path: root/include/phy.h
2015-04-20net/phy: fixup for get_phy_idShengzhou Liu
commit 3c6928fd7b0f84 "net: phy: fix warnings with W=1" caused some PHYs(e.g. CS4315/CS4340) not working. This patch fixes the warning and make those special PHYs working as well. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2015-04-18dm: net: Adjust PHY interface to work with CONFIG_DM_ETHSimon Glass
When driver model is used for Ethernet a few functions are passed a udevice instead of an eth_device. Also add a function to find a PHY type given its name. This will be used to decode the device tree node. Finally, put a phy_interface field in struct eth_pdata since this is an important part of the platform data for Ethernet. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-16phylib: add support for aquantia PHYsShaohui Xie
This patch supports AQ1202, AQ2104, AQR105 PHY. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05net/phy: Add support for CS4315/CS4340 PHYShengzhou Liu
Add support for Cortina CS4315/CS4340 10G PHY. - This driver loads CS43xx firmware from NOR/NAND/SPI/SD device to initialize Cortina PHY. - Cortina PHY has non-standard offset of PHY ID registers, thus we define own get_phy_id() to override default get_phy_id(). - To define macro CONFIG_PHY_CORTINA will enable this driver. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-19net/fm: add 2.5G SGMII supportShengzhou Liu
As auto-negotiation is not supported for 2.5G SGMII, we need to add a new type PHY_INTERFACE_MODE_SGMII_2500 to differentiate SGMII-1G and SGMII-2.5G with different setting for auto-negotiation. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-23net: phy.h: Make PHY autonegotiation timeout configurableStefan Roese
The Marvell MV78460 eval board DB-78460-BP seems to need a longer PHY autonegotiation timeout than the "standard" 4 seconds. So lets make this timeout configurable. If not defined in the board config header the original 4000ms is used. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2014-08-06Change Andy Fleming's email addressAndy Fleming
Messages to afleming@freescale.com now bounce, and should be directed to my personal address at afleming@gmail.com Signed-off-by: Andy Fleming <afleming@gmail.com>
2014-03-05wandboard: Fix sparse warningFabio Estevam
Add a prototype for board_phy_config() to fix the following sparse warning: wandboard.c:200:5: warning: symbol 'board_phy_config' was not declared. Should it be static? Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-12-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-22net: add extended function to phy APIStefano Babic
Some phys (Micrel) has extended registers that must be accessed in a special way. Add pointers to the phy driver structure to allow to use these functions with mdio command. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-11-22phy: introduce structure fixed-linkShaohui Xie
fixed-link is used in kernel for PHY-less MAC, so introduce this structure that U-boot can use it to fixup dtb dynamically. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2013-06-24phy: export genphy_parse_link()Yegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-14net/phy: add VSC8574 supportShaohui Xie
The VSC8574 is a quad-port Gigabit Ethernet transceiver with four SerDes interfaces for quad-port dual media capability. This driver supports SGMII and QSGMII MAC mode. For now SGMII mode is tested. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-10phy: add support for ET1011C physMatt Porter
Adds an ET1011C PHY driver which is derived from the Linux kernel PHY driver (drivers/net/phy/et1011c.c) from the v3.9-rc2 tag. Note that an errata workaround config option is implemented to allow for TX_CLK to be enabled even when gigabit mode is negotiated. This workaround is used on the PG1.0 TI814X EVM. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-01-28phy: add phy_find_by_mask/phy_connect_devTroy Kisky
It is useful to be able to try a range of possible phy addresses to connect. Also, an ethernet device is not required to use phy_find_by_mask leading to better separation of mii vs ethernet, as suggested by Andy Fleming. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-02-27net: phy: add support for Micrel's KSZ9021Troy Kisky
Add the gigabit phy KSZ9021. Also, add function ksz9021_phy_extended_write /_read for access to the phys extended registers. The environment variable "disable_giga" can be used to disable 1000baseTx. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-01-05phy: add phy_smsc_init() declarationVladimir Zapolskiy
This trivial change removes a compilation warning: ----8<---- phy.c: In function 'phy_init': phy.c:448:2: warning: implicit declaration of function 'phy_smsc_init' ----8<---- Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-20powerpc/85xx: wait for alignment before resetting SERDES RX lanes (SERDES9)Timur Tabi
The work-around for P4080 erratum SERDES9 says that the SERDES receiver lanes should be reset after the XAUI starts tranmitting alignment signals. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-20phylib: Add a bunch of PHY drivers from tsecAndy Fleming
The tsec driver had a bunch of PHY drivers already written. This converts them all into PHY Lib drivers, and serves as the first set of PHY drivers for PHY Lib. While doing that, cleaned up a number of magic numbers (though not all of them, as PHY vendors like to keep their numbers as magical as possible). Also, noticed that almost all of the vitesse/cicada PHYs had the same config/parse/startup functions, so those have been collapsed into one. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20Create PHY Lib for U-BootAndy Fleming
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45). The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure. We now have MDIO drivers and PHY drivers An MDIO driver provides: read write reset A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown() Each PHY driver can be configured separately, or all at once using config_phylib_all_drivers.h (added in the patch which adds the drivers) We also provide generic drivers for Clause 22 (10/100/1000), and Clause 45 (10G) PHYs. We also implement phy_reset(), and call it in phy_connect(). Because phy_reset() is essentially the same as miiphy_reset, but: a) must support 10G PHYs, and b) should use the phylib primitives, we implement miiphy_reset, using phy_reset(), but only when CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this way, we save on compile size, even if we don't manage to save code size. Pulled ethtool.h and mdio.h from: git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 782d640afd15af7a1faf01cfe566ca4ac511319d With many, many deletions so as to enable compilation under u-boot Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
