path: root/include/part_efi.h
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2013-05-01disk/gpt: Fix GPT partition handling for blocksize != 512Egbert Eich
Disks beyond 2T in size use blocksizes of 4096 bytes. However a lot of code in u-boot still assumes a 512 byte blocksize. This patch fixes the handling of GPTs. Signed-off-by: Egbert Eich <eich@suse.com>
2012-12-13gpt: The leXX_to_int() calls replaced with ones defined at <compiler.h>Chang Hyun Park
Custom definitions of le_XX_to_int functions have been replaced with standard ones, defined at <compiler.h> Replacement of several GPT related structures members with ones indicating its endianness and proper size. Signed-off-by: Chang Hyun Park <heartinpiece@outlook.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-13part:efi: Move part_efi.h file to ./includeLukasz Majewski
This move is necessary to export gpt header and GPT partition entries to be used with other commands or subsystems. Additionally the part_efi.h file has been cleaned-up to supress checkpatch's warnings. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
