Updated for PPC405EP boards.stroese
2003-05-23PPC405EP support added.stroese
2003-03-20Added edge conditioning register (ecr) for PPC405GPr.stroese
