path: root/include/net.h
2015-07-21net: Allow drivers to return -ENOSYS with the write_hwaddr() methodSimon Glass
Some drivers may want to implement this method for some of their devices but not for others. So it is not possible to just leave the operation out of the table. Drivers could get around this by masquerading as two separate drivers but that seems unpleasant. Allow the driver to return an error when it does not want to process the write_hwaddr() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: eth: Avoid blocking on packet receptionSimon Glass
Some devices can take a long time to work out whether they have a new packet or now. For example the ASIX USB Ethernet dongle can take 5 seconds to do this, since it waits until it gets a new packet on the wire before allowing the USB bulk read packet to be submitted. At present with driver mode the Ethernet receive code reads 32 packets. This can take a very long time if we must wait for all 32 packets. The old code (before driver model) worked by reading a single set of packets from the USB device, then processing all the packets with in. It would be nice to use the same behaviour with driver model. Add a flag to the receive method which indicates that the driver should try to find a packet if available, by consulting the hardware. When the flag is not set, it should just return any packet data it has already received. If there is none, it should return -EAGAIN so that the loop will terminate. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: net: Adjust PHY interface to work with CONFIG_DM_ETHSimon Glass
When driver model is used for Ethernet a few functions are passed a udevice instead of an eth_device. Also add a function to find a PHY type given its name. This will be used to decode the device tree node. Finally, put a phy_interface field in struct eth_pdata since this is an important part of the platform data for Ethernet. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: Convert protocol structures to use explicit sizesSergey Temerkhanov
Convert uchar/ushort to u8/u16 respectively. Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Fix incorrect DHCP/BOOTP packets on 64-bit systemsSergey Temerkhanov
This commit fixes incorrect DHCP/BOOTP packet layout caused by 'ulong' type size difference on 64 and 32-bit architectures. It also renames NetReadLong()/NetCopyLong() to net_read_u32/net_copy_u32() accordingly. Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.hJoe Hershberger
There were still a few remaining complains in the legacy eth_device definition that hadn't been addressed. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up cmd_net variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within common/cmd_net.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up netconsole variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within netconsole.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up DNS variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within dns.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up CDP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within cdp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names for DHCP stringsJoe Hershberger
Remove CamelCase variable naming. Move the definition to the same compilation unit as the primary use. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names related to boot fileJoe Hershberger
The variables around the bootfile were inconsistent and used CamelCase. Update them to make the code more readable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Provide a way for drivers to manage packet buffersJoe Hershberger
Some drivers need a chance to manage their receive buffers after the packet has been handled by the network stack. Add an operation that will allow the driver to be called in that case. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-on: pcduino3
2015-04-18net: Improve error handlingJoe Hershberger
Take a pass at plumbing errors through to the users of the network stack Currently only the start() function errors will be returned from NetLoop(). recv() tends not to have errors, so that is likely not worth adding. send() certainly can return errors, but this patch does not attempt to plumb them yet. halt() is not expected to error. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add support for aliasesJoe Hershberger
Allow network devices to be referred to as "eth0" instead of "eth@12345678" when specified in ethact. Add tests to verify this behavior. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Pass the packet pointer as a parameter to recvJoe Hershberger
Stop forcing drivers to call net_process_received_packet() - formerly called NetReceive(). Now the uclass will handle calling the driver for each packet until the driver errors or has nothing to return. The uclass will then pass the good packets off to the network stack by calling net_process_received_packet(). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: Clean up network stack names used in DM driversJoe Hershberger
Take the opportunity to enforce better names on newly written or retrofitted Ethernet drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add basic driver model support to Ethernet stackJoe Hershberger
First just add support for MAC drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-04-18net: Use int instead of u8 for boolean flagJoe Hershberger
On some archs masking the parameter is inefficient, so don't use u8. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Refactor in preparation for driver modelJoe Hershberger
Move some things around and organize things so that the driver model implementation will fit in more easily. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove unneeded "extern" in net.hJoe Hershberger
Many of the functions in net.h were preceded extern needlessly. Removing them to limit the number of checkpatch.pl complaints. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Provide a function to get the current MAC addressJoe Hershberger
The current implementation exposes the eth_device struct to code that needs to access the MAC address. Add a wrapper function for this to abstract away the pointer for this operation. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-24net: Add ethernet FCS length macro in net.hBin Meng
Some ethernet drivers use their own version of ethernet FCS length macro which is really common. We define ETH_FCS_LEN in net.h and replace those custom versions in various places. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-12net: Use new checksum functionsSimon Glass
Drop the old checksum functions in favour of the new ones. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-23net: Add a separate file for IP checksummingSimon Glass
Move the checksum code out into its own file so it can be used elsewhere. Also use a new version which supports a length which is not a multiple of 2 and add a new function to add two checksums. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-14net: Declare physical address as phys_addr_t unsigned typeMichal Simek
Use phys_addr_t instead of int for addresses. Addresses can't be < 0. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-10-10SPDX License cleanup for LiMon imported filesWolfgang Denk
A number of network related files were imported from the LiMon project; these contain a somewhat unclear license statement: Copyright 1994 - 2000 Neil Russell. (See License) I analyzed the source code of LiMon v1.4.2 which was used for this import. It does not contain any "License" file, but the top level directory contains a file "COPYING", which turns out to be GPL v2 of June 1991. So it is legitimate to conclude that the LiMon derived files are also to be released under GPLv2. Mark them as such. Signed-off-by: Wolfgang Denk <wd@denx.de>
2014-05-12net: rename and refactor eth_rand_ethaddr() functionMasahiro Yamada
Some functions in include/net.h are ported from include/linux/etherdevice.h of Linux Kernel. For ex. is_zero_ether_addr() is_multicast_ether_addr() is_broadcast_ether_addr() is_valid_ether_addr(); So, we should use the same function name as that of Linux Kernel, eth_rand_addr(), for consistency. Besides, eth_rand_addr() has been implemented as an inline function. So it should not be surrounded by #ifdef CONFIG_RANDOM_MACADDR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2013-11-22net: Fix mcast function pointer prototypeClaudiu Manoil
This fixes the following compiler warnings when activating CONFIG_MCAST_TFTP: tsec.c: In function 'tsec_mcast_addr': tsec.c:130:2: warning: passing argument 2 of 'ether_crc' makes pointer from integer without a cast [enabled by default] In file included from /work/u-boot-net/include/common.h:874:0, from tsec.c:15: /work/u-boot-net/include/net.h:189:5: note: expected 'const unsigned char *' but argument is of type 'u8' tsec.c: In function 'tsec_initialize': tsec.c:646:13: warning: assignment from incompatible pointer type [enabled by default] eth.c: In function 'eth_mcast_join': eth.c:358:2: warning: passing argument 2 of 'eth_current->mcast' makes integer from pointer without a cast [enabled by default] eth.c:358:2: note: expected 'u32' but argument is of type 'u8 *' In the eth_mcast_join() implementation, eth_current->mcast() takes a u8 pointer to the multicast mac address and not a ip address value as implied by its prototype. Fix parameter type mismatch for tsec_macst_addr() (tsec.c): ether_crc() takes a u8 pointer not a u8 value. mcast() is given a u8 pointer to the multicats mac address. Update parameter type for the rest of mcast() instances. Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com> Patch: 278989
2013-08-19net.h: don't use the reserved name __unusedJeroen Hofstee
The __* keywords are reserved. On FreeBSD __unused evaluates to the attribute unused, causing a compilation failure. Just use unused instead. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> cc: joe.hershberger@gmail.com
2013-06-24net: make IPaddr type big endianKim Phillips
for use with sparse. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2013-06-04net: Add prototype for update_tftpSimon Glass
This function should be declared in net.h. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-11-04net/: sparse fixesKim Phillips
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static? bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static? bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static? arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static? arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static? arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static? atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static? net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static? net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static? ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static? ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static? tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static? tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static? eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static? Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020 "net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING clause from when it was necessary to avoid warnings when it was embedded in net.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-24net: Filter incoming netconsole packets by IPJoe Hershberger
Check the incoming packets' source IP address... if ncip isn't set to a broadcast address, only listen to the client at ncip. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-24net: Improve the speed of netconsoleJoe Hershberger
Previously u-boot would initialize the network interface for every network operation and then shut it down again. This makes sense for most operations where the network in not known to be needed soon after the operation is complete. In the case of netconsole, it will use the network for every interaction with the shell or every printf. This means that the network is being reinitialized very often. On many devices, this intialization is very slow. This patch checks for consecutive netconsole actions and leaves the ethernet hardware initialized between them. It will still behave the same old way for all other network operations and any time another network operation happens between netconsole operations. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-07-07net: add helper to generate random mac addressMichael Walle
Add new function eth_random_enetaddr() to generate a locally administered ethernet address. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Joe Hershberger <joe.hershberger@gmail.com>
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Add link-local addressing supportJoe Hershberger
Code based on networking/zcip.c in busybox commit 8531d76a15890c2c535908ce888b2e2aed35b172 Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Don't copy every packet that waits for an ARPJoe Hershberger
Use the NetArpTxPacket for the ARP packet, not to hold what used to be in NetTxPacket. This saves a copy and makes the code easier to understand. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Fix net buffer initializationJoe Hershberger
A new non-static function net_init() will initialize buffers and read from the environment. Only update from the env on each entry to NetLoop(). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Add net_update_ether() to handle ARP and Ping repliesJoe Hershberger
When the network is VLAN or SNAP, net_update_ether() will preserve the original Ethernet packet header and simply replace the src and dest MACs and the protocol Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to separate the UDP handler from the ARP handlerJoe Hershberger
Call a built-in dummy if none is registered... don't require protocols to register a handler (eliminating dummies) NetConsole now uses the ARP handler when waiting on arp (instead of needing a #define hack in arp.c) Clear handlers at the end of net loop Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to protect access to the NetState variableJoe Hershberger
Changes to NetState now go through an accessor function called net_set_state() Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Refactor to use NetSendPacket instead of eth_send directlyJoe Hershberger
Use this entry-point consistently across the net/ code Use a static inline function to preserve code size Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
