path: root/include/part.h
2012-09-25disk: part_efi: parse and store partition UUIDStephen Warren
Each EFI partition table entry contains a UUID. Extend U-Boot's struct disk_partition to be able to store this information, and modify get_partition_info_efi() to fill it in. The implementation of uuid_string() was derived from the Linux kernel, tag v3.6-rc4 file lib/vsprintf.c function uuid_string(). Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: get_device_and_partition() "auto" partition and cleanupStephen Warren
Rework get_device_and_partition() to: a) Implement a new partition ID of "auto", which requests that U-Boot search for the first "bootable" partition, and fall back to the first valid partition if none is found. This way, users don't need to specify an explicit partition in their commands. b) Make use of get_device(). c) Add parameter to indicate whether returning a whole device is acceptable, or whether a partition is mandatory. d) Make error-checking of the user's device-/partition-specification more complete. In particular, if strtoul() doesn't convert all characters, it's an error rather than just ignored. The resultant device/partition returned by the function will be as follows, based on whether the disk has a partition table (ptable) or not, and whether the calling command allows the whole device to be returned or not. (D and P are integers, P >= 1) D D: No ptable: !allow_whole_dev: error allow_whole_dev: device D ptable: device D partition 1 D:0 !allow_whole_dev: error allow_whole_dev: device D D:P No ptable: error ptable: device D partition P D:auto No ptable: !allow_whole_dev: error allow_whole_dev: device D ptable: first partition in device D with bootable flag set. If none, first valid paratition in device D. Note: In order to review this patch, it's probably easiest to simply look at the file contents post-application, rather than reading the patch itself. Signed-off-by: Rob Herring <rob.herring@calxeda.com> [swarren: Rob implemented scanning for bootable partitions. I fixed a couple of issues there, switched the syntax to ":auto", added the error-checking rework, and ":0" syntax for the whole device] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk: introduce get_device()Stephen Warren
This patch introduces function get_device(). This looks up a block_dev_desc_t from an interface name (e.g. mmc) and device number (e.g. 0). This function is essentially the non-partition-specific prefix of get_device_and_partition(). Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25disk/part: introduce get_device_and_partitionRob Herring
All block device related commands (scsiboot, fatload, ext2ls, etc.) have simliar duplicated device and partition parsing and selection code. This adds a common function to replace various implementations. The new function has an enhancement over current versions. If no device or partition is specified on the command line, the bootdevice env variable will be used (scsiboot does this). Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-25disk/part: check bootable flag for DOS partitionsRob Herring
Determine which partitions are bootable/active. In the partition listing, print "Boot" for partitions with the bootable/active flag set. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-05-22include/part.h: fix indentation of lbaAnatolij Gustschin
Indent at the same level as other struct members. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-15MMC: add erase function to both mmc and sdLei Wen
Erase is a very basic function since the begin of sd specification is announced. Although we could write a bulk of full 0xff memory to the range to take place of erase, it is more convenient and safe to implement the erase function itself. Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2008-10-18Add support for CONFIG_EFI_PARTITION (GUID Partition Table)richardretanubun
The GUID (Globally Unique Identifier) Partition Table (GPT) is a part of EFI. See http://en.wikipedia.org/wiki/GUID_Partition_Table Based on linux/fs/partitions/efi.[ch] Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2008-03-27Coding style cleanup, update CHANGELOGWolfgang Denk
2008-03-26ata: add the support for SATA frameworkDave Liu
- add the SATA framework - add the SATA command line Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-02-03MMC for PXA 27X (resubmit)stefano babic
MMC support for X_Scale PXA is broken and does not work. Mainly, the mmc_init() function cannot recognize current SD/MMC cards. There were already some patches around the world but none of them was merged into the official u-boot tree. This patch makes order fixing this issue. Resubmit after code cleanup. Applied and tested on PXA 270 (TrizepsIV module). Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-10-23fix pxa255_idp boardMarcel Ziswiler
The pxa255_idp being an old unmaintained board showed several issues: 1. CONFIG_INIT_CRITICAL was still defined. 2. Neither CONFIG_MAC_PARTITION nor CONFIG_DOS_PARTITION was defined. 3. Symbol flash_addr was undeclared. 4. The boards lowlevel_init function was still called memsetup. 5. The TEXT_BASE was still 0xa3000000 rather than 0xa3080000. 6. Using -march=armv5 instead of -march=armv5te resulted in lots of 'target CPU does not support interworking' warnings on recent compilers. 7. The PXA's serial driver redefined FFUART, BTUART and STUART used as indexes rather than the register definitions from the pxa-regs header file. Renamed them to FFUART_INDEX, BTUART_INDEX and STUART_INDEX to avoid any ambiguities. 8. There were several redefinition warnings concerning ICMR, OSMR3, OSCR, OWER, OIER, RCSR and CCCR in the PXA's assembly start file. 9. The board configuration file was rather outdated. 10. The part header file defined the vendor, product and revision arrays as unsigned chars instead of just chars in the block_dev_desc_t structure. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-02-20[PATCH 9_9] Use "void *" not "unsigned long *" for block dev read_write ↵Grant Likely
buffer pointers Block device read/write is anonymous data; there is no need to use a typed pointer. void * is fine. Also add a hook for block_read functions Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 8_9] Add block_write hook to block_dev_desc_tGrant Likely
Preparation for future patches which support block device writing Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-03-17Patch by Pierre Aubert, 15 Mar 2004:wdenk
Fix buffer overflow in IDE identification
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2002-03-08Initial revisionwdenk
