This commit adds a simple wget command that can download files
from http server.
The command syntax is
wget ${loadaddr} <path of the file from server>
Signed-off-by: Duncan Hare <DuncanCHare@yahoo.com>
Signed-off-by: Ying-Chun Liu (PaulLiu) <paul.liu@linaro.org>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Currently file transfers are done using tftp or NFS both
over udp. This requires a request to be sent from client
(u-boot) to the boot server.
The current standard is TCP with selective acknowledgment.
Signed-off-by: Duncan Hare <DH@Synoia.com>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
In the current DSA switch driver API, only the udevice of the switch
(belonging to UCLASS_DSA) is exposed, as well as an "int port" argument.
So drivers do not have access to the udevice of individual ports
(belonging to UCLASS_ETH), one of the reasons being that not all ports
have an associated UCLASS_ETH udevice.
However, all DSA ports have an OF node, and in some cases the driver
needs a handle to it, for all ports including the CPU port. Example: the
following Linux per-port device tree property:
managed = "in-band-status";
states whether a port should operate with clause 37 in-band autoneg
enabled or not.
This patch exposes a function which can be called by individual drivers
as needed.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
NXP Legal insists that the following are not fine:
- Saying "NXP Semiconductors" instead of "NXP", since the company's
registered name is "NXP"
- Putting a "(c)" sign in the copyright string
- Putting a comma in the copyright string
The only accepted copyright string format is "Copyright <year-range> NXP".
This patch changes the copyright headers in the networking files that
were sent by me, or derived from code sent by me.
Some drivers might want to execute code for each port at probe time, as
opposed to executing code just-in-time for the port selected for
networking.
To cater to that use case, introduce a .port_probe() callback method
into the DSA switch operations which is called for each available port,
at the end of dsa_port_probe().
Tested-by: Michael Walle <michael@walle.cc>
When using bootefi to boot a EFI binary, u-boot is supposed to
provide networking service for EFI application. Currently, 'pfe stop'
command is called from bootcmd before running bootefi. As a result
network stops working for EFI applications and console is flooded with
"Rx pkt not on expected port" messages.
Implement board_quiesce_devices() for ls1012a boards and call
pfe_command_stop() from it instead of calling 'pfe stop' from
*_bootcmd and bootcmd.
Tested-by: Anji Jagarlmudi <anji.jagarlmudi@nxp.com>
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
[Fixed checkpatch space error]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
DSA stands for Distributed Switch Architecture and it covers switches that
are connected to the CPU through an Ethernet link and generally use frame
tags to pass information about the source/destination ports to/from CPU.
Front panel ports are presented as regular ethernet devices in U-Boot and
they are expected to support the typical networking commands.
DSA switches may be cascaded, DSA class code does not currently support
this.
Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com>
Signed-off-by: Claudiu Manoil <claudiu.manoil@nxp.com>
This commits update the support of sntp to use
the framework udp. This change allows to remove
all the reference to sntp in the main network
file net/net.c.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
This commit adds a generic udp protocol framework in the
network loop. So protocol based on udp may be implemented
without modifying the network loop (for example custom
wait magic packet).
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
This introduces support for the NC-SI protocol, modelled as a phy driver
for other ethernet drivers to consume.
NC-SI (Network Controller Sideband Interface) is a protocol to manage a
sideband connection to a proper network interface, for example a BMC
(Baseboard Management Controller) sharing the NIC of the host system.
Probing and configuration occurs by communicating with the "remote" NIC
via NC-SI control frames (Ethernet header 0x88f8).
This implementation is roughly based on the upstream Linux
implementation[0], with a reduced feature set and an emphasis on getting
a link up as fast as possible rather than probing the full possible
topology of the bus.
The current phy model relies on the network being "up", sending NC-SI
command frames via net_send_packet() and receiving them from the
net_loop() loop (added in a following patch).
The ncsi-pkt.h header[1] is copied from the Linux kernel for consistent
field definitions.
[0]: https://github.com/torvalds/linux/tree/master/net/ncsi
[1]: https://github.com/torvalds/linux/blob/master/net/ncsi/ncsi-pkt.h
Signed-off-by: Samuel Mendoza-Jonas <sam@mendozajonas.com>
Reviewed-by: Joel Stanley <joel@jms.id.au>
Add support for capturing ethernet packets and storing
them in memory in PCAP(2.4) format, later to be analyzed by
any PCAP viewer software (IE. Wireshark)
This feature greatly assist debugging network issues such
as detecting dropped packets, packet corruption etc.
Signed-off-by: Ramon Fried <rfried.dev@gmail.com>
Reviewed-by: Alex Marginean <alexm.osslist@gmail.com>
Tested-by: Alex Marginean <alexm.osslist@gmail.com>
Merge UDP fastboot support from AOSP:
https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Signed-off-by: Alex Deymo <deymo@google.com>
Signed-off-by: Jocelyn Bohr <bohr@google.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Contains all the pfe header files.
Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com>
Signed-off-by: Anjaneyulu Jagarlmudi <anji.jagarlmudi@nxp.com>
This change gives the ability to reuse the <tftp.h> header file by other
subsystems (like e.g. dfu).
Without this change compilation error emerges for the legacy update.c file.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
