path: root/include/pci.h
2006-10-19* Fix a bunch of compiler warnings for gcc 4.0Jon Loeliger
Signed-off-by: Matthew McClintock <msm@freescale.com>
2006-08-09* Added PCI-X #defines for PCI-X initialization Patch by Andy Fleming on ā†µMatthew McClintock
17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-03-12Merge with git://git.kernel.org/pub/scm/boot/u-boot/u-boot.git#pciWolfgang Denk
2006-03-12Fix bad declaration on pci_cfgfunc_nothingWolfgang Denk
Patch by Sam Song, 19 Jun 2005
2006-01-11Added support for PCI prefetchable region and BARsKumar Gala
If a host controller sets up a region as prefetchable and a device's BAR denotes it as prefetchable, allocate the BAR into the prefetch region. If a BAR is prefetchable and no prefetchable region has been setup by the controller we fall back to allocating the BAR into the normally memory region. Patch by Kumar Gala 11 Jan 2006
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
