path: root/include/netdev.h
2015-01-21net: gem: Use phys_addr_t instead of int for addressesMichal Simek
Use phys_addr_t for physical address declaration. It is also unsigned type instead of sign. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-10-23net: mvneta.c: Add support for the ethernet controller of the Marvell Armada ↵Stefan Roese
XP SoC This patch adds support for the NETA ethernet controller which is integrated in the Marvell Armada XP SoC's. This port is based on the Linux driver which has been stripped of the in U-Boot unused portions. Tested on the Marvell MV78460 eval board db-78460-bp. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Tested-by: Luka Perkov <luka@openwrt.org>
2014-08-30arm: bcm281xx: net: Add Ethernet DriverJiandong Zheng
The Broadcom StarFighter2 Ethernet driver is used in multiple Broadcom SoC(s) and: - supports multiple MAC blocks, - provides support for the Broadcom GMAC. This driver requires MII and PHYLIB. Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-21drivers: net: remove dead driversMasahiro Yamada
The following configs are not defined at all: - CONFIG_INCA_IP_SWITCH - CONFIG_PBL2800_ETHER - CONFIG_PHY_ICPLUS Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-06net: Rename and cleanup sunxi (Allwinner) emac driverStefan Roese
There have been 3 versions of the sunxi_emac support patch during its development. Somehow version 2 ended up in upstream u-boot where as the u-boot-sunxi git repo got version 3. This bumps the version in upstream u-boot to version 3 of the patch: - Initialize MII clock earlier so mii access to allow independent use - Name change from WEMAC to EMAC to match mainline kernel & chip manual - Cosmetic code cleanup Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-05-25sunxi: add gmac Ethernet supportIan Campbell
Add support for the GMAC Ethernet controller on Allwinner A20 (sun7i) processors. Enable for the Cubietruck. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-04-20MIPS: drop incaip boardDaniel Schwierzeck
This is dead hardware and no one is interested in making the necessary changes for upcoming features like generic board or driver model. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Wolfgang Denk <wd@denx.de>
2014-03-04net: gem: Add OF initialization supportMichal Simek
Gem can be directly initialized from DTB. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04net: emaclite: Fix OF initializationMichal Simek
- Add xilinx_emaclite_of_init to netdev.h - Remove global data pointer from the driver - Add better handling for error state. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2013-06-24net: add Faraday FTMAC110 10/100Mbps ethernet supportKuo-Jung Su
Faraday FTMAC110 10/100Mbps supports half-word data transfer for Linux. However it has a weird DMA alignment issue: (1) Tx DMA Buffer Address: 1 bytes aligned: Invalid 2 bytes aligned: O.K 4 bytes aligned: O.K (2) Rx DMA Buffer Address: 1 bytes aligned: Invalid 2 bytes aligned: O.K 4 bytes aligned: Invalid!!! Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Tom Rini <trini@ti.com>
2013-06-24net: ks8851_mll: add ethernet supportRoberto Cerati
The device interface is 16 bits wide. All the available packets are read from the incoming fifo. Signed-off-by: Roberto Cerati <roberto.cerati@bticino.it> Signed-off-by: Raffaele Recalcati <raffaele.recalcati@bticino.it> [voice.shen@atmel.com: address comments from review results] [voice.shen@atmel.com: clean up for submit] Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Raffaele Recalcati <raffaele.recalcati@bticino.it>
2013-06-24net: Add sunxi (Allwinner) wemac driverHenrik Nordström
This patch adds support for the WEMAC, the ethernet controller included in the Allwinner A10 SoC. It will get used in the upcoming A10 board support. From: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-04-30net: gem: Preserve clk on emio interfaceDavid Andrey
Avoid overwriting GEMx_RCLK_CTRL and GEMx_CLK_CTRL if the Ethernet interface is connect on EMIO Do not enable emio for this standard board configuration for now. Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Pass phy address to initDavid Andrey
Pass the PHY address to the driver init to allow parallel use of both interfaces Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-01-28net: fec_mxc: get phydev before fec_probeTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-09mv88e61xx: refactor PHY and SWITCH level-codeAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-09-26net: Add driver for Zynq Gem IPMichal Simek
Device driver for Zynq Gem IP. Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Joe Hershberger <joe.hershberger@gmail.com> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-07-07SPEAr: Add interface information in initializationVipin Kumar
Few Designware peripheral registers need to be modified based on the ethernet interface selected by the board. This patch supports interface information in ethernet driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-01-05net: add Calxeda xgmac driverRob Herring
This adds ethernet driver for Calxeda xgmac found on Highbank SOC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Fix: WARNING: __aligned(size) is preferred over __attribute__((aligned(size))) Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-10-26altera_tse: Add support for dedicated descriptor memoryJoachim Foerster
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
2011-10-23net: emaclite: Move RX/TX ping pong initialization toMichal Simek
Init RX/TX ping pong directly from board not in the driver. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-23net: emaclite: Use unsigned long for baseaddrMichal Simek
Baseaddr should be unsigned long. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-15net: axi_ethernet: Add driver to u-bootMichal Simek
Add axi_ethernet driver for little-endian Microblaze. RX/TX BDs and rxframe buffer are shared among all axi_ethernet MACs. Only one MAC can work in one time. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-30FEC: Allow registering MII postconfiguration callbackMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-09-30FEC: Allow multiple FECesMarek Vasut
This patch allows user to register multiple FEC controllers. To preserve compatibility with older boards, the mxcfec_register() call is still in place. To use multiple controllers, new macro is in place, the mxcfec_register_multi(), which takes more arguments. The syntax is: mxcfec_register_multi(bd, FEC ID, FEC PHY ID on the MII bus, base address); To disable the fecmxc_register() compatibility stuff, define the macro CONFIG_FEC_MXC_MULTI. This will remove the requirement for defining IMX_FEC_BASE and CONFIG_FEC_MXC_PHYADDR. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-09-30net: Adds Fast Ethernet Controller driver for Armada100Ajay Bhargav
This patch adds support for Fast Ethernet Controller driver for Armada100 series. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-09-10cm4008, cm41xx: fix build warningsWolfgang Denk
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' While we are at it, sort include list in netdev.h Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-02-02Add support for MX35 processorStefano Babic
The patch adds basic support for the Freescale's i.MX35 (arm1136 based) processor. The patch adds also a prototype for the initialization of the FEC(ethernet controller) to netdev.h to avoid warnings. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-01-09ftgmac100: support of gigabit eth ftgmac100Macpaul Lin
Add Faraday's ftgmac100 (gigabit ethernet) MAC controller's driver. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-10-11net: Move Emaclite to NET_MULTIMichal Simek
Emaclite was using old net api that's why this patch move emaclite to NET_MULTI api. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11NET: add ENC28J60 driver using SPI frameworkReinhard Meyer
V3: further refinements: - use priv member instead of container method - allow setting of MAC address by write_hwaddr method - avoid shutting down link between commands Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11net: Fix faulty definition of uec_initialize()Joakim Tjernlund
The correct definition is in drivers/qe/uec.h so just remove this one. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12AX88180: add missing init prototypeMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12SPEAr : Network driver support addedVipin KUMAR
Designware network driver support added. This is a Synopsys ethernet controller Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03net: add altera triple speeds ethernet mac driverThomas Chou
This driver supports the Altera triple speeds 10/100/1000 ethernet mac. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03net: add opencore 10/100 ethernet mac driverThomas Chou
This patch ports the opencore 10/100 ethernet mac driver ethoc.c from linux kernel to u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31Add EP93xx ethernet driverMatthias Kaehlcke
Added ethernet driver for EP93xx SoCs Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13NET: LAN91C96 CONFIG_NET_MULTIifyNishanth Menon
Make the lan91c96 driver capable of CONFIG_NET_MULTI to be clean for the new arch, add a a lil detect function Most of the formatting change was done to keep checkpatch silent, but a few functions and #if 0ed code which does not make sense for NET_MULTI have been removed Now, use the lan91c96_initialize() function to init the driver Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-10arm: A320: driver for FTMAC100 ethernet controllerPo-Yu Chuang
This patch adds an FTMAC100 ethernet driver for Faraday A320 evaluation board. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
