path: root/include/ppc405.h
2008-07-11ppc4xx: Consolidate PPC4xx UIC definesStefan Roese
This 2nd patch now removes all UIC mask bit definition. They should be generated from the vectors by using the UIC_MASK() macro from now on. This way only the vectors need to get defined for new PPC's. Also only the really used interrupt vectors are now defined. This makes definitions for new PPC versions easier and less error prone. Another part of this patch is that the 4xx emac driver got a little cleanup, since now the usage of the interrupts is clearer. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Consolidate PPC4xx EBC definesStefan Roese
This patch removes all EBC related defines from the PPC4xx headers ppc405.h and ppc440.h and introduces a new header include/asm-ppc/ppc4xx-ebc.h with all those defines. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Add SDR0_SRST Mnemonics for the 405EX(r)Grant Erickson
This patch adds bit field mnemonics for the 405EX(r) SDR0_SRST soft reset register. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Consolidate PPC4xx SDRAM/DDR/DDR2 defines, part1Stefan Roese
This patch removes all SDRAM related defines from the PPC4xx headers ppc405.h and ppc440.h. This is needed since now some 405 PPC's use the same SDRAM controller as 440 systems do (like 405EX and 440SP). It also introduces new defines for the equipped SDRAM controller based on which PPC variant is used. There new defines are: used on 405GR/CR/EP and some Xilinx Virtex boards. used on 440GP/GX/EP/GR. used on 440EPx/GRx. used on 405EX/r/440SP/SPe/460EX/GT. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Enable Primordial Stack for 40x and Unify ECC HandlingGrant Erickson
This patch (Part 1 of 2): * Rolls up a suite of changes to enable correct primordial stack and global data handling when the data cache is used for such a purpose for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS). * Related to the first, unifies DDR2 SDRAM and ECC initialization by eliminating redundant ECC initialization implementations and moving redundant SDRAM initialization out of board code into shared 4xx code. * Enables MCSR visibility on the 405EX(r). * Enables the use of the data cache for initial RAM on both AMCC's Kilauea and Makalu and removes a redundant CFG_POST_MEMORY flag from each board's CONFIG_POST value. - Removed, per Stefan Roese's request, defunct memory.c file for Makalu and rolled sdram_init from it into makalu.c. With respect to the 4xx DDR initialization and ECC unification, there is certainly more work that can and should be done (file renaming, etc.). However, that can be handled at a later date on a second or third pass. As it stands, this patch moves things forward in an incremental yet positive way for those platforms that utilize this code and the features associated with it. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add basic support for AMCC 460EX/460GT (4/5)Stefan Roese
This patch adds basic support for the AMCC 460EX/460GT PPC's. Signed-off-by: Stefan Roese <sr@denx.de>
2008-02-16ppc4xx: PPC405GPr fix missing register definitionsNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-12-08ppc4xx: 405EX: Correctly enable USB pinsStefan Roese
This patch selects the USB data pins in the 405EX GPIO and MFC (multi function control) registers. This is done for the AMCC Kilauea and Makalu eval boards. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-15ppc4xx: Enable 440 GPIO init table CFG_440_GPIO_TABLE for 405 platformsStefan Roese
- Rename CFG_440_GPIO_TABLE to CFG_4xx_GPIO_TABLE - Cleanup of the 4xx GPIO functions - Move some GPIO defines from the cpu headers ppc405.h/ppc440.h into gpio.h Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework 4xx cache supportStefan Roese
New cache handling functions added and all existing functions moved from start.S into seperate cache.S. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Fix small merge problems with CPCI440 and Acadia boardsStefan Roese
2007-10-31ppc4xx: Add PPC405EX supportStefan Roese
2007-08-14Merge with /home/stefan/git/u-boot/zeusStefan Roese
2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2007-08-13ppc4xx: Fix problem in PLL clock calculationStefan Roese
This patch was originall provided by David Mitchell <dmitchell@amcc.com> and fixes a bug in the PLL clock calculation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06ppc4xx: Add NAND booting support for AMCC Acadia (405EZ) eval boardStefan Roese
This patch adds NAND booting support for the AMCC Acadia eval board. Please make sure to configure jumper J7 to position 2-3 when booting from NOR, and to position 1-2 when booting for NAND. I also added a board command to configure the I2C bootstrap EEPROM values. Right now only 267MHz is support for booting either via NOR or NAND FLASH. Here the usage: => bootstrap 267 nor ;to configure the board for 267MHz NOR booting => bootstrap 267 nand ;to configure the board for 267MHz NNAND booting Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-22ppc4xx: Use do { ... } while (0) for CPR & SDR access macrosStefan Roese
2007-04-18ppc4xx: Add output for bootrom location to 405EZ portsStefan Roese
Now 405EZ ports also show upon bootup from which boot device they are configured to boot: U-Boot 1.2.0-gd3832e8f-dirty (Apr 18 2007 - 07:47:05) CPU: AMCC PowerPC 405EZ Rev. A at 199.999 MHz (PLB=133, OPB=66, EBC=66 MHz) Bootstrap Option E - Boot ROM Location EBC (32 bits) 16 kB I-Cache 16 kB D-Cache Board: Acadia - AMCC PPC405EZ Evaluation Board Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-21[PATCH] Add AMCC PPC405EZ supportStefan Roese
This patch adds support for the new AMCC 405EZ PPC. It is in preparation for the AMCC Acadia board support. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
2007-01-11 Added support for the SOLIDCARD III board from EurodesignHeiko Schocher
2004-12-16Code cleanup.wdenk
2004-12-16new 405ep defines addedstroese
2004-06-06Add support for the second Ethernet interface for the 'PPChameleon' board.wdenk
2003-12-09Updated for PPC405EP boards.stroese
2003-05-23PPC405EP support added.stroese
2003-03-20Added edge conditioning register (ecr) for PPC405GPr.stroese
