path: root/include/pch.h
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-05-08x86: pch: Add an ioctl to read power-management infoSimon Glass
Add a new ioctl() request to read information about the power-management system. This can be used to power off the device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: ivybridge: Add a way to get the HDA config settingSimon Glass
Add a way check to whether HD audio is enabled. Use ioctl() to avoid adding too many unusual operations to PCH. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20pch: Add ioctl supportSimon Glass
At present the PCH has 4 operations and these are reasonably widely used in the drivers. But sometimes we want to add rarely used operations, and each of these currently adds to the size of the PCH operations table. Add an ioctl() method which can be easily expanded without any more impact on the operations table. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-05dm: pch: Add get_io_base opBin Meng
On some newer chipset (eg: BayTrail), there is an IO base address register on the PCH device which configures the base address of a memory-mapped I/O controller. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Add get_gpio_base opBin Meng
x86 GPIO registers are accessed via I/O port whose base address is configured in a PCI configuration register on the PCH device. Add an op get_gpio_base to get the GPIO base address from PCH. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Rename get_sbase op to get_spi_baseBin Meng
Spell out 'sbase' to 'spi_base' so that it looks clearer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Remove pch_get_version opBin Meng
pch_get_version op was only used by the ich spi controller driver, and does not really provide a good identification of pch controller so far, since we see plenty of Intel PCH chipsets and one differs from another a lot, which is not simply either a PCHV_7 or PCHV_9. Now that ich spi controller driver was updated to not get such info from pch, the pch_get_version op is useless now. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-01-24dm: x86: Add a driver for Intel PCH7Simon Glass
At some point we may need to distinguish between different types of PCHs, but for existing supported platforms we only need to worry about version 7 and version 9 bridges. Add a driver for the PCH7. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: Expand the uclass for Platform Controller Hubs (PCH)Simon Glass
A Platform Controller Hub is an Intel concept - it is like the peripherals on an SoC and is often in a separate chip from the CPU. The chip is typically found on the first PCI bus and integrates multiple devices. We have a very simple uclass to support PCHs. Add a few operations, such as setting up the devices on the PCH and finding the SPI controller base address. Also move it into drivers/pch/ since we will be adding a few PCH drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
