This Rockchip PMIC provides features suitable for battery-powered
applications. It is commonly used with Rockchip SoCs.
Add a driver which provides register access. The regulator driver will use
this.
include/power/pmic.h never used any generic spi code
from include/spi.h, but this has been added in below commit.
"dm: pmic: add implementation of driver model pmic uclass"
(sha1: 4d9057e82be11a862db411c4867e859fe0d4ca2a)
Adding functionalities in include/spi.h will trigger a build
issue as this been added used in include/power/pmic.h
Build issue on trats2 with adding BIT macro on spi.h:
CC lib/asm-offsets.s
In file included from include/power/pmic.h:15:0,
from include/power/max77686_pmic.h:11,
from include/configs/trats2.h:212,
from include/config.h:5,
from include/common.h:18,
from lib/asm-offsets.c:15:
include/spi.h: In function 'spi_w8r8':
include/spi.h:327:2: warning: implicit declaration of function 'BIT' [-Wimplicit-function-declaration]
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Reported-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
This commit adds unit tests for ADC uclass's methods using sandbox ADC.
Testing proper ADC binding:
- dm_test_adc_bind() - device binding
- dm_test_adc_wrong_channel_selection() - checking wrong channel selection
Testing ADC supply operations:
- dm_test_adc_supply():
- Vdd/Vss values validating
- Vdd regulator updated value validating
- Vdd regulator's auto enable state validating
Testing ADC operations results:
- dm_test_adc_single_channel_conversion() - single channel start/data
- dm_test_adc_single_channel_shot() - single channel shot
- dm_test_adc_multi_channel_conversion() - multi channel start/data
- dm_test_adc_multi_channel_shot() - multi channel single shot
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Some devices are supplied by configurable regulator's output.
But there was no function for getting it. This commit adds
function, that allows for getting the supply device by it's phandle.
The returned regulator device can be used with regulator uclass's API.
This driver allows I/O operations on the Samsung S2MPS11 PMIC,
which provides lots of LDO/BUCK outputs.
To enable it, update defconfig with:
- CONFIG_PMIC_S2MPS11
and additional, if were not defined:
- CONFIG_CMD_PMIC
- CONFIG_ERRNO_STR
The binding info: doc/device-tree-bindings/pmic/s2mps11.txt
Tested-by: Anand Moon <linux.amoon@gmail.com>
Add a driver for the ACT8846 PMIC. This supports several LDOs and BUCKs and
is connected to the I2C bus. This driver supports using a regulator driver
to access the regulators.
* Add pmic pfuze3000 support, implement power_pfuze3000_init to be
used in power_init_board callback function.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
This part of mentioned commit, was missed by my mistake during the rebase.
Original commit message:
power: pmic: pfuze100 support driver model
1. Support driver model for pfuze100.
2. Introduce a new Kconfig entry DM_PMIC_PFUZE100 for pfuze100
3. This driver intends to support PF100, PF200 and PF3000, so add
the device id into the udevice_id array.
4. Rename PMIC_NUM_OF_REGS macro to PFUZE100_NUM_OF_REGS.
Change-Id: I4fc88414f3c0285f9648e47ec7aed60addeccc4d
This adds a simple pmic driver for the hi6553 pmic which is used in
conjunction with the hi6220 SoC on the hikey board. Eventually this
driver will be updated to be a proper UCLASS PMIC driver which
can parse the voltages direct from device tree.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
1. Add new regulator driver pfuze100.
* Introduce struct pfuze100_regulator_desc for maintaining info
for one regulator.
2. Add new Kconfig entry DM_REGULATOR_PFUZE100 for pfuze100.
3. This driver intends to support PF100, PF200 and PF3000.
4. Add related macro definition in pfuze header file.
We do not need that "regulator-name" property must be provided in dts.
If "regulator-name" property is not provided in dts, node name
will chosen for settings '.name' field of uc_pdata.
According to datasheet, SWBST_MODE starts from bit 2 and it occupies 2 bits.
So SWBST_MODE_MASK should be 0xC, and SWBST_MODE_xx should be ([mode] << 2).
Remove the old drivers (both the normal one and the cros_ec one) now that
we have new drivers that use driver model.
This PMIC is used with SoCs which need a combination of BUCKs and LDOs. The
driver supports probing and basic register access. It supports the standard
device tree binding and supports driver model. A regulator driver can be
provided also.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
The existing TPS65090 driver does not support driver model. Add a new one
that does. This can be used as a base for a regulator driver also. It uses
the standard device tree binding.
Add support for MAX77696 PMIC.
It is a common requirement to update some PMIC registers. Provide some
simple convenience functions to do this.
Tested-by: Przemyslaw Marczak <p.marczak@samsung.com>
The device tree provides information about which regulators should be
on at boot, or always on. Use this to set them up automatically.
The regulator_autoset() function mixes printf() output and PMIC adjustment
code. It provides a boolean to control the output. It is better to avoid
missing logic and output, and this permits a smaller SPL code size. So
split the output into a separate function.
Also rename the function to have a by_name() suffix, since we would like
to be able to pass a device when we know it, and thus avoid the name
search.
Decide when the regulator is set up whether we want to auto-set the voltage
or current. This avoids the complex logic spilling into the processing code.
Change PUZE_100_SW1ABCONF to PFUZE100_SW1ABCONF
This change adds new file to sandbox driver model test environment.
The file is: test/dm/power.c, and it includes tests for PMIC framework,
which includes PMIC uclass and REGULATOR uclass.
All tests are based od Sandbox PMIC emulated device. Some test constants for
this device are defined in the header: include/power/sandbox_pmic.h
PMIC tests includes:
- pmic get - tests, that pmic_get() returns the requested device
- pmic I/O - tests I/O by writing and reading some values to PMIC's registers
and then compares, that the write/read values are equal.
The regulator tests includes:
- Regulator get by devname/platname
- Voltage set/get
- Current set/get
- Enable set/get
- Mode set/get
- Autoset
- List autoset
For the regulator 'get' test, the returned device pointers are compared,
and their names are also compared to the requested one.
Every other test, first sets the given attribute and next try to get it.
The test pass, when the set/get values are equal.
Tested on sandbox:
This commit adds emulation of sandbox PMIC device, which includes:
- PMIC I2C emulation driver
- PMIC I/O driver (UCLASS_PMIC)
- PMIC regulator driver (UCLASS_REGULATOR)
The sandbox PMIC has 12 significant registers and 4 as padding to 16 bytes,
which allows using 'i2c md' command with the default count (16).
The sandbox PMIC provides regulators:
- 2x BUCK
- 2x LDO
Each, with adjustable output:
- Enable state
- Voltage
- Current limit (LDO1/BUCK1 only)
- Operation mode (different for BUCK and LDO)
Each attribute has it's own register, beside the enable state, which depends
on operation mode.
The header file: sandbox_pmic.h includes PMIC's default register values,
which are set on i2c pmic emul driver's probe() method.
Tested on sandbox:
This cleanup includes:
- remove of the preprocessor macros which pointed to long name functions
- update of the names of some regulator uclass driver functions
- cleanup of the function regulator_autoset()
- reword of some comments of regulator uclass header file
- regulator_get_by_platname: check error for uclass_find_* function calls
- add function: regulator_name_is_unique
- regulator post_bind(): check regulator name uniqueness
- fix mistakes in: regulator/Kconfig
- regulator.h: update comments
- odroid u3: cleanup the regulator calls
Tested on sandbox:
The cleanup includes:
- pmic.h - fix mistakes in a few comments
- pmic operations: value 'reg_count' - redefine as function call
- fix function name: pmic_bind_childs() -> pmic_bind_children()
- pmic_bind_children: change the 'while' loop with the 'for'
- add implementation of pmic_reg_count() method
- pmic_bind_children() - update function call name
- Kconfig: add new line at the end of file
- Update MAX77686 driver code
Tested on sandbox:
This commit adds support to MAX77686 regulator driver,
based on a driver model regulator's API. It implements
almost all regulator operations, beside those for setting
and geting the Current value.
For proper bind and operation it requires the MAX77686 PMIC driver.
New file: drivers/power/regulator/max77686.c
New config: CONFIG_DM_REGULATOR_MAX77686
This is the implementation of driver model PMIC driver.
The max77686 PMIC driver implements read/write operations and driver
bind method - to bind its childs.
This driver will try to bind the regulator devices by using it's child
info array with regulator prefixes and driver names. This should succeed
when compatible regulator driver is compiled. If no regulator driver found,
then the pmic can still provide read/write operations, and can be used with
PMIC function calls.
This commit introduces the implementation of dm regulator API.
Device tree support allows for auto binding. And by the basic
uclass operations, it allows to driving the devices in a common
way. For detailed informations, please look into the header file.
Core files:
- drivers/power/regulator-uclass.c - provides regulator common functions api
- include/power/regulator.h - define all structures required by the regulator
Changes:
- new uclass-id: UCLASS_REGULATOR
- new config: CONFIG_DM_REGULATOR
This commit introduces the PMIC uclass implementation.
It allows providing the basic I/O interface for PMIC devices.
For the multi-function PMIC devices, this can be used as I/O
parent device, for each IC's interface. Then, each PMIC particular
function can be provided by the child device's operations, and the
child devices will use its parent for read/write by the common API.
Core files:
- 'include/power/pmic.h'
- 'drivers/power/pmic/pmic-uclass.c'
The old pmic framework is still kept and is independent.
For more detailed informations, please look into the header file.
Changes:
- new uclass-id: UCLASS_PMIC
- new config: CONFIG_DM_PMIC
With the full PMIC framework we may be able to avoid this. But for now
we need access to the PMIC.
Signed-off-by: Tom Warren <twarren@nvidia.com>
The LDO_EN is bit 4, not value 4. This is only used on the Ventana boards so
we will change it in the header as the other values there are in terms of
values and not bit numbers.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
a summary screen to the lcd.
Values are taken from environment and or devicetree blob.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Applying ccbb18713b279f1326479cc10664d247206e9e76,
the define disappeared. Fix it.
Add more pfuze register offset.
And switch mode definition.
"#define PFUZE100_SW1ABC_SETP(x) ((x - 3000) / 250)"
This macro is for configuring SW1A/B/C Output Voltage easily.
This regulator is used with AM437x IDK to feed
VDD_MPU, without means to scale VDD_MPU we can't
support higher frequencies.
Signed-off-by: Felipe Balbi <balbi@ti.com>
DCDC1 is used as VDD_MPU in all known boards,
let's define all other valid voltages for that
rail so it can be used by our boards.
The AS3722 provides a number of DC/DC converters and LDOs as well as 8
GPIOs.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add definitions for buck regulators (SW1A/B/C) registers and voltage
values.
Signed-off-by: Ye.Li <B37916@freescale.com>
Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
Allow to set the buck voltage for the max77686.
This will be used to reset the SMC LAN9730 ethernet on the odroids.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
Add in an init function for the drivers/power framework so we can dump
and read the registers via i2c.
Cc: Łukasz Majewski <l.majewski@samsung.com>
As this is a weak function that we may override, provide a prototype for
it.
Add a driver for the TPS65218 PMIC which is used by TI AM43xx SoCs and
may be used by TI AM335x SoCs.
mx6sabresd boards have a PFUZE100 PMIC connected to I2C2 bus.
Add support for it
This adds driver support for the TPS65090 PMU. Support includes
hooking into the pmic infrastructure so that the pmic commands
can be used on the console. The TPS65090 supports the following
functionality:
- fet enable/disable/querying
- getting and setting of charge state
Even though it is connected to the pmic infrastructure it does
not hook into the pmic charging charging infrastructure.
The device tree binding is from Linux, but only a small subset of
functionality is supported.
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
Signed-off-by: Katie Roberts-Hoffman <katierh@chromium.org>
Signed-off-by: Rong Chang <rongchang@chromium.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Aaron Durbin <adurbin@chromium.org>
