path: root/include/phy.h
2020-09-16include: phy: fix NULL pointer check in phy_write()Thirupathaiah Annapureddy
phy_write() uses bus->write() instead of bus->read(). This means NULL pointer pre-check needs to happen on bus->write instead of bus->read. Signed-off-by: Thirupathaiah Annapureddy <thiruan@linux.microsoft.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2020-08-03net: Drop dm.h header file from phy.hSimon Glass
This header file should not be included in other header files. Remove it and use other headers and C inclusions instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-06-12net: phy: Add helper routines to set and clear bitsDan Murphy
Add phy_set/clear_bit helper routines so that ported drivers from the kernel can use these functions. Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Dan Murphy <dmurphy@ti.com>
2020-06-12net: phy: Fix kernel doc issues in phy.hDan Murphy
Fix kernel doc warnings in phy.h. Mostly the warnings were due to the return missing the semi-colon. Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Dan Murphy <dmurphy@ti.com>
2020-06-12net: phy: Add missing kernel doc to phy functionsDan Murphy
Add kernel doc to the phy_read/write utility functions in phy.h Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Dan Murphy <dmurphy@ti.com>
2020-03-09net: phy: add XFI, USXGMII types to is_10g_interface() helperAlex Marginean
The helper is used to reset PHYs on connect and it determines the clause to use (C22/C45) based on interface type. This fixes 'PHY reset timed out' warnings in console for USXGMII/XFI PHYs. Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-03-09phy: Include NC-SI in phy setupSamuel Mendoza-Jonas
Add NC-SI to the usual phy handling. This makes two notable changes: - Somewhat similar to a fixed phy, phy_connect() will create an NC-SI phy if CONFIG_PHY_NCSI is defined. - An early return is added to phy_read() and phy_write() to handle a case like the NC-SI phy which does not define a bus. Signed-off-by: Samuel Mendoza-Jonas <sam@mendozajonas.com> Reviewed-by: Joel Stanley <joel@jms.id.au> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-03-09phy: Add support for the NC-SI protocolSamuel Mendoza-Jonas
This introduces support for the NC-SI protocol, modelled as a phy driver for other ethernet drivers to consume. NC-SI (Network Controller Sideband Interface) is a protocol to manage a sideband connection to a proper network interface, for example a BMC (Baseboard Management Controller) sharing the NIC of the host system. Probing and configuration occurs by communicating with the "remote" NIC via NC-SI control frames (Ethernet header 0x88f8). This implementation is roughly based on the upstream Linux implementation[0], with a reduced feature set and an emphasis on getting a link up as fast as possible rather than probing the full possible topology of the bus. The current phy model relies on the network being "up", sending NC-SI command frames via net_send_packet() and receiving them from the net_loop() loop (added in a following patch). The ncsi-pkt.h header[1] is copied from the Linux kernel for consistent field definitions. [0]: https://github.com/torvalds/linux/tree/master/net/ncsi [1]: https://github.com/torvalds/linux/blob/master/net/ncsi/ncsi-pkt.h Signed-off-by: Samuel Mendoza-Jonas <sam@mendozajonas.com> Reviewed-by: Joel Stanley <joel@jms.id.au> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-02-05dm: core: Drop the inclusion of linux/compat.h in dm.hSimon Glass
Most files don't need this header and it pulls in quite of lots of stuff, malloc() in particular. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-09include: phy: add data field for private driver dataAlex Marginean
This is useful to carry custom information between the driver structure associated with a specific HW and the driver code. Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-10-08net: phy: Add gmiitorgmii converter supportSiva Durga Prasad Paladugu
This patch adds support for gmiitorgmii converter. This converter sits between the MAC and the external phy MAC <==> GMII2RGMII <==> RGMII_PHY. The ethernet driver probes this bridge and this bridge driver probes real phy driver and invokes the real phy functionalities as requested. This bridge just needs to be configured based on real phy negotiated speed and duplex. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-07-18net: add comments to phy APIsAlex Marginean
Added a comment on the limitations of phy_find_by_mask API when scanning MDIO buses with multiple PHYs present. Added short descriptions to the other APIs in phy.h for consistency. Signed-off-by: Alex Marginean <alexm.osslist@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-07net: phy: Add generic helpers to access MMD PHY registersCarlo Caione
Two new helper functions (phy_read_mmd() and phy_write_mmd()) are added to allow access to the MMD PHY registers. The MMD PHY registers can be accessed by several means: 1. Using two new MMD access function hooks in the PHY driver. These functions can be implemented when the PHY driver does not support the standard IEEE Compatible clause 45 access mechanism described in clause 22 or if the PHY uses its own non-standard access mechanism. 2. Direct access for C45 PHYs and C22 PHYs when accessing the reachable DEVADs. 3. The standard clause 45 access extensions to the MMD registers through the indirection registers (clause 22) in all the other cases. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-24net: phy: Add clause 45 identifier to phy_devicePankaj Bansal
The phy devices can be accessed via clause 22 or via clause 45. This information can be deduced when we read phy id. if the phy id is read without giving any MDIO Manageable Device Address (MMD), then it conforms to clause 22. otherwise it conforms to clause 45. Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-24net/phy: Add phy-id for IN112525_S03Priyanka Jain
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: phy: add ofnode node to struct phy_deviceGrygorii Strashko
Now the UCLASS_ETH device "node" field is owerwritten by some network drivers in case of Ethernet PHYs which are linked to UCLASS_ETH device using "phy-handle" DT property and when Ethernet PHY driver needs to read some additional information from DT. In such cases following happens (in general): - network drivers priv->phydev = phy_connect(priv->bus, priv->phyaddr, dev, priv->interface); <-- phydev is connected to dev which is UCLASS_ETH device if (priv->phy_of_handle > 0) dev_set_of_offset(priv->phydev->dev, priv->phy_of_handle); <-- phydev->dev->node is overwritten by phy-handle DT node - PHY driver in .config() callback int node = dev_of_offset(dev); <-- PHY driver uses overwritten dev->node const void *fdt = gd->fdt_blob; if (fdtdec_get_bool(fdt, node, "property")) ... As result, UCLASS_ETH device can't be used any more for DT accessing. This patch adds additional ofnode node field to struct phy_device which can be set explicitly by network drivers and used by PHY drivers, so overwriting can be avoided. Also add helper function phy_get_ofnode() which will check and return phy_device->node or dev_ofnode(phydev->dev) for backward compatibility with existing drivers. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26phy: Break include cycleJoe Hershberger
Because some phy wants to export some functions [1], export.h was including the whole phy subsystem which pulls in lots of stuff that causes some ordering and redefinition issues. Split out the only part that is actually needed in export.h and include it there and in phy.h. [1] commit 95279315076c ("board/ls2085rdb: Export functions for standalone AQ FW load apps") Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-13net: include/phy.h: add new mode for internal phyKunihiko Hayashi
Add the new mode to indicate a built-in PHY. This will be used by UniPhier AVE ethernet driver. Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-13net/phy/cortina: Add support for CS4223 PHYVicentiu Galanopulo
Add support for Cortina CS4223 10G PHY - As per the CS4223 specs, an EEPROM module is connected to the PHY. At startup the PHY reads the firmware line and tries to load the firmware into the internal memory. - This driver reads the EEPROM status and checks if firmware has been loaded Signed-off-by: Vicentiu Galanopulo <vicentiu.galanopulo@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-15net: phy: Add Broadcom BCM53xx switch driverFlorian Fainelli
Add a minimalistic Broadcom BCM53xx (roboswitch) switch driver similar to the Marvell MV88E617x. This takes care of configuring the minimum amount out of the switch hardware such that each user visible port (configurable) and the CPU port can forward packets between each other while preserving isolation with other ports. This is useful for e.g: the Lamobo R1 board featuring a Broadcom BCM53125 switch. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-11-17net: phy: Add Amlogic Meson GXL Internal PHY supportNeil Armstrong
The Amlogic Meson GXL/GXM families embeds an internal RMII Ethernet PHY. The PHY acts as a generic PHY but needs a slight configuration right before it's configuration. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2017-08-07net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 driversAlexandru Gagniuc
The KS8721BL and KSZ9021 PHYs are software-incompatible, yet they share the same ID. Drivers for bothe PHYs cannot safely coexist, so the solution was to use #ifdefs to select between the two drivers. As a result KSZ9031, which has a unique ID, is now caught in the crossfire. Unless CONFIG_PHY_MICREL_KSZ9031 is defined, the KSZ9031 will not function properly, as some essential configuration code is ifdef'd-out. To prevent such situations, move the KSZ9000 drivers to a separate file, and place them under a separate Kconfig option. While it is possible to enable both KSZ8000 and KSZ9000 drivers at the same time, the assumption is that it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY, and that only one of the drivers will be enabled at any given time. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-04-04Merge git://www.denx.de/git/u-boot-marvellTom Rini
This includes Marvell mvpp2 patches with the ethernet support for the ARMv8 Armada 7k/8k platforms. The ethernet patches are all acked by Joe and he is okay with me pushing them via the Marvell tree.
2017-03-29net: include/phy.h: Add new PHY interface modesStefan Roese
This patch adds the new PHY interface modes XAUI, RXAUI and SFI that will be used by the PPv2.2 support in the Marvell mvpp2 ethernet driver. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefan Chulski <stefanc@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-26drivers/net/phy: add fixed-phy / fixed-link supportHannes Schmelzer
This patch adds support for having a "fixed-link" to some other MAC (like some embedded switch-device). For this purpose we introduce a new phy-driver, called "Fixed PHY". Fixed PHY works only with CONFIG_DM_ETH enabled, since the fixed-link is described with a subnode below ethernet interface. Most ethernet drivers (unfortunately not all are following same scheme for searching/attaching phys) are calling "phy_connect(...)" for getting a phy-device. At this point we link in, we search here for a subnode called "fixed- link", once found we start phy_device_create(...) with the special phy- id PHY_FIXED_ID (0xa5a55a5a). During init the "Fixed PHY" driver has registered with this id and now gets probed, during probe we get all the details about fixed-link out of dts, later on the phy reports this values. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-02-08net: phy: MSCC Add Support for VSC8530-VSC8531-VSC8540-VSC8541John Haechten
Signed-off-by: John Haechten <john.haechten@microsemi.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-24net: phy: Add phy_interface_is_sgmii to phy.hDan Murphy
Add a helper to phy.h to identify whether the phy is configured for SGMII all variables. Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-24net: phy: Move is_rgmii helper to phy.hDan Murphy
Move the phy_interface_is_rgmii to the phy.h file for all phy's to be able to use the API. This now aligns with the Linux kernel based on commit e463d88c36d42211aa72ed76d32fb8bf37820ef1 Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-24net: phy: Add PHY driver for mv88e61xx switchesKevin Smith
The previous mv88e61xx driver was a driver for configuring the switch, but did not integrate with the PHY/networking system, so it could not be used as a PHY by U-boot. This is a complete rework to support this device as a PHY. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-04-04phy: Add phy driver support for xilinx PCS/PMA coreSiva Durga Prasad Paladugu
Add phy driver support for xilinx PCS/PMA core Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Kedareswara rao Appana <appanad@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-28net: phy: introduce a quirk PHY_FLAG_BROKEN_RESETShaohui Xie
Current driver always performs a phy soft reset when connecting the phy device, but soft reset is not always supported by a phy device, so introduce a quirk PHY_FLAG_BROKEN_RESET to let such a phy device to skip soft reset. This commit uses 'flags' of phy device structure to store the quirk. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28drivers/net/phy: introduce phy_set_supported()Alexey Brodkin
This new function will allow MAC drivers to override supported capabilities of the phy. It is required when MAC cannot handle all speeds supported by phy. For example phy supports up-to 1Gb connections while MAC may only work in modes up to 100 or even 10 Mbit/sec. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28net: phy: breakdown PHY_*_FEATURES definesFlorian Fainelli
Breakdown the PHY_*_FEATURES into per speed defines such that we can easily re-use them individually. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-11-19net: phy: Add support for Texas Instruments DP83867Edgar E. Iglesias
Code is taken from Linux kernel driver (v4.2). Signed-off-by: Edgar E. Iglesias <edgar.iglesias@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-20net/phy: fixup for get_phy_idShengzhou Liu
commit 3c6928fd7b0f84 "net: phy: fix warnings with W=1" caused some PHYs(e.g. CS4315/CS4340) not working. This patch fixes the warning and make those special PHYs working as well. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2015-04-18dm: net: Adjust PHY interface to work with CONFIG_DM_ETHSimon Glass
When driver model is used for Ethernet a few functions are passed a udevice instead of an eth_device. Also add a function to find a PHY type given its name. This will be used to decode the device tree node. Finally, put a phy_interface field in struct eth_pdata since this is an important part of the platform data for Ethernet. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-16phylib: add support for aquantia PHYsShaohui Xie
This patch supports AQ1202, AQ2104, AQR105 PHY. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05net/phy: Add support for CS4315/CS4340 PHYShengzhou Liu
Add support for Cortina CS4315/CS4340 10G PHY. - This driver loads CS43xx firmware from NOR/NAND/SPI/SD device to initialize Cortina PHY. - Cortina PHY has non-standard offset of PHY ID registers, thus we define own get_phy_id() to override default get_phy_id(). - To define macro CONFIG_PHY_CORTINA will enable this driver. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-19net/fm: add 2.5G SGMII supportShengzhou Liu
As auto-negotiation is not supported for 2.5G SGMII, we need to add a new type PHY_INTERFACE_MODE_SGMII_2500 to differentiate SGMII-1G and SGMII-2.5G with different setting for auto-negotiation. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-23net: phy.h: Make PHY autonegotiation timeout configurableStefan Roese
The Marvell MV78460 eval board DB-78460-BP seems to need a longer PHY autonegotiation timeout than the "standard" 4 seconds. So lets make this timeout configurable. If not defined in the board config header the original 4000ms is used. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2014-08-06Change Andy Fleming's email addressAndy Fleming
Messages to afleming@freescale.com now bounce, and should be directed to my personal address at afleming@gmail.com Signed-off-by: Andy Fleming <afleming@gmail.com>
2014-03-05wandboard: Fix sparse warningFabio Estevam
Add a prototype for board_phy_config() to fix the following sparse warning: wandboard.c:200:5: warning: symbol 'board_phy_config' was not declared. Should it be static? Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-12-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-22net: add extended function to phy APIStefano Babic
Some phys (Micrel) has extended registers that must be accessed in a special way. Add pointers to the phy driver structure to allow to use these functions with mdio command. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-11-22phy: introduce structure fixed-linkShaohui Xie
fixed-link is used in kernel for PHY-less MAC, so introduce this structure that U-boot can use it to fixup dtb dynamically. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2013-06-24phy: export genphy_parse_link()Yegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-14net/phy: add VSC8574 supportShaohui Xie
The VSC8574 is a quad-port Gigabit Ethernet transceiver with four SerDes interfaces for quad-port dual media capability. This driver supports SGMII and QSGMII MAC mode. For now SGMII mode is tested. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
