This patch was originall provided by David Mitchell <dmitchell@amcc.com>
and fixes a bug in the PLL clock calculation.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
Now 405EZ ports also show upon bootup from which boot device
they are configured to boot:
U-Boot 1.2.0-gd3832e8f-dirty (Apr 18 2007 - 07:47:05)
CPU: AMCC PowerPC 405EZ Rev. A at 199.999 MHz (PLB=133, OPB=66, EBC=66 MHz)
Bootstrap Option E - Boot ROM Location EBC (32 bits)
16 kB I-Cache 16 kB D-Cache
Board: Acadia - AMCC PPC405EZ Evaluation Board
This patch adds support for the new AMCC 405EZ PPC. It is in
preparation for the AMCC Acadia board support.
Please note that this Acadia/405EZ support is still in a beta stage.
Still lot's of cleanup needed but we need a preliminary release now.
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
