When enumerating devices, honour the pci_skip_dev() function. This can
be used by PCI controller drivers to restrict which devices will be
probed.
This is required by the NVIDIA Tegra PCIe controller driver, which will
fail with a data abort exception if an access is attempted to a device
number larger than 0 outside of bus 0. pci_skip_dev() is therefore
implemented to prevent any such accesses.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Some board-level drivers may wish to have per-device fixup functions
for PCI devices.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
This patch simply #ifdef's out the C-specific parts of pci.h when it is
included by an assembly file. This will allow the macros it contains to
be used from assembly source as will be done in a followup commit adding
support for more modern MIPS Malta boards.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
configuration space.
Previously, the address of a requested capability is define like that
"#define PCI_DCR 0x78"
But, the addresses of capabilities is different with regard to PCIe revs.
So this method is not flexible.
Now a function to get the address of a requested capability is added and used.
It can get the address dynamically by capability ID.
The step of this function:
1. Read Status register in PCIe configuration space to confirm that
Capabilities List is valid.
2. Find the address of Capabilities Pointer Register.
3. Find the address of requested capability from the first capability.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
T4240 PCIe IP is version 3.0 and has some update comparing previous
QorIQ products.
1. Move Freescale specific register define
to
arch/powerpc/include/asm/fsl_pci.h
and update the register offset define for T4240.
2. add the status/control register define
use status/control register to judge the link status
3. The original code uses 'Programming Interface' field to judge if PCIE is
EP or RC mode, however, T4240 does not support this functionality.
According to PCIE specification, 'Header Type' offset 0x0e is used to
indicate header type, so for PCIE controller, the patch changes code to
use 'Header Type' field to identify if the PCIE is RC or EP mode.
This patch fixes the PCIe card link up issue on T4240QDS.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
[trini: Fixup common/cmd_io.c]
I am not sure of the meaning of extern inline, but this gives errors
when building with function instrumenting enabled. Change these functions
to static inline.
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Implement <asm-generic/gpio.h> functions for Intel ICH6 and later.
Only GPIOs 0-31 are handled by this code.
Signed-off-by: Bill Richardson <wfrichar@chromium.org>
The FSL PCI driver uses local prototypes for
pciauto_[pre|post]scan_setup_bridge(), this does not seem right,
so move them to the <pci.h> file.
Fixed a small extern declaration too, this is harmless but distracts
the view since all other prototypes are explicitly external.
Fixing build regressions for the Integrator I get find that a few
boards try to work around the missing declaration of
pciauto_config_init() by declaring it in the local scope. This
does not make sense when the sibling functions are in <pci.h>
so move the function to the header, ridding the build error
in the Integrator and getting rid of the local declarations
here and there.
Reported-by: Wolfgang Denk <wd@denx.de>
The P1011, P1012, P1015, P1016, P1020, P1021, P1024, & P1025 SoCs require
that we initialize the SERDES registers if the lanes are configured for
PCIe. Additionally these devices PCIe controller do not support ASPM
and we have to explicitly disable it.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
This patch fix a problem for the pcie enumeration when the mpc83xx
pcie controller is connected with switch or we use both of the two
pcie controller.
Signed-off-by: Leo Liu <liucai.lfn@gmail.com>
fix codingstyle and compiler warning: 'pcie_priv' defined but not used
Previously we passed in a specifically named struct pci_controller to
determine if we had setup the particular PCI bus. Now we can search for
the struct so we dont have to depend on the name or the struct being
statically allocated.
Introduced new find_hose_by_cfg_addr() to get back a pci_controller struct
back by searching for it means we can do things like dynamically allocate
them or not have to expose the static structures to all users.
Acked-by: Wolfgang Denk <wd@denx.de>
This change does the following:
- Removes the printing of the PCI interrupt line value. This is
normally set to 0 by U-Boot on bootup and is rarely used during
everyday operation.
- Prints out the PCI function number of a device. Previously a device
with multiple functions would be printed identically 2 times, which is
generally confusing. For example, on an Intel 2 port gigabit Ethernet
card the following was displayed:
04 01 8086 1010 0200 00
- Prints a text description of each device's PCI class instead of the
raw PCI class code. The textual description makes it much easier to
determine what devices are installed on a PCI bus.
- Changes the general formatting of the PCI device output.
Previous output:
PCIE1: connected as Root Complex
03 00 10b5 8112 0604 00
02 01 10b5 8518 0604 00
02 02 10b5 8518 0604 00
08 00 1957 0040 0b20 00
07 00 10b5 8518 0604 00
09 00 10b5 8112 0604 00
07 01 10b5 8518 0604 00
07 02 10b5 8518 0604 00
06 00 10b5 8518 0604 00
02 03 10b5 8518 0604 00
01 00 10b5 8518 0604 00
PCIE1: Bus 00 - 0b
PCIE2: connected as Root Complex
0d 00 1957 0040 0b20 00
PCIE2: Bus 0c - 0d
Updated output:
04:01.0 - 8086:1010 - Network controller
04:01.1 - 8086:1010 - Network controller
03:00.0 - 10b5:8112 - Bridge device
02:01.0 - 10b5:8518 - Bridge device
02:02.0 - 10b5:8518 - Bridge device
08:00.0 - 1957:0040 - Processor
07:00.0 - 10b5:8518 - Bridge device
09:00.0 - 10b5:8112 - Bridge device
07:01.0 - 10b5:8518 - Bridge device
07:02.0 - 10b5:8518 - Bridge device
06:00.0 - 10b5:8518 - Bridge device
02:03.0 - 10b5:8518 - Bridge device
01:00.0 - 10b5:8518 - Bridge device
PCIE1: Bus 00 - 0b
0d:00.0 - 1957:0040 - Processor
PCIE2: Bus 0c - 0d
Change the code to use the PCIe capabilities register to determine if we
are a PCIe controller or not. Additionally cleaned up some white space
and formatting in the file.
This is just a handy routine that reports last PCI busno: we walk
down all the hoses and return last hose's last_busno.
Will be used by PCI/PCIe initialization code.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
It is no longer always true that the pci bus address can be
used as the virtual address for pci accesses. pci_map_bar()
is created to return the virtual address for a pci region.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
This patch adds support for MPC83xx PCI-E controllers in Root Complex
mode.
The patch is based on Tony Li and Dave Liu work[1].
Though unlike the original patch, by default we don't register PCI-E
buses for use in U-Boot, we only configure the controllers for future
use in other OSes (Linux). This is done because we don't have enough
of spare BATs to map all the PCI-E regions.
To actually use PCI-E in U-Boot, users should explicitly define
CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES symbol in the board file. And
only then U-Boot will able to access PCI-E, but at the cost of disabled
address translation.
[1] http://lists.denx.de/pipermail/u-boot/2008-January/027630.html
Signed-off-by: Tony Li <tony.li@freescale.com>
Acked-by: Dave Liu <daveliu@freescale.com>
PCI bus is inherently 64-bit. While not all system require access to
the full 64-bit PCI address range some do. This allows those systems
to enable the full PCI address width via CONFIG_SYS_PCI_64BIT.
Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
Physical addrs need to be represented by phys_addr_t, not
unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT
are going to fail mightily.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
All of the PCI/PCI-Express driver and initialization code that
was in the MPC8641HPCN port has now been moved into the common
drivers/fsl_pci_init.c. In a subsequent patch, this will be
utilized by the 85xx ports as well.
Common PCI-E IMMAP register blocks for FSL 85xx/86xx are added.
Also enable the second PCI-Express controller on 8641
by getting its BATS and CFG_ setup right.
Fixed a u16 vendor compiler warning in AHCI driver too.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
Signed-off-by: Matthew McClintock <msm@freescale.com>
17-Mar-2006
Signed-off-by: Andy Fleming <afleming@freescale.com>
Patch by Sam Song, 19 Jun 2005
If a host controller sets up a region as prefetchable and
a device's BAR denotes it as prefetchable, allocate the
BAR into the prefetch region.
If a BAR is prefetchable and no prefetchable region has
been setup by the controller we fall back to allocating
the BAR into the normally memory region.
Patch by Kumar Gala 11 Jan 2006
Patch by Steven Blakeslee, 27 Jul 2005
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
