This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
This patch cleans up the PPC4xx I2C intrastructure:
- Use C struct to describe the I2C registers instead of defines
- Coding style cleanup (braces, whitespace, comments, line length)
- Extract common code from i2c_read() and i2c_write()
- Remove unneeded IIC defines from ppc405.h & ppc440.h
After running checkstyle.pl on the three previous patches I noted that in
the *.h files there were a lot of long lines. This patch solves this problem.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
Here you find all the changes in the include directory for new register names
and adapting other ones to the names used by AMCC in their manuals, e.g.
For 440EPx/GRPPC440EPx/GRX, Revision 1.15 – September 22, 2008
For PPC405GP Embedded Processor, Revision 1.02 – March 22, 2006
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
It was brought to our attention that U-Boot contains code derived from the
IBM OpenBIOS source code originally provided with some of the older PowerPC
4xx development boards. As a result, the original license of this code has
been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot
under either the terms of the GNU General Public License version 2, or the
original code license already present.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This 2nd patch now removes all UIC mask bit definition. They should be
generated from the vectors by using the UIC_MASK() macro from now on.
This way only the vectors need to get defined for new PPC's.
Also only the really used interrupt vectors are now defined. This makes
definitions for new PPC versions easier and less error prone.
Another part of this patch is that the 4xx emac driver got a little
cleanup, since now the usage of the interrupts is clearer.
This patch removes all EBC related defines from the PPC4xx headers
ppc405.h and ppc440.h and introduces a new header
include/asm-ppc/ppc4xx-ebc.h
with all those defines.
This patch adds bit field mnemonics for the 405EX(r) SDR0_SRST soft reset register.
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
This patch removes all SDRAM related defines from the PPC4xx headers
ppc405.h and ppc440.h. This is needed since now some 405 PPC's use
the same SDRAM controller as 440 systems do (like 405EX and 440SP).
It also introduces new defines for the equipped SDRAM controller based on
which PPC variant is used. There new defines are:
used on 405GR/CR/EP and some Xilinx Virtex boards.
used on 440GP/GX/EP/GR.
used on 440EPx/GRx.
used on 405EX/r/440SP/SPe/460EX/GT.
This patch (Part 1 of 2):
* Rolls up a suite of changes to enable correct primordial stack and
global data handling when the data cache is used for such a purpose
for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS).
* Related to the first, unifies DDR2 SDRAM and ECC initialization by
eliminating redundant ECC initialization implementations and moving
redundant SDRAM initialization out of board code into shared 4xx
code.
* Enables MCSR visibility on the 405EX(r).
* Enables the use of the data cache for initial RAM on
both AMCC's Kilauea and Makalu and removes a redundant
CFG_POST_MEMORY flag from each board's CONFIG_POST value.
- Removed, per Stefan Roese's request, defunct memory.c file for
Makalu and rolled sdram_init from it into makalu.c.
With respect to the 4xx DDR initialization and ECC unification, there
is certainly more work that can and should be done (file renaming,
etc.). However, that can be handled at a later date on a second or
third pass. As it stands, this patch moves things forward in an
incremental yet positive way for those platforms that utilize this
code and the features associated with it.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This patch adds basic support for the AMCC 460EX/460GT PPC's.
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
This patch selects the USB data pins in the 405EX GPIO and MFC (multi
function control) registers. This is done for the AMCC Kilauea and
Makalu eval boards.
- Rename CFG_440_GPIO_TABLE to CFG_4xx_GPIO_TABLE
- Cleanup of the 4xx GPIO functions
- Move some GPIO defines from the cpu headers ppc405.h/ppc440.h into gpio.h
New cache handling functions added and all existing functions
moved from start.S into seperate cache.S.
This patch moves some common 4xx macros and the PPC405_SYS_INFO/
PPC440_SYS_INFO structure into the common ppc4xx.h header.
Lot's of other macros are good candidates to be consolidated this way
in the future.
This patch was originall provided by David Mitchell <dmitchell@amcc.com>
and fixes a bug in the PLL clock calculation.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
Now 405EZ ports also show upon bootup from which boot device
they are configured to boot:
U-Boot 1.2.0-gd3832e8f-dirty (Apr 18 2007 - 07:47:05)
CPU: AMCC PowerPC 405EZ Rev. A at 199.999 MHz (PLB=133, OPB=66, EBC=66 MHz)
Bootstrap Option E - Boot ROM Location EBC (32 bits)
16 kB I-Cache 16 kB D-Cache
Board: Acadia - AMCC PPC405EZ Evaluation Board
This patch adds support for the new AMCC 405EZ PPC. It is in
preparation for the AMCC Acadia board support.
Please note that this Acadia/405EZ support is still in a beta stage.
Still lot's of cleanup needed but we need a preliminary release now.
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
