path: root/include/pcmcia.h
2014-10-27ppc: Zap ICU862 boardMarek Vasut
This board is the only user of CONFIG_SYS_EEPROM_X40430 , remove it so the EEPROM command code can be cleansed of the related code as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2014-08-21powerpc: mpc8xx: remove svm_sc8xx boardMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove netta, netta2, netphone board supportMasahiro Yamada
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
2014-04-18powerpc: remove RPXClassic, RPXlite boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/RPXlite/* - Remove board/RPXClassic/* - Remove include/configs/RPXlite.h - Remove include/configs/RPXClassic.h - Clean-up defined(CONFIG_RPXCLASSIC) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove ADS860, FADS823, FADS850SAR, FADS860T supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove include/configs/{ADS860.h,FADS823.h,FADS850SAR.h,FADS860T.h} - Cleanup defined(CONFIG_ADS), defined(CONFIG_MPC823FADS), defined(CONFIG_MPC850SAR), defined(CONFIG_SYS_DAUGHTERBOARD) - Remove the entries from boards.cfg Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-03-26PXA: Remove PXA PCMCIA supportMarek Vasut
Say good bye to some ancient, very broken and unused code. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-05-18Add support for CompactFlash on ATC boardwdenk
(includes support for Intel 82365 and compatible PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers)
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
