path: root/include/nand.h
2017-03-28mtd: nand: remove nand size print from nand_init functionHou Zhiqiang
Add nand_size() function to move the nand size print into initr_nand(). Remove nand size print from nand_init() to allow other function to call nand_init() without printing nand size. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-24mtd: nand: Add the sunxi NAND controller driverBoris Brezillon
We already have an SPL driver for the sunxi NAND controller, now add the normal/standard one. The source has been copied from Linux 4.6 with a few changes to make it work in u-boot. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-22nand_spl_simple: Add a simple NAND read functionThomas Gleixner
To support UBI in SPL we need a simple NAND read function. Add one to nand_spl_simple and keep it as simple as it goes. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Scott Wood <oss@buserror.net> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Remove nand_info_t typedefScott Wood
This typedef serves no purpose other than causing confusion with struct nand_chip. Signed-off-by: Scott Wood <oss@buserror.net>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-30nand: yaffs: Remove the "nand write.yaffs" commandPeter Tyser
This command is only enabled by one board, complicates the NAND code, and doesn't appear to have been functioning properly for several years. If there are no bad blocks in the NAND region being written nand_write_skip_bad() will take the shortcut of calling nand_write() which bypasses the special yaffs handling. This causes invalid YAFFS data to be written. See http://lists.denx.de/pipermail/u-boot/2011-September/102830.html for an example and a potential workaround. U-Boot still retains the ability to mount and access YAFFS partitions via CONFIG_YAFFS2. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2015-03-30nand: Add verification functionsPeter Tyser
Add nand_verify() and nand_verify_page_oob(). nand_verify() verifies NAND contents against an arbitrarily sized buffer using ECC while nand_verify_page_oob() verifies a NAND page's contents and OOB. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-30nand: Remove unused read/write structuresPeter Tyser
The use of the nand_write_options and nand_read_options structures were removed in commit dfbf617ff055e4216f78d358b0867c548916d14b. Remove the now-unused structures too. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2014-11-17spl, nand, atmel_nand: add erase one block functionHeiko Schocher
erase one nand block in spl code. keep it simple, as size matters This is used on the upcoming taurus spl support. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-09mtd: nand: atmel: prepare for nand spl boot supportBo Shen
Prepare for nand spl boot support. It supports nand software ECC and hardware PMECC. This patch is take <drivers/mtd/nand/nand_spl_simple.c> as reference. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-24dfu, nand: before write a buffer to nand, erase the nand sectorsHeiko Schocher
before writing the received buffer to nand, erase the nand sectors. If not doing this, nand write fails. See for more info here: http://lists.denx.de/pipermail/u-boot/2013-June/156361.html Using the nand erase option "spread", maybe overwrite blocks on, for example another mtd partition, if the erasing range contains bad blocks. So a limit option is added to nand_erase_opts() Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-22nand/fsl_ifc: Convert to self-initPrabhakar Kushwaha
Convert NAND IFC driver to support CONFIG_SYS_NAND_SELF_INIT. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-04-10nand: Extend nand_(read|write)_skip_bad with *actual and limit parametersTom Rini
We make these two functions take a size_t pointer to how much space was used on NAND to read or write the buffer (when reads/writes happen) so that bad blocks can be accounted for. We also make them take an loff_t limit on how much data can be read or written. This means that we can now catch the case of when writing to a partition would exceed the partition size due to bad blocks. To do this we also need to make check_skip_len count not just complete blocks used but partial ones as well. All callers of nand_(read|write)_skip_bad are adjusted to call these with the most sensible limits available. The changes were started by Pantelis and finished by Tom. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-11-26nand: Add torture featureBenoît Thébaudeau
This patch adds a NAND Flash torture feature, which is useful as a block stress test to determine if a block is still good and reliable (or should be marked as bad), e.g. after a write error. This code is ported from mtd-utils' lib/libmtd.c. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-17nand: Make NAND lock status compatible with MicronJoe Hershberger
Micron NAND flash (e.g. MT29F4G08ABADAH4) BLOCK LOCK READ STATUS is not the same as others. Instead of bit 1 being lock, it is #lock_tight. To make the driver support either format, ignore bit 1 and use only bit 0 and bit 2. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-17nand: Change ulong to loff_t and size_tJoe Hershberger
Missed in previous cleanup. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-17nand: Add support for unlock.invertJoe Hershberger
NAND unlock command allows an invert bit to be set to unlock all but the selected page range. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> [scottwood@freescale.com: updated docs and added comment about invert bit] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-01at91: atmel_nand: extract HWECC initialization code into one function: ↵Wu, Josh
atmel_hw_nand_init_param(). This patch 1. extract the hwecc initialization code into one function. It is a preparation for adding atmel PMECC support. 2. enable CONFIG_SYS_NAND_SELF_INIT. Which make us can configurate the ecc parameters between nand_scan_ident() and nand_scan_tail(). Signed-off-by: Josh Wu <josh.wu@atmel.com> [fix empty newline at EOF error and move return value check into ifdef] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-04-30linux/compat.h: rename from linux/mtd/compat.hMike Frysinger
This lets us use it in more places than just mtd code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-01-26nand/fsl_elbc: Convert to self-initScott Wood
This driver doesn't yet make use of the added flexibility (not that that should stop anyone from converting...), but it will with the in-progress hack to support 4k-page NAND. Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-26nand: Introduce CONFIG_SYS_NAND_SELF_INITScott Wood
This allows a driver to run code between nand_scan_ident() and nand_scan_tail(), among other things. See the additions to doc/README.nand for details. To allow a gradual transition, Boards that don't set CONFIG_SYS_NAND_SELF_INIT will still be initialized the old way, but new drivers should not require this, and existing drivers should be converted when convenient. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06nand: Add common functions to linux/mtd/nand.hSimon Schwarz
Functions often used in SPL are now part of linux/mtd/nand.h. Static modifiers are removed from these functions in drivers/mtd/nand/nand_base.c. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Cc: scottwood@freescale.com Cc: s-paulraj@ti.com Cc: albert.u.boot@aribaud.net Acked-by: Scott Wood <scottwood@freescale.com>
2011-09-30spl: add NAND Library to new SPLSimon Schwarz
Adds NAND library to SPL. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30omap-common: add nand spl supportSimon Schwarz
Add NAND support for the new SPL structure. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-01nand_util: drop trailing all-0xff pages if requestedBen Gardiner
Add a flag to nand_read_skip_bad() such that if true, any trailing pages in an eraseblock whose contents are entirely 0xff will be dropped. The implementation is via a new drop_ffs() function which is based on the function of the same name from the ubiformat utility by Artem Bityutskiy. This is as-per the reccomendations of the UBI FAQ [1] [1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Artem Bityutskiy <dedekind1@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-07-01nand_util: treat WITH_YAFFS_OOB as a modeBen Gardiner
When specified in the flags argument of nand_write, WITH_YAFFS_OOB causes an operation which is mutually exclusive with the 'usual' way of writing. Add a check that client code does not specify WITH_YAFFS_OOB along with any other flags and add a comment indicating that the WITH_YAFFS_OOB flag should not be mixed with other flags. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-07-01nand_util: convert nand_write_skip_bad() to flagsBen Gardiner
In a future commit the behaviour of nand_write_skip_bad() will be further extended. Convert the only flag currently passed to the nand_write_ skip_bad() function to a bitfield of only one allocated member. This should avoid an explosion of int's at the end of the parameter list or the ambiguous calls like nand_write_skip_bad(info, offset, len, buf, 0, 1, 1); nand_write_skip_bad(info, offset, len, buf, 0, 1, 0); Instead there will be: nand_write_skip_bad(info, offset, len, buf, WITH_YAFFS_OOB | WITH_OTHER); Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-01-12NAND: add the ability to directly write yaffs imageLei Wen
This patch add addition suffix to nand write to give the uboot the power to directly burn the yaffs image to nand. Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-10-11nand erase: .spread, .part, .chip subcommandsScott Wood
A while back, in http://lists.denx.de/pipermail/u-boot/2009-June/054428.html, Michele De Candia posted a patch to not count bad blocks toward the requested size to be erased. This is desireable when you're passing in something like $filesize, but not when you're trying to erase a partition. Thus, a .spread subcommand (named for consistency with http://lists.denx.de/pipermail/u-boot/2010-August/075163.html) is introduced to make explicit the user's desire to erase for a given amount of data, rather than to erase a specific region of the chip. While passing $filesize to "nand erase" is useful, accidentally passing something like $fliesize currently produces quite unpleasant results, as the variable evaluates to nothing and U-Boot assumes that you want to erase the entire rest of the chip/partition. To improve the safety of the erase command, require the user to make explicit their intentions by using a .part or .chip subcommand. This is an incompatible user interface change, but keeping compatibility would eliminate the safety gain, and IMHO it's worth it. While touching nand_erase_opts(), make it accept 64-bit offsets and sizes, fix the percentage display when erase length is rounded up, eliminate an inconsistent warning about rounding up the erase length which only happened when the length was less than one block (rounding up for $filesize is normal operation), and add a diagnostic if there's an attempt to erase beginning at a non-block boundary. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-07-12NAND: environment offset in OOB (CONFIG_ENV_OFFSET_OOB)Ben Gardiner
This is a re-submission of the patch by Harald Welte <laforge@openmoko.org> with minor modifications for rebase and changes as suggested by Scott Wood <scottwood@freescale.com> [1] [2]. This patch enables the environment partition to have a run-time dynamic location (offset) in the NAND flash. The reason for this is simply that all NAND flashes have factory-default bad blocks, and a fixed compile time offset would mean that sometimes the environment partition would live inside factory bad blocks. Since the number of factory default blocks can be quite high (easily 1.3MBytes in current standard components), it is not economic to keep that many spare blocks inside the environment partition. With this patch and CONFIG_ENV_OFFSET_OOB enabled, the location of the environment partition is stored in the out-of-band (OOB) data of the first block in flash. Since the first block is where most systems boot from, the vendors guarantee that the first block is not a factory default block. This patch introduces the 'nand env.oob' command, which can be called from the u-boot command line. 'nand env.oob get' reads the address of the environment partition from the OOB data, 'nand env.oob set {offset,partition-name}' allows the setting of the marker by specifying a numeric offset or a partition name. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/43916 [2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/79195 Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Harald Welte <laforge@gnumonks.org>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07mtd: nand: use loff_t for offsetJean-Christophe PLAGNIOL-VILLARD
nand_util currently uses size_t which is arch dependent and not always a unsigned long. Now use loff_t, as does the linux mtd layer. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23NAND: move board_nand_init to nand.hMike Frysinger
Rather than putting the function prototype for board_nand_init() in the one place where it gets called, put it into nand.h so that every place that also defines it gets the prototype. Otherwise, errors can go silently unnoticed such as using the wrong return value (void rather than int) when defining the function. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12NAND boot: MPC8313ERDB supportScott Wood
Note that with older board revisions, NAND boot may only work after a power-on reset, and not after a warm reset. I don't have a newer board to test on; if you have a board with a 33MHz crystal, please let me know if it works after a warm reset. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12NAND read/write fixScott Wood
Implement block-skipping read/write, based on a patch from Morten Ebbell Hestens <morten.hestnes@tandberg.com>. Signed-off-by: Morten Ebbell Hestnes <morten.hestnes@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-09NAND: ifdef-protect most of nand.h when using legacy NAND.Scott Wood
Some macros such as NAND_CTL_SETALE conflict between current and legacy NAND, being defined by the subsystem in the former case and the board config file in the latter. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-04-28NAND: fix some strict-aliasing compiler warningsWolfgang Denk
2007-06-22[patch] add nand_init() prototype to nand.hMike Frysinger
since nand_init() is expected to be called by other parts of u-boot, there should be a prototype for it in nand.h Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-20Add board/cpu specific NAND chip select function to 440 NDFCStefan Roese
Based on idea and implementation from Jeff Mann Patch by Stefan Roese, 20 Oct 2006
2006-10-10* Several improvements to the new NAND subsystem:Stefan Roese
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2005-11-02* Add hook to NAND erase and implement nand_wait function.Wolfgang Denk
Patch by Mike Rapoport, 01 Nov 2005 Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
