path: root/include/panel.h
2018-10-09panel: Expand the backlight supportSimon Glass
At present the panel can be turned on but not off, and the brightness cannot be controlled at run-time. Add a new API function to both the panel and backlight uclasses to handle this. Enhance the PWM backlight driver to deal with custom levels properly and allow the backlight to be turned on and off. Update the test to cover thes new features. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-08-01dm: panel: get timings from panelYannick Fertré
Get timings from panel instead of read device tree. Signed-off-by: Yannick Fertré <yannick.fertre@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: panel: Add a panel uclassSimon Glass
LCD panels can usefully be modelled as their own uclass. They can be probed (which powers them up ready for use). If they have a backlight, this can be enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
