PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled
by default for '-O2':
BOOTP broadcast 1
data abort
pc : [<8ff8bb30>] lr : [<00004f1f>]
reloc pc : [<17832b30>] lr : [<878abf1f>]
sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4
r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594
r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e
r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd
Flags: nzcv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Core reason is usage of structures for network headers without packed
attribute.
Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com>
(cherry picked from commit 704f3acfcf55343043bbed01c5fb0a0094a68e8a)
include/net.h
upstream changed magic numbers with define
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
We can now successfully boot EFI applications from disk, but users
may want to also run them from a PXE setup.
This patch implements rudimentary network support, allowing a payload
to send and receive network packets.
With this patch, I was able to successfully run grub2 with network
access inside of QEMU's -M xlnx-ep108.
Ethernet packages with IEEE 802.1Q VLAN support may be up to 1522
bytes long. Increase the default size used to allocate packet
storage by 4 bytes. While at it, let git care about history and
rewrite the comment to represent the situation today only.
Signed-off-by: Stefan Agner <stefan@agner.ch>
This patch adds support for the mvpp2 ethernet controller which is integrated
in the Marvell Armada 375 SoC. This port is based on the Linux driver (v4.4),
which has been stripped of the in U-Boot unused portions.
Tested on the Marvell Armada 375 eval board db-88f6720.
Cc: Luka Perkov <luka.perkov@sartura.hr>
Acked-by: Joe Hershberger <joe.hershberger@gmail.com>
Some TI boards (e.g. IDK) have 4 to 6 ethernet ports and
this function is handy at board.c to configure the
MAC address of the ports.
Signed-off-by: Roger Quadros <rogerq@ti.com>
This will be used for getting max speed mode of Ethernet interface that
a particular MAC supports from Device Tree blob and later being used for
phy configuration.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Since commit de4d2e9e7ce0f9 (" bitops: Add fls_long and __ffs64")
<linux/compiler.h> is included in include/linux/bitops.h,
which allows us to marking a function as 'always_inline' in a simpler
format.
The net_boot_file_name buffer is used as storage for the bootfilename
command line argument to network boot commands such as tftp and nfs.
Increase the size of this buffer to 1024 bytes as the current size of
128 bytes is restrictive for arbitrary paths on the server.
Signed-off-by: Jacob Stiffler <j-stiffler@ti.com>
As we don't modify the 'name' parameter, so change it to const.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
The previous eth_device struct returned by eth_get_dev() allowed
code to directly query the state member field. However, with
CONFIG_DM_ETH this data gets encapsulated (i.e. private), and
eth_get_dev() returns a udevice struct 'abstraction' instead.
This breaks legacy code relying on the former behaviour - e.g.
netconsole.
(see http://lists.denx.de/pipermail/u-boot/2015-June/216528.html)
The patch introduces a method to retrieve the ethernet device
state in a 'clean' and uniform way, supporting both legacy code
and driver model. The new function eth_is_active() accepts a
device struct pointer and tests it for ETH_STATE_ACTIVE.
Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de>
This code allows using DFU defined mediums for storing data received via
TFTP protocol.
It reuses and preserves functionality of legacy code at common/update.c.
The update_tftp() function now accepts parameters - namely medium device
name and its number (e.g. mmc 1).
Without this information passed old behavior is preserved.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
Some drivers may want to implement this method for some of their devices but
not for others. So it is not possible to just leave the operation out of
the table. Drivers could get around this by masquerading as two separate
drivers but that seems unpleasant.
Allow the driver to return an error when it does not want to process the
write_hwaddr() method.
Some devices can take a long time to work out whether they have a new packet
or now. For example the ASIX USB Ethernet dongle can take 5 seconds to do
this, since it waits until it gets a new packet on the wire before allowing
the USB bulk read packet to be submitted.
At present with driver mode the Ethernet receive code reads 32 packets. This
can take a very long time if we must wait for all 32 packets. The old code
(before driver model) worked by reading a single set of packets from the USB
device, then processing all the packets with in. It would be nice to use
the same behaviour with driver model.
Add a flag to the receive method which indicates that the driver should try
to find a packet if available, by consulting the hardware. When the flag is
not set, it should just return any packet data it has already received. If
there is none, it should return -EAGAIN so that the loop will terminate.
When driver model is used for Ethernet a few functions are passed a udevice
instead of an eth_device. Also add a function to find a PHY type given its
name. This will be used to decode the device tree node.
Finally, put a phy_interface field in struct eth_pdata since this is an
important part of the platform data for Ethernet.
Convert uchar/ushort to u8/u16 respectively.
Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com>
This commit fixes incorrect DHCP/BOOTP packet layout caused by
'ulong' type size difference on 64 and 32-bit architectures.
It also renames NetReadLong()/NetCopyLong() to
net_read_u32/net_copy_u32() accordingly.
Finish eliminating CamelCase from net.c and other failures
There were still a few remaining complains in the legacy eth_device
definition that hadn't been addressed.
Make a thorough pass through all variables and function names contained
within common/cmd_net.c and remove CamelCase and improve naming.
within netconsole.c and remove CamelCase and improve naming.
within dns.c and remove CamelCase and improve naming.
within cdp.c and remove CamelCase and improve naming.
Update the naming convention used in the network stack functions and
variables that Ethernet drivers use to interact with it.
This cleans up the temporary hacks that were added to this interface
along with the DM support.
This patch has a few remaining checkpatch.pl failures that would be out
of the scope of this patch to fix (drivers that are in gross violation
of checkpatch.pl).
This patch cleans up the names of internal packet buffer names that are
used within the network stack and the functions that use them.
Use "_ethaddr" at the end of variables and drop CamelCase.
Make constant values actually 'const'.
Remove CamelCase variable naming.
Move the definition to the same compilation unit as the primary use.
The variables around the bootfile were inconsistent and used CamelCase.
Update them to make the code more readable.
This patch is simply clean-up to make the IPv4 type that is used match
what Linux uses. It also attempts to move all variables that are IP
addresses use good naming instead of CamelCase. No functional change.
Some drivers need a chance to manage their receive buffers after the
packet has been handled by the network stack. Add an operation that
will allow the driver to be called in that case.
Reported-by: Simon Glass <sjg@chromium.org>
Tested-on: pcduino3
Take a pass at plumbing errors through to the users of the network stack
Currently only the start() function errors will be returned from
NetLoop(). recv() tends not to have errors, so that is likely not worth
adding. send() certainly can return errors, but this patch does not
attempt to plumb them yet. halt() is not expected to error.
Allow network devices to be referred to as "eth0" instead of
"eth@12345678" when specified in ethact.
Add tests to verify this behavior.
Stop forcing drivers to call net_process_received_packet() - formerly
called NetReceive(). Now the uclass will handle calling the driver for
each packet until the driver errors or has nothing to return. The uclass
will then pass the good packets off to the network stack by calling
net_process_received_packet().
Take the opportunity to enforce better names on newly written or
retrofitted Ethernet drivers.
First just add support for MAC drivers.
This value is not used by the network stack and is available in the
global data, so stop passing it around. For the one legacy function
that still expects it (init op on old Ethernet drivers) pass in the
global pointer version directly to avoid changing that interface.
(Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
On some archs masking the parameter is inefficient, so don't use u8.
Move some things around and organize things so that the driver model
implementation will fit in more easily.
Many of the functions in net.h were preceded extern needlessly. Removing
them to limit the number of checkpatch.pl complaints.
The current implementation exposes the eth_device struct to code that
needs to access the MAC address. Add a wrapper function for this to
abstract away the pointer for this operation.
Some ethernet drivers use their own version of ethernet FCS length
macro which is really common. We define ETH_FCS_LEN in net.h and
replace those custom versions in various places.
Drop the old checksum functions in favour of the new ones.
Move the checksum code out into its own file so it can be used elsewhere.
Also use a new version which supports a length which is not a multiple of
2 and add a new function to add two checksums.
Use phys_addr_t instead of int for addresses.
Addresses can't be < 0.
A number of network related files were imported from the LiMon
project; these contain a somewhat unclear license statement:
Copyright 1994 - 2000 Neil Russell.
(See License)
I analyzed the source code of LiMon v1.4.2 which was used for this
import. It does not contain any "License" file, but the top level
directory contains a file "COPYING", which turns out to be GPL v2
of June 1991. So it is legitimate to conclude that the LiMon derived
files are also to be released under GPLv2. Mark them as such.
Some functions in include/net.h are ported from
include/linux/etherdevice.h of Linux Kernel.
For ex.
is_zero_ether_addr()
is_multicast_ether_addr()
is_broadcast_ether_addr()
is_valid_ether_addr();
So, we should use the same function name as that of Linux Kernel,
eth_rand_addr(), for consistency.
Besides, eth_rand_addr() has been implemented as an inline function.
So it should not be surrounded by #ifdef CONFIG_RANDOM_MACADDR.
This fixes the following compiler warnings when activating
CONFIG_MCAST_TFTP:
tsec.c: In function 'tsec_mcast_addr':
tsec.c:130:2: warning: passing argument 2 of 'ether_crc' makes pointer
from integer without a cast [enabled by default]
In file included from /work/u-boot-net/include/common.h:874:0,
from tsec.c:15:
/work/u-boot-net/include/net.h:189:5: note: expected 'const unsigned
char *' but argument is of type 'u8'
tsec.c: In function 'tsec_initialize':
tsec.c:646:13: warning: assignment from incompatible pointer type
eth.c: In function 'eth_mcast_join':
eth.c:358:2: warning: passing argument 2 of 'eth_current->mcast' makes
integer from pointer without a cast [enabled by default]
eth.c:358:2: note: expected 'u32' but argument is of type 'u8 *'
In the eth_mcast_join() implementation, eth_current->mcast()
takes a u8 pointer to the multicast mac address and not a ip
address value as implied by its prototype.
Fix parameter type mismatch for tsec_macst_addr() (tsec.c):
ether_crc() takes a u8 pointer not a u8 value.
mcast() is given a u8 pointer to the multicats mac address.
Update parameter type for the rest of mcast() instances.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
Patch: 278989
The __* keywords are reserved. On FreeBSD __unused evaluates
to the attribute unused, causing a compilation failure.
Just use unused instead.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
cc: joe.hershberger@gmail.com
for use with sparse.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
