path: root/include/of_live.h
2017-06-01dm: Add a function to create a 'live' device treeSimon Glass
This function converts the flat device tree into a hierarchical one with C structures and pointers. This is easier to access. Signed-off-by: Simon Glass <sjg@chromium.org>
