path: root/include/opensbi.h
2019-12-10spl: opensbi: specify main hart as preferred boot hartLukas Auer
OpenSBI uses a relocation lottery to determine the hart to relocate OpenSBI to its link address. In the U-Boot SPL boot flow, the main hart schedules the secondary harts to enter OpenSBI before doing so itself. One of the secondary harts will therefore always be the winner of the relocation lottery. This is problematic if the link address ranges of OpenSBI and U-Boot SPL overlap. OpenSBI will be relocated and therefore overwrite U-Boot SPL while some harts may still run it, leading to code corruption. Avoid this problem by specifying the main hart as the preferred boot hart to perform the OpenSBI relocation. The main hart will be the last hart to enter OpenSBI, relocation can therefore occur safely. The boot hart field was added to version 2 of the OpenSBI FW_DYNAMIC info structure. The header file include/opensbi.h is synchronized with include/sbi/fw_dynamic.h from the OpenSBI project to update the info structure. The header file is recent as of commit 7a13beb21326 ("firmware: Add preferred boot HART field in struct fw_dynamic_info"). Reported-by: Rick Chen <rick@andestech.com> Suggested-by: Anup Patel <Anup.Patel@wdc.com> Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Rick Chen <rick@andestech.com> Tested-by: Rick Chen <rick@andestech.com> Reviewed-by: Anup Patel <anup.patel@wdc.com>
2019-08-26spl: support booting via RISC-V OpenSBILukas Auer
RISC-V OpenSBI is an open-source implementation of the RISC-V Supervisor Binary Interface (SBI) specification. It is required by Linux and U-Boot running in supervisor mode. This patch adds support for booting via the OpenSBI FW_DYNAMIC firmware. It supports OpenSBI version 0.4 and higher. In this configuration, U-Boot SPL starts in machine mode. After loading OpenSBI and U-Boot proper, it will start OpenSBI. All necessary parameters are generated by U-Boot SPL and are passed to OpenSBI. U-Boot proper is started in supervisor mode by OpenSBI. Support for OpenSBI is enabled with CONFIG_SPL_OPENSBI. An additional configuration entry, CONFIG_SPL_OPENSBI_LOAD_ADDR, is used to specify the load address of the OpenSBI firmware binary. It is not used directly in U-Boot and instead is intended to make the value available to scripts such as FIT configuration generators. The header file include/opensbi.h is based on header files from the OpenSBI project. They are recent, as of commit bae54f764570 ("firmware: Add fw_dynamic firmware"). Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com>
