path: root/include/os.h
2014-03-17sandbox: Allow Ctrl-C to work in sandboxSimon Glass
It is useful for Cltl-C to be handled by U-Boot as it is on other boards. But it is also useful to be able to terminate U-Boot with Ctrl-C. Add an option to enable signals while in raw mode, and make this the default. Add an option to leave the terminal cooked, which is useful for redirecting output. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add os_jump_to_image() to run another executableSimon Glass
For some tests it is useful to be able to run U-Boot again but pass on the same memory contents. Add a function to achieve this. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-07unit-test: make "test -e" test independent of $CWDStephen Warren
The unit-test for hush's "test -e" currently relies upon being run in the U-Boot build directory, because it tests for the existence of a file that exists in that directory. Fix this by explicitly creating the file we use for the existence test, and deleting it afterwards so that multiple successive unit-test invocations succeed. This required adding an os.c function to erase files. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-01-24sandbox: fix the return type of os_free() functionMasahiro Yamada
The function os_free() returns nothing. Its return type should be "void" rather than "void *". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-08sandbox: Allow reading/writing of RAM bufferSimon Glass
It is useful to be able to save and restore the RAM contents of sandbox U-Boot either for setting up tests, for later analysys, or for chaining together multiple tests which need to keep the same memory contents. Add a function to provide a memory file for U-Boot. This is read on start-up and written when shutting down. If the file does not exist on start-up, it will be created when shutting down. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Allow the console to work earlierSimon Glass
With sandbox, errors and problems may be reported before console_init_f() is executed. For example, an argument may not parse correctly or U-Boot may panic(). At present this output is swallowed so there is no indication what is going wrong. Adjust the console to deal with a very early sandbox setup, by detecting that there is no global_data yet, and calling os functions in that case. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Improve/augment memory allocation functionsSimon Glass
Implement realloc() and free() for sandbox, by adding a header to each block which contains the block size. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
2013-11-21sandbox: Use uint64_t instead of u64 for timeSimon Glass
The uint64_t type is defined in linux/types.h, so is safer than u64, which is not actually a Linux type. Change-Id: Ifc9a369e6543250c49117b8d3cb3a676eee43e04 Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-04sandbox: Add a way of obtaining directory listingsSimon Glass
This implementation uses opendir()/readdir() to access the directory information and then puts it in a linked list for the caller's use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-28sandbox: Improve sandbox serial port keyboard interfaceTaylor Hutt
Implements the tstc() interface for the serial driver. Multiplexing the console between the serial port and a keyboard uses a polling method of checking if characters are available; this means that the serial console must be non-blocking when attempting to read characters. Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-12sandbox: mark os_exit as noreturnMike Frysinger
2012-03-12sandbox: add getopt supportSimon Glass
This adds simple command-line parsing to sandbox. The idea is that it sets up the state with options provided, and this state can then be queried later, as needed. New flags are declared with the SB_CMDLINE_OPT_SHORT helper macro, pointers are automatically gathered up in a special section, and then the core code takes care of gathering them up and processing at runtime. This way there is no central place where we have to store a list of flags with ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add flags for open() callSimon Glass
This provides a way for callers to create files for writing. The flags are translated at runtime, for the ones we support. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add lseek helperMike Frysinger
Follow up patches want to be able to seek fd's. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add ifdef protection to os.hMike Frysinger
2011-12-10sandbox: Add timer simulationMatthias Weisser
Making sleep command work Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add improved RAM simulationMatthias Weisser
Using mmap to allocate memory from the OS for RAM simulation we can use u-boot own malloc implementation. Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-03sandbox: put stdin into raw modeMike Frysinger
This allows us to act like a serial device: we get tab chars and CTRL+C and respond appropriately. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add OS dependent layerSimon Glass
We want to keep all OS-dependent code in once place, with a simple interface to U-Boot. For now, this is that place. Signed-off-by: Simon Glass <sjg@chromium.org>
