path: root/include/net.h
2009-03-20net: new utility functions for working with enetaddr'sMike Frysinger
Declare new utility functions for converting between the environment variables (eth*addr) and the binary MAC address representation. This way we can unify all the random places that already do this kind of thing. The functions in question: eth_parse_enetaddr - "..." -> {...} eth_getenv_enetaddr - env -> {...} eth_setenv_enetaddr - {...} -> env Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-16Make some minor whitespace changes to eliminate line-wrappingAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28Move is_valid_ether_addr() to include/net.hMike Frysinger
Import the is_valid_ether_addr() function from the Linux kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: Define IP flag field valuesPeter Tyser
These defines were pulled from the "Add simple IP/UDP fragmentation support" patch from Frank Haverkamp <haver@vnet.ibm.com>. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-30Fix warnings while compiling net/net.c for MPC8610HPCD boardAnatolij Gustschin
MPC8610HPCD board adds -O2 gcc option to PLATFORM_CPPFLAGS causing overriding default -Os option. New gcc (ver. 4.2.2) produces warnings while compiling net/net.c file with -O2 option. The patch is an attempt to fix this. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-01-03Introduce new eth_receive routineRafal Jaworowski
The purpose of this routine is receiving a single network frame, outside of U-Boot's NetLoop(). Exporting it to standalone programs that run on top of U-Boot will let them utilise networking facilities. For sending a raw frame the already existing eth_send() can be used. The direct consumer of this routine is the newly introduced API layer for external applications (enabled with CONFIG_API). Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-08-13multicast tftp: RFC2090David Updegraff
Implemented IETF RFC2090, Multicast TFTP. Initial implementation on Realtek RTL8139 and Freescale TSEC. Signed-off-by: David Updegraff <dave@cray.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13Add ability to take MAC address from the environment to DM9000 driverMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-07-09Finally retire cmd_confdefs.h and CONFIG_BOOTP_MASK!Jon Loeliger
All of the choices for CONFIG_BOOTP_ are now documented in the README file. You must now individually select exactly the set that you want using a series of #define CONFIG_BOOTP_<x> statements in the board port config files now. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2004-10-09Patch by Andreas Engel, 16 Aug 2004:wdenk
parameter type cleanup for NetSetTimeout()
2004-08-02Add support for console over UDP (compatible to Ingo Molnar'swdenk
netconsole patch under Linux)
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2003-06-05- CFG_ETH_RX_BUFFER added.stroese
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
2002-11-11* Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211wdenk
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h
2002-10-31Initial revisionwdenk
