path: root/include/power
2015-01-13pmic: add tps62362 simple wrapper codeFelipe Balbi
This regulator is used with AM437x IDK to feed VDD_MPU, without means to scale VDD_MPU we can't support higher frequencies. Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-13power: tps65218: define all valid VDD_MPU voltagesFelipe Balbi
DCDC1 is used as VDD_MPU in all known boards, let's define all other valid voltages for that rail so it can be used by our boards. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-12-18power: Add AMS AS3722 PMIC supportThierry Reding
The AS3722 provides a number of DC/DC converters and LDOs as well as 8 GPIOs. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-11-26Merge branch 'master' of http://git.denx.de/u-boot-samsungTom Rini
2014-11-20power: pfuze100: Update definitions for buck regulatorsYe.Li
Add definitions for buck regulators (SW1A/B/C) registers and voltage values. Signed-off-by: Ye.Li <B37916@freescale.com> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-11-17arm: odroid: pmic77686: allow buck voltage settingsSuriyan Ramasami
Allow to set the buck voltage for the max77686. This will be used to reset the SMC LAN9730 ethernet on the odroids. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-07-25tps65218/am43xx_evm: Add power framework support to TPS65218Tom Rini
Add in an init function for the drivers/power framework so we can dump and read the registers via i2c. Cc: Łukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-07-25power/pmic.h: Add prototype for power_init_board.Tom Rini
As this is a weak function that we may override, provide a prototype for it. Cc: Łukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-06-30Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-06power: Add support for the TPS65218 PMICTom Rini
Add a driver for the TPS65218 PMIC which is used by TI AM43xx SoCs and may be used by TI AM335x SoCs. Signed-off-by: Tom Rini <trini@ti.com>
2014-06-02Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-28mx6sabred: Add PFUZE100 PMIC supportFabio Estevam
mx6sabresd boards have a PFUZE100 PMIC connected to I2C2 bus. Add support for it Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-05-28power: Add support for TPS65090 PMU chip.Tom Wai-Hong Tam
This adds driver support for the TPS65090 PMU. Support includes hooking into the pmic infrastructure so that the pmic commands can be used on the console. The TPS65090 supports the following functionality: - fet enable/disable/querying - getting and setting of charge state Even though it is connected to the pmic infrastructure it does not hook into the pmic charging charging infrastructure. The device tree binding is from Linux, but only a small subset of functionality is supported. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Katie Roberts-Hoffman <katierh@chromium.org> Signed-off-by: Rong Chang <rongchang@chromium.org> Signed-off-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Aaron Durbin <adurbin@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-28power: Add PMIC_ prefix to CHARGER_EN/DISABLESimon Glass
This enum should be common across all PMICs rather than having it independently defined with the same name in multiple places. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-09power: Add support for LTC3676 PMICTim Harvey
The LTC3676 PMIC includes four DC/DC converters, and three 300mA LDO Regulators (two Adjustable). The DC/DC converters are adjustable based on a resistor devider (board-specific). This adds support for the LTC3676 by creating a namespace unique init function that uses the PMIC API to allocate a pmic and defines the registers. Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-05-09power: make pfuze100 be able to coexist with other pmicsTim Harvey
Avoid uding pmic_init() as this forces the model of only allowing a single PMIC driver to be built at a time. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-03-05Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-03-05power: add PFUZE100 PMIC driverTim Harvey
2014-02-03trats2: add LCD download menu supportPrzemyslaw Marczak
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03trats2: Code cleanup.Przemyslaw Marczak
Remove wrong and unused env variables Trats2 is not as GT-I8800. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Cc: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-10-14pmic: max77686: fix the wrong offsetJaehoon Chung
0x1D is reserved. So BUCK3DVS1 is started from 0x1e. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2013-10-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-09-25drivers:power:max77693: add support for new multi function pmic max77693Piotr Wilczek
This patch add support for new multi function pmic max77693. The driver is split into three modules: pmic, muic and fuelgage. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-20am335x:Handle worst case scenario for Errata 1.0.24Steve Kipisz
In Errata 1.0.24, if the board is running at OPP50 and has a warm reset, the boot ROM sets the frequencies for OPP100. This patch attempts to drop the frequencies back to OPP50 as soon as possible in the SPL. Then later the voltages and frequencies up set higher. Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> [trini: Adapt to current framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20drivers/power/pmic: Add tps65910 driverPhilip, Avinash
Add a driver for the TPS65910 PMIC that is found in the AM335x GP EVM, AM335x EVM SK and others. Signed-off-by: Philip, Avinash <avinashphilip@ti.com> [trini: Split and rework Avinash's changes into new drivers/power framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20drivers/power/pmic: Add tps65217 driverGreg Guyotte
Add a driver for the TPS65217 PMIC that is found in the Beaglebone family of boards. Signed-off-by: Greg Guyotte <gguyotte@ti.com> [trini: Split and rework Greg's changes into new drivers/power framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-30drivers:power:max77686: add function to set voltage and modePiotr Wilczek
This patch add new functions to pmic max77686 to set voltage and mode. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-24exynos: Adjust the starting MIF voltage to 1.05vBernie Thompson
Some Exynos5250 silicon may require 1.05v on the MIF to be stable, so to be safe we can default to 1.05v instead of 1.00v. This can be set optimally later in the boot process by the kernel. The 0x6 value for 1.05v comes from the MAX77686 datasheet. Signed-off-by: Bernie Thompson <bhthompson@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-02-20SMDK5250: Add PMIC voltage settingsRajeshwari Shinde
This patch adds required pmic voltage settings for SMDK5250. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-11POWER: MAX77686: Modified as per the latest ImplementationRajeshwari Shinde
Moved the pmic_max77686.c max77686_pmic.h to drivers/power and made required changes accordingly Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-11-14arm:trats:pmic: Default PMIC(MAX8997) initialization for Samsung's TRATS boardŁukasz Majewski
Default PMIC (MAX8997) initialization for Samsung's TRATS development board. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-11-14pmic:max8997: Function for calculating LDO internal register valueŁukasz Majewski
Function for calculating LDO internal register value from passed micro Volt. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:fuel-gauge: Support for MAX17042 fuel-gaugeŁukasz Majewski
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997 power management device. Special file - fg_battery_cell_params.h with cells characteristics added. The FG device will work with redesigned PMIC framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:muic: Support for MUIC built into MAX8997 deviceŁukasz Majewski
Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997 power management device. The MUIC device will work with redesigned PMIC framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Extend struct pmic to support battery and charger related operationsŁukasz Majewski
Now it is possible to provide specific function per PMIC/power device instance. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-11-14pmic:chrg: Common information about charger and battery (power_chrg.h)Łukasz Majewski
New power_chrg.h file has been added to "bind" together common information about charging battery available in the system. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Extend PMIC framework to support multiple instances of PMIC devicesŁukasz Majewski
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power". Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
