path: root/include/netdev.h
2012-07-07SPEAr: Add interface information in initializationVipin Kumar
Few Designware peripheral registers need to be modified based on the ethernet interface selected by the board. This patch supports interface information in ethernet driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-01-05net: add Calxeda xgmac driverRob Herring
This adds ethernet driver for Calxeda xgmac found on Highbank SOC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Fix: WARNING: __aligned(size) is preferred over __attribute__((aligned(size))) Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-10-26altera_tse: Add support for dedicated descriptor memoryJoachim Foerster
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
2011-10-23net: emaclite: Move RX/TX ping pong initialization toMichal Simek
Init RX/TX ping pong directly from board not in the driver. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-23net: emaclite: Use unsigned long for baseaddrMichal Simek
Baseaddr should be unsigned long. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-15net: axi_ethernet: Add driver to u-bootMichal Simek
Add axi_ethernet driver for little-endian Microblaze. RX/TX BDs and rxframe buffer are shared among all axi_ethernet MACs. Only one MAC can work in one time. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-30FEC: Allow registering MII postconfiguration callbackMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-09-30FEC: Allow multiple FECesMarek Vasut
This patch allows user to register multiple FEC controllers. To preserve compatibility with older boards, the mxcfec_register() call is still in place. To use multiple controllers, new macro is in place, the mxcfec_register_multi(), which takes more arguments. The syntax is: mxcfec_register_multi(bd, FEC ID, FEC PHY ID on the MII bus, base address); To disable the fecmxc_register() compatibility stuff, define the macro CONFIG_FEC_MXC_MULTI. This will remove the requirement for defining IMX_FEC_BASE and CONFIG_FEC_MXC_PHYADDR. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-09-30net: Adds Fast Ethernet Controller driver for Armada100Ajay Bhargav
This patch adds support for Fast Ethernet Controller driver for Armada100 series. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-09-10cm4008, cm41xx: fix build warningsWolfgang Denk
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' While we are at it, sort include list in netdev.h Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-02-02Add support for MX35 processorStefano Babic
The patch adds basic support for the Freescale's i.MX35 (arm1136 based) processor. The patch adds also a prototype for the initialization of the FEC(ethernet controller) to netdev.h to avoid warnings. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-01-09ftgmac100: support of gigabit eth ftgmac100Macpaul Lin
Add Faraday's ftgmac100 (gigabit ethernet) MAC controller's driver. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-10-11net: Move Emaclite to NET_MULTIMichal Simek
Emaclite was using old net api that's why this patch move emaclite to NET_MULTI api. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11NET: add ENC28J60 driver using SPI frameworkReinhard Meyer
V3: further refinements: - use priv member instead of container method - allow setting of MAC address by write_hwaddr method - avoid shutting down link between commands Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11net: Fix faulty definition of uec_initialize()Joakim Tjernlund
The correct definition is in drivers/qe/uec.h so just remove this one. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12AX88180: add missing init prototypeMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12SPEAr : Network driver support addedVipin KUMAR
Designware network driver support added. This is a Synopsys ethernet controller Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03net: add altera triple speeds ethernet mac driverThomas Chou
This driver supports the Altera triple speeds 10/100/1000 ethernet mac. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03net: add opencore 10/100 ethernet mac driverThomas Chou
This patch ports the opencore 10/100 ethernet mac driver ethoc.c from linux kernel to u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31Add EP93xx ethernet driverMatthias Kaehlcke
Added ethernet driver for EP93xx SoCs Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13NET: LAN91C96 CONFIG_NET_MULTIifyNishanth Menon
Make the lan91c96 driver capable of CONFIG_NET_MULTI to be clean for the new arch, add a a lil detect function Most of the formatting change was done to keep checkpatch silent, but a few functions and #if 0ed code which does not make sense for NET_MULTI have been removed Now, use the lan91c96_initialize() function to init the driver Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-10arm: A320: driver for FTMAC100 ethernet controllerPo-Yu Chuang
This patch adds an FTMAC100 ethernet driver for Faraday A320 evaluation board. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22fec_mxc: driver for FEC ethernet controller on i.MX27Ilya Yanok
Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-07-188xxx: fix warning: implicit declaration of function 'uec_standard_init'Wolfgang Denk
Commit 8e55258f created function uec_standard_init() to initialize all UEC interfaces for 83xx and 85xx but failed to provide a prototype for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-15Convert DM9000 driver for CONFIG_NET_MULTIRemy Bohmer
All drivers need to be converted to CONFIG_NET_MULTI. This patch converts the dm9000 driver. Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15net: Add Marvell Kirkwood gigabit ethernet driverPrafulla Wadaskar
This patch adds a egiga driver for the Marvell Kirkwood SoC's. Contributors: Yotam Admon <yotam@marvell.com> Michael Blostein <michaelbl@marvell.com Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Acked-by: Stefan Rose <sr@denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15Switched davinci_emac Ethernet driver to use newer APIBen Warren
Added CONFIG_NET_MULTI to all Davinci boards Removed all calls to Davinci network driver from board code Added cpu_eth_init() to cpu/arm926ejs/cpu.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15Marvell MV88E61XX Switch Driver supportPrafulla Wadaskar
Chips supported:- 1. 88E6161 6 port gbe swtich with 5 integrated PHYs 2. 88E6165 6 port gbe swtich with 5 integrated PHYs 2. 88E6132 3 port gbe swtich with 2 integrated PHYs Platform specific configuration supported for:- default or router port vlan configuration led_init configuration mdip/n polarity reversal configuration Note: This driver is supported and tested against kirkwood egiga interface Contributors: Yotam Admon <yotam@marvell.com> Michael Blostein <michaelbl@marvell.com Reviewed by: Ronen Shitrit <rshitrit@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-04-19net: fix ULI 526x macro usage in netdev.hTimur Tabi
Change netdev.h to use CONFIG_ULI526X instead of CONFIG_ULI526. CONFIG_ULI526X is used everywhere else, so that's the correct macro name. Without this fix, Ethernet will not work on the Freescale MPC8610 HPCD. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-11Fix whitespace damage: double space changed to a tabJerry Van Baren
At some point an intentional double space at the end of the sentence got changed into a tab in the GPL header line: * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the This patch fixes the damage. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2009-02-10dnet: driver for Dave DNET ethernet controllerIlya Yanok
Driver for Dave DNET ethernet controller (used on Dave/DENX QongEVB-LITE board). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-24mgcoge make ether_scc.c work with CONFIG_NET_MULTIGary Jennejohn
This change is needed for mgcoge because it uses two ethernet drivers. Add a check for the presence of the PIGGY board on mgcoge. Without this board networking cannot work and the initialization must be aborted. Only allocate rtx once to prevent DPRAM exhaustion. Initialize ether_scc.c and the keymile-specific HDLC driver (to be added soon) in eth.c. Signed-off-by: Gary Jennejohn <garyj@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-24sh: sh_eth: Change new network APINobuhiro Iwamatsu
sh_eth used old network API. This patch changed new API. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09Moved initialization of PPC4xx EMAC to cpu_eth_init()Ben Warren
Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-11-09Moved initialization of MPC8XX SCC to cpu_eth_init()Ben Warren
2008-11-09Moved initialization of MPC8220 FEC to cpu_eth_init()Ben Warren
2008-11-09Moved initialization of QE Ethernet controller to cpu_eth_init()Ben Warren
2008-11-09Moved initialization of FCC Ethernet controller to cpu_eth_initBen Warren
Affected boards: Several MPC8xx boards Several MPC8260/MPC8272 boards Several MPC85xx boards Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09net: Move initialization of Au1x00 SoC ethernet MAC to cpu_eth_initShinya Kuribayashi
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init as a part of ongoing eth_initialize cleanup work. The function ret value is also fixed as it should be negative on fail. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09Moved initialization of IXP4XX_NPE Ethernet controller to cpu_eth_init()Ben Warren
Also, removed the driver initialization from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
