path: root/include/netdev.h
2018-08-08mips: au1x00: Remove support for these SoCsTom Rini
The only platform left for the AU1x00 SoCs was the pb1x00 platform, an apparent clone of the dbau1x00 platform. As pb1x00 had no listed maintainer I am assuming that it is also orphaned. Remove this platform and then remove the unused SoC support. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-05-23net: Drop CONFIG_TSI108_ETHTuomas Tynkkynen
Last user of this driver went away in June 2015 in commit d928664f4101e24 ("powerpc: 74xx_7xx: remove 74xx_7xx cpu support") Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-04-13net: fec_mxc: simplify fec_get_miibusPeng Fan
No need to provide two prototype for this function. Use ulong for the first parameter, then this function could be shared for DM/non DM case. Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-22net: Drop CONFIG_ENC28J60Tuomas Tynkkynen
Last user of this driver went away in October 2014 in commit d58a9451e7339ed4 ("ppc/arm: zap EMK boards"). Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-23net: Remove Xilinx ll_temac driverMichal Simek
ll_temac driver was used by Xilinx Microblaze big endian and Xilinx ppc405/ppc440 SoCs. ppc support was removed by: "powerpc: remove 4xx support" (sha1: 98f705c9cefdfdba62c069821bbba10273a0a8ed) and Microblaze BE is not tested for a long time that's why this driver can be removed because none is going to updated it to DM anyway. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-07-28net: fec_mxc: adjust prototype of fec_get_miibus() for DM_ETHLothar Waßmann
commit 306dd7dabd64 ("net: fec_mxc: fix PHY initialization bug with CONFIG_DM_ETH") has broken the build of the fec_mxc driver with CONFIG_DM_ETH enabled because it changed the parameters passed to *fec_get_miibus() without changing the functions prototype. This patch fixes up the prototype of fec_get_miibus() for the DM_ETH case. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
2017-06-16powerpc, 82xx: remove some missed mpc82xx remainsHeiko Schocher
we removed 82xx support. Missed some 82xx remains, remove them now. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-24net: Remove unused mv88e61xx switch driverKevin Smith
No boards are using this driver. Remove in preparation for a new driver with integrated PHY support. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de>
2016-01-27net: emaclite: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: emaclite: Remove ancient OF probe functionMichal Simek
Prepare for DM move. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Move driver to DMMichal Simek
2015-12-07net: gem: Move driver to DMMichal Simek
- Enable DM_ETH by default for Zynq and ZynqMP - Remove board_eth_init code - Change miiphy_read function to return value instead of error code based on DM requirement - Do not enable EMIO DT support by default Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-07net: gem: Remove zynq_gem_of_init()Michal Simek
This function was used for OF init before DM. Remove this function as the part of move to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-12net: zap altera_tse_initialize prototypesThomas Chou
Zap the altera_tse_initialize() prototypes, since it is converted to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-09-09net: pch_gbe: Convert to driver modelBin Meng
This commit converts pch_gbe ethernet driver to driver model. Since this driver is only used by Intel Crown Bay board, the conversion does not keep the non-dm version. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-04sunxi: emac: Remove non driver-model codeHans de Goede
All sunxi boards now use the driver-model, so remove the non driver-model code. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: gmac: Move sunxi_gmac_initialize proto out of netdev.hHans de Goede
netdev.h should not be included in driver-model enabled builds (doing so causes compiler warnings about struct eth_driver not being declared), but we do use sunxi_gmac_initialize in the driver-model case, so move it out of netdev.h . Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-10lpc32xx: add Ethernet supportAlbert ARIBAUD \(3ADEV\)
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-03-24net: Add Intel Topcliff GMAC driverBin Meng
Add a new driver for the Gigabit Ethernet MAC found on Intel Topcliff Platform Controller Hub. Tested under 10/100 half/full duplex and 1000 full duplex modes using ping and tftpboot commands. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-01-21net: gem: Use phys_addr_t instead of int for addressesMichal Simek
Use phys_addr_t for physical address declaration. It is also unsigned type instead of sign. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-10-23net: mvneta.c: Add support for the ethernet controller of the Marvell Armada ↵Stefan Roese
XP SoC This patch adds support for the NETA ethernet controller which is integrated in the Marvell Armada XP SoC's. This port is based on the Linux driver which has been stripped of the in U-Boot unused portions. Tested on the Marvell MV78460 eval board db-78460-bp. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Tested-by: Luka Perkov <luka@openwrt.org>
2014-08-30arm: bcm281xx: net: Add Ethernet DriverJiandong Zheng
The Broadcom StarFighter2 Ethernet driver is used in multiple Broadcom SoC(s) and: - supports multiple MAC blocks, - provides support for the Broadcom GMAC. This driver requires MII and PHYLIB. Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-21drivers: net: remove dead driversMasahiro Yamada
The following configs are not defined at all: - CONFIG_INCA_IP_SWITCH - CONFIG_PBL2800_ETHER - CONFIG_PHY_ICPLUS Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-06net: Rename and cleanup sunxi (Allwinner) emac driverStefan Roese
There have been 3 versions of the sunxi_emac support patch during its development. Somehow version 2 ended up in upstream u-boot where as the u-boot-sunxi git repo got version 3. This bumps the version in upstream u-boot to version 3 of the patch: - Initialize MII clock earlier so mii access to allow independent use - Name change from WEMAC to EMAC to match mainline kernel & chip manual - Cosmetic code cleanup Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-05-25sunxi: add gmac Ethernet supportIan Campbell
Add support for the GMAC Ethernet controller on Allwinner A20 (sun7i) processors. Enable for the Cubietruck. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-04-20MIPS: drop incaip boardDaniel Schwierzeck
This is dead hardware and no one is interested in making the necessary changes for upcoming features like generic board or driver model. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Wolfgang Denk <wd@denx.de>
2014-03-04net: gem: Add OF initialization supportMichal Simek
Gem can be directly initialized from DTB. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04net: emaclite: Fix OF initializationMichal Simek
- Add xilinx_emaclite_of_init to netdev.h - Remove global data pointer from the driver - Add better handling for error state. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2013-06-24net: add Faraday FTMAC110 10/100Mbps ethernet supportKuo-Jung Su
Faraday FTMAC110 10/100Mbps supports half-word data transfer for Linux. However it has a weird DMA alignment issue: (1) Tx DMA Buffer Address: 1 bytes aligned: Invalid 2 bytes aligned: O.K 4 bytes aligned: O.K (2) Rx DMA Buffer Address: 1 bytes aligned: Invalid 2 bytes aligned: O.K 4 bytes aligned: Invalid!!! Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Tom Rini <trini@ti.com>
2013-06-24net: ks8851_mll: add ethernet supportRoberto Cerati
The device interface is 16 bits wide. All the available packets are read from the incoming fifo. Signed-off-by: Roberto Cerati <roberto.cerati@bticino.it> Signed-off-by: Raffaele Recalcati <raffaele.recalcati@bticino.it> [voice.shen@atmel.com: address comments from review results] [voice.shen@atmel.com: clean up for submit] Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Raffaele Recalcati <raffaele.recalcati@bticino.it>
2013-06-24net: Add sunxi (Allwinner) wemac driverHenrik Nordström
This patch adds support for the WEMAC, the ethernet controller included in the Allwinner A10 SoC. It will get used in the upcoming A10 board support. From: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-04-30net: gem: Preserve clk on emio interfaceDavid Andrey
Avoid overwriting GEMx_RCLK_CTRL and GEMx_CLK_CTRL if the Ethernet interface is connect on EMIO Do not enable emio for this standard board configuration for now. Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Pass phy address to initDavid Andrey
Pass the PHY address to the driver init to allow parallel use of both interfaces Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-01-28net: fec_mxc: get phydev before fec_probeTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-09mv88e61xx: refactor PHY and SWITCH level-codeAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-09-26net: Add driver for Zynq Gem IPMichal Simek
Device driver for Zynq Gem IP. Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Joe Hershberger <joe.hershberger@gmail.com> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-07-07SPEAr: Add interface information in initializationVipin Kumar
Few Designware peripheral registers need to be modified based on the ethernet interface selected by the board. This patch supports interface information in ethernet driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-01-05net: add Calxeda xgmac driverRob Herring
This adds ethernet driver for Calxeda xgmac found on Highbank SOC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Fix: WARNING: __aligned(size) is preferred over __attribute__((aligned(size))) Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-10-26altera_tse: Add support for dedicated descriptor memoryJoachim Foerster
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
2011-10-23net: emaclite: Move RX/TX ping pong initialization toMichal Simek
Init RX/TX ping pong directly from board not in the driver. Signed-off-by: Michal Simek <monstr@monstr.eu>
