path: root/include/net.h
2011-05-19TFTP: add tftpsrv commandLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-12NET: pass source IP address to packet handlersLuca Ceresoli
This is needed for the upcoming TFTP server implementation. This also simplifies PingHandler() and fixes rxhand_f documentation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-11-28string_to_ip: constify "s" argMike Frysinger
2010-11-28string_to_VLAN: constify "var" argMike Frysinger
2010-11-28copy_filename: constify "src" argMike Frysinger
2010-09-20Integrate USB gadget layer and USB CDC driver layerRemy Bohmer
Derived from Linux kernel 2.6.27 Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-08-09Fix compile warnings for const correctnessBen Warren
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls to take a (const char *) parameter instead of (char *), but in some cases the modified functions call other functions taking (char *). The end result is warnings about discarding the const qualifier. This patch fixes these other function signatures. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03Program net device MAC addresses after initializingBen Warren
Add a new function to the eth_device struct for programming a network controller's hardware address. After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-01-17Make getenv_IPaddr() globalDirk Behme
There are boards out there that do not have network support in U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This makes it desirable to be able to port network configuration (like the IP address) to the Linux kernel. We should not make the passing of the IP configuration to Linux dependent on U-Boot features / settings. For this, make getenv_IPaddr() global. This fixes build error u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr' on various architectures. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04net: add random_port() prototypeMike Frysinger
The random_port() is meant to be used by other net code, but without a prototype, we get fun warnings like: dns.c: In function 'DnsSend': dns.c:89: warning: implicit declaration of function 'random_port' Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-07net: sync env ethaddr to device enetaddr in eth_init()Mike Frysinger
In the previous enetaddr refactoring, the assumption with commit 56b555a644 was that the eth layer would handle the env -> device enetaddr syncing. This was not the case as eth_initialize() is called only once and the sync occurs there. So make sure the eth_init() function does the env -> device sync with every network init. Reported-by: Andrzej Wolski <awolski@poczta.fm> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22net: rename NetRxPkt to NetRxPacketMike Frysinger
The net code is mostly consistent in using 'Packet' rather than 'Pkt', so rename the minor detractor to follow suite. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20net: new utility functions for working with enetaddr'sMike Frysinger
Declare new utility functions for converting between the environment variables (eth*addr) and the binary MAC address representation. This way we can unify all the random places that already do this kind of thing. The functions in question: eth_parse_enetaddr - "..." -> {...} eth_getenv_enetaddr - env -> {...} eth_setenv_enetaddr - {...} -> env Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-16Make some minor whitespace changes to eliminate line-wrappingAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28Move is_valid_ether_addr() to include/net.hMike Frysinger
Import the is_valid_ether_addr() function from the Linux kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: Define IP flag field valuesPeter Tyser
These defines were pulled from the "Add simple IP/UDP fragmentation support" patch from Frank Haverkamp <haver@vnet.ibm.com>. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-30Fix warnings while compiling net/net.c for MPC8610HPCD boardAnatolij Gustschin
MPC8610HPCD board adds -O2 gcc option to PLATFORM_CPPFLAGS causing overriding default -Os option. New gcc (ver. 4.2.2) produces warnings while compiling net/net.c file with -O2 option. The patch is an attempt to fix this. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-01-03Introduce new eth_receive routineRafal Jaworowski
The purpose of this routine is receiving a single network frame, outside of U-Boot's NetLoop(). Exporting it to standalone programs that run on top of U-Boot will let them utilise networking facilities. For sending a raw frame the already existing eth_send() can be used. The direct consumer of this routine is the newly introduced API layer for external applications (enabled with CONFIG_API). Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-08-13multicast tftp: RFC2090David Updegraff
Implemented IETF RFC2090, Multicast TFTP. Initial implementation on Realtek RTL8139 and Freescale TSEC. Signed-off-by: David Updegraff <dave@cray.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13Add ability to take MAC address from the environment to DM9000 driverMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-07-09Finally retire cmd_confdefs.h and CONFIG_BOOTP_MASK!Jon Loeliger
All of the choices for CONFIG_BOOTP_ are now documented in the README file. You must now individually select exactly the set that you want using a series of #define CONFIG_BOOTP_<x> statements in the board port config files now. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2004-10-09Patch by Andreas Engel, 16 Aug 2004:wdenk
parameter type cleanup for NetSetTimeout()
2004-08-02Add support for console over UDP (compatible to Ingo Molnar'swdenk
netconsole patch under Linux)
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2003-06-05- CFG_ETH_RX_BUFFER added.stroese
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
2002-11-11* Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211wdenk
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h
2002-10-31Initial revisionwdenk
