path: root/include/pci.h
2015-08-05pci: Add a constant for an invalid interruptSimon Glass
Rather than using 0xff in the code, add a constant. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-03drivers/pci: Add function to find an extended capabilityMinghuan Lian
PCIe extends device's configuration space to 4k and provides extended capability. The patch adds function to find them. The code is ported from Linux PCIe driver. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-21dm: pci: Add a function to get the BDF for a deviceSimon Glass
It is useful to be able to find the full PCI address (bus, device and function) for a PCI device. Add a function to provide this. Adjust the existing code to use this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: pci: Add support for PCI driver matchingSimon Glass
At present all PCI devices must be present in the device tree in order to be used. Many or most PCI devices don't require any configuration other than that which is done automatically by U-Boot. It is inefficent to add a node with nothing but a compatible string in order to get a device working. Add a mechanism whereby PCI drivers can be declared along with the device parameters they support (vendor/device/class). When no suitable driver is found in the device tree the list of such devices is consulted to determine the correct driver. If this also fails, then a generic driver is used as before. The mechanism used is very similar to that provided by Linux and the header file defintions are copied from Linux 4.1. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-07-14pci: Configure expansion ROM during auto config processBin Meng
Currently PCI expansion ROM address is assigned by a call to pciauto_setup_rom() outside of the pci auto config process. This does not work when expansion ROM is on a device behind PCI bridge where bridge's memory limit register was already programmed to a value that does not cover the newly assigned expansion ROM address. To fix this, we should configure the ROM address during the auto config process. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14dm: pci: Use the correct hose when configuring devicesSimon Glass
Only the PCI controller has access to the PCI region information. Make sure to use the controller (rather than any attached bridges) when configuring devices. This corrects a failure to scan and configure devices when driver model is enabled for PCI. Also add a comment to explain the problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: sandbox: pci: Add a PCI emulation uclassSimon Glass
Since sandbox does not have real devices (unless it borrows those from the host) it must use emulations. Provide a uclass which permits PCI operations to be passed through to an emulation device. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Add a uclass for PCISimon Glass
Add a uclass for PCI controllers and a generic one for PCI devices. Adjust the 'pci' command and the existing PCI support to work with this new uclass. Keep most of the compatibility code in a separate file so that it can be removed one day. TODO: Add more header file comments to the new parts of pci.h Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Move common PCI functions into their own fileSimon Glass
Driver model will share many functions with the existing PCI implementation. Move these into their own file to avoid duplication and confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-05pci: Add a function to find a device by classSimon Glass
There is an existing function prototype in the header file but it is not implemented. Implement something similar. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-23x86: Access the VGA ROM when neededSimon Glass
Add code to the generic pci_rom file to access the VGA ROM in PCI space when needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-05powerpc: mpc824x: remove MPC824X cpu supportMasahiro Yamada
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Torsten Demke <torsten.demke@fci.com> Cc: Jim Thompson <jim@musenki.com> Cc: Greg Allen <gallen@arlut.utexas.edu>
2014-11-25pci: Add functions to read and write a BAR addressSimon Glass
Some PCI functions cannot be auto-configured. Add a function to set up a fixed BAR which can be used in these situations. Also add a function to read the current address of a BAR. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-23pci: Honour pci_skip_dev()Thierry Reding
When enumerating devices, honour the pci_skip_dev() function. This can be used by PCI controller drivers to restrict which devices will be probed. This is required by the NVIDIA Tegra PCIe controller driver, which will fail with a data abort exception if an access is attempted to a device number larger than 0 outside of bus 0. pci_skip_dev() is therefore implemented to prevent any such accesses. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09pci: add support for board_pci_fixup_dev functionTim Harvey
Some board-level drivers may wish to have per-device fixup functions for PCI devices. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2013-11-09pci.h: allow inclusion in assembly sourcePaul Burton
This patch simply #ifdef's out the C-specific parts of pci.h when it is included by an assembly file. This will allow the macros it contains to be used from assembly source as will be done in a followup commit adding support for more modern MIPS Malta boards. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-10-16PCIe:change the method to get the address of a requested capability in ↵Zhao Qiang
configuration space. Previously, the address of a requested capability is define like that "#define PCI_DCR 0x78" But, the addresses of capabilities is different with regard to PCIe revs. So this method is not flexible. Now a function to get the address of a requested capability is added and used. It can get the address dynamically by capability ID. The step of this function: 1. Read Status register in PCIe configuration space to confirm that Capabilities List is valid. 2. Find the address of Capabilities Pointer Register. 3. Find the address of requested capability from the first capability. Signed-off-by: Zhao Qiang <B45475@freescale.com>
2013-08-09powerpc/pcie: add PCIe version 3.x supportZang Roy-R61911
T4240 PCIe IP is version 3.0 and has some update comparing previous QorIQ products. 1. Move Freescale specific register define to arch/powerpc/include/asm/fsl_pci.h and update the register offset define for T4240. 2. add the status/control register define use status/control register to judge the link status 3. The original code uses 'Programming Interface' field to judge if PCIE is EP or RC mode, however, T4240 does not support this functionality. According to PCIE specification, 'Header Type' offset 0x0e is used to indicate header type, so for PCIE controller, the patch changes code to use 'Header Type' field to identify if the PCIE is RC or EP mode. This patch fixes the PCIe card link up issue on T4240QDS. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2013-06-26pci: Convert extern inline functions to static inlineSimon Glass
I am not sure of the meaning of extern inline, but this gives errors when building with function instrumenting enabled. Change these functions to static inline. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-12-06x86: gpio: Add GPIO driver for Intel ICH6 and later.Bill Richardson
Implement <asm-generic/gpio.h> functions for Intel ICH6 and later. Only GPIOs 0-31 are handled by this code. Signed-off-by: Bill Richardson <wfrichar@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-30pci: declare pciauto functions in headerLinus Walleij
The FSL PCI driver uses local prototypes for pciauto_[pre|post]scan_setup_bridge(), this does not seem right, so move them to the <pci.h> file. Fixed a small extern declaration too, this is harmless but distracts the view since all other prototypes are explicitly external. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-04pci: move pciauto_config_init() to pci.hLinus Walleij
Fixing build regressions for the Integrator I get find that a few boards try to work around the missing declaration of pciauto_config_init() by declaring it in the local scope. This does not make sense when the sibling functions are in <pci.h> so move the function to the header, ridding the build error in the Integrator and getting rid of the local declarations here and there. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-29powerpc/85xx: Handle PCIe initialization requires for P1021 class SoCsPrabhakar Kushwaha
The P1011, P1012, P1015, P1016, P1020, P1021, P1024, & P1025 SoCs require that we initialize the SERDES registers if the lanes are configured for PCIe. Additionally these devices PCIe controller do not support ASPM and we have to explicitly disable it. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-05mpc83xx: fix pcie configuration space read/writeLeo Liu
This patch fix a problem for the pcie enumeration when the mpc83xx pcie controller is connected with switch or we use both of the two pcie controller. Signed-off-by: Leo Liu <liucai.lfn@gmail.com> fix codingstyle and compiler warning: 'pcie_priv' defined but not used Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-01-14powerpc/fsl-pci: Determine pci_controller based on cfg addr for dts fixupKumar Gala
Previously we passed in a specifically named struct pci_controller to determine if we had setup the particular PCI bus. Now we can search for the struct so we dont have to depend on the name or the struct being statically allocated. Introduced new find_hose_by_cfg_addr() to get back a pci_controller struct back by searching for it means we can do things like dynamically allocate them or not have to expose the static structures to all users. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-11-14pci: Clean up PCI info when CONFIG_PCI_SCAN_SHOWPeter Tyser
This change does the following: - Removes the printing of the PCI interrupt line value. This is normally set to 0 by U-Boot on bootup and is rarely used during everyday operation. - Prints out the PCI function number of a device. Previously a device with multiple functions would be printed identically 2 times, which is generally confusing. For example, on an Intel 2 port gigabit Ethernet card the following was displayed: ... 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 ... - Prints a text description of each device's PCI class instead of the raw PCI class code. The textual description makes it much easier to determine what devices are installed on a PCI bus. - Changes the general formatting of the PCI device output. Previous output: PCIE1: connected as Root Complex 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d Updated output: PCIE1: connected as Root Complex 04:01.0 - 8086:1010 - Network controller 04:01.1 - 8086:1010 - Network controller 03:00.0 - 10b5:8112 - Bridge device 02:01.0 - 10b5:8518 - Bridge device 02:02.0 - 10b5:8518 - Bridge device 08:00.0 - 1957:0040 - Processor 07:00.0 - 10b5:8518 - Bridge device 09:00.0 - 10b5:8112 - Bridge device 07:01.0 - 10b5:8518 - Bridge device 07:02.0 - 10b5:8518 - Bridge device 06:00.0 - 10b5:8518 - Bridge device 02:03.0 - 10b5:8518 - Bridge device 01:00.0 - 10b5:8518 - Bridge device PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex 0d:00.0 - 1957:0040 - Processor PCIE2: Bus 0c - 0d Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-28pci/fsl_pci_init: Use PCIe capability to determine if controller is PCIeKumar Gala
Change the code to use the PCIe capabilities register to determine if we are a PCIe controller or not. Additionally cleaned up some white space and formatting in the file. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-23PCI: Add pci_last_busno() helperAnton Vorontsov
This is just a handy routine that reports last PCI busno: we walk down all the hoses and return last hose's last_busno. Will be used by PCI/PCIe initialization code. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-10drivers/pci: Create pci_map_bar functionBecky Bruce
It is no longer always true that the pci bus address can be used as the virtual address for pci accesses. pci_map_bar() is created to return the virtual address for a pci region. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-21mpc83xx: Add support for MPC83xx PCI-E controllersAnton Vorontsov
This patch adds support for MPC83xx PCI-E controllers in Root Complex mode. The patch is based on Tony Li and Dave Liu work[1]. Though unlike the original patch, by default we don't register PCI-E buses for use in U-Boot, we only configure the controllers for future use in other OSes (Linux). This is done because we don't have enough of spare BATs to map all the PCI-E regions. To actually use PCI-E in U-Boot, users should explicitly define CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES symbol in the board file. And only then U-Boot will able to access PCI-E, but at the cost of disabled address translation. [1] http://lists.denx.de/pipermail/u-boot/2008-January/027630.html Signed-off-by: Tony Li <tony.li@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-24pci: Allow for PCI addresses to be 64-bitKumar Gala
PCI bus is inherently 64-bit. While not all system require access to the full 64-bit PCI address range some do. This allows those systems to enable the full PCI address width via CONFIG_SYS_PCI_64BIT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com> Acked-by: Wolfgang Denk <wd@denx.de>
2008-05-10Update pci code to use phys_addr_tBecky Bruce
Physical addrs need to be represented by phys_addr_t, not unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT are going to fail mightily. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2007-08-06Make MPC8641's PCI/PCI-E driver a common driver for many FSL parts.Ed Swarthout
All of the PCI/PCI-Express driver and initialization code that was in the MPC8641HPCN port has now been moved into the common drivers/fsl_pci_init.c. In a subsequent patch, this will be utilized by the 85xx ports as well. Common PCI-E IMMAP register blocks for FSL 85xx/86xx are added. Also enable the second PCI-Express controller on 8641 by getting its BATS and CFG_ setup right. Fixed a u16 vendor compiler warning in AHCI driver too. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-19* Fix a bunch of compiler warnings for gcc 4.0Jon Loeliger
Signed-off-by: Matthew McClintock <msm@freescale.com>
2006-08-09* Added PCI-X #defines for PCI-X initialization Patch by Andy Fleming on ↵Matthew McClintock
17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-03-12Merge with git://git.kernel.org/pub/scm/boot/u-boot/u-boot.git#pciWolfgang Denk
2006-03-12Fix bad declaration on pci_cfgfunc_nothingWolfgang Denk
Patch by Sam Song, 19 Jun 2005
2006-01-11Added support for PCI prefetchable region and BARsKumar Gala
If a host controller sets up a region as prefetchable and a device's BAR denotes it as prefetchable, allocate the BAR into the prefetch region. If a BAR is prefetchable and no prefetchable region has been setup by the controller we fall back to allocating the BAR into the normally memory region. Patch by Kumar Gala 11 Jan 2006
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
