path: root/include/mxs_nand.h
2020-05-10mtd: nand: raw: mxs_nand changes for nandbcbHan Xu
Add more BCH setting mode and remove the unnecessary platform constrain Signed-off-by: Han Xu <han.xu@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10mtd: mxs_nand: fix the gf_13/14 definition issueHan Xu
gf_13/14 mask was not set correctly in register definition. Signed-off-by: Han Xu <han.xu@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10mtd: gpmi: provide the option to use legacy bch geometryYe Li
Provide an option in DT to use legacy bch geometry, which compatible with the 3.10 kernel bch setting. To enable the feature, adding "fsl,legacy-bch-geometry" under gpmi-nand node. NOTICE: The feature must be enabled/disabled in both u-boot and kernel. Signed-off-by: Han Xu <han.xu@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10mtd: gpmi: change the BCH layout setting for large oob NANDYe Li
The code change updated the NAND driver BCH ECC layout algorithm to support large oob size NAND chips(oob > 1024 bytes) and proposed a new way to set ECC layout. Current implementation requires each chunk size larger than oob size so the bad block marker (BBM) can be guaranteed located in data chunk. The ECC layout always using the unbalanced layout(Ecc for both meta and Data0 chunk), but for the NAND chips with oob larger than 1k, the driver cannot support because BCH doesn’t support GF 15 for 2K chunk. The change keeps the data chunk no larger than 1k and adjust the ECC strength or ECC layout to locate the BBM in data chunk. General idea for large oob NAND chips is 1.Try all ECC strength from the minimum value required by NAND spec to the maximum one that works, any ECC makes the BBM locate in data chunk can be chosen. 2.If none of them works, using separate ECC for meta, which will add one extra ecc with the same ECC strength as other data chunks. This extra ECC can guarantee BBM located in data chunk, of course, we need to check if oob can afford it. Previous code has two methods for ECC layout setting, the legacy_calc_ecc_layout and calc_ecc_layout_by_info, the difference between these two methods is, legacy_calc_ecc_layout set the chunk size larger chan oob size and then set the maximum ECC strength that oob can afford. While the calc_ecc_layout_by_info set chunk size and ECC strength according to NAND spec. It has been proved that the first method cannot provide safe ECC strength for some modern NAND chips, so in current code, 1. Driver read NAND parameters first and then chose the proper ECC layout setting method. 2. If the oob is large or NAND required data chunk larger than oob size, chose calc_ecc_for_large_oob, otherwise use calc_ecc_layout_by_info 3. legacy_calc_ecc_layout only used for some NAND chips does not contains necessary information. So this is only a backup plan, it is NOT recommended to use these NAND chips. Signed-off-by: Han Xu <b45815@freescale.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-11-03nand: mxs_nand: add API for switching different BCH layoutsIgor Opaniuk
On i.MX7 in a sake of reducing the disturbances caused by a neighboring cells in the FCB page in the NAND chip, a randomizer is enabled when reading the FCB page by ROM bootloader. Add API for setting BCH to specific layout (and restoring it back) used by ROM bootloader to be able to burn it in a proper way to NAND using nandbcb command. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Anti Sullin <anti.sullin@artecdesign.ee> Tested-by: Max Krummenacher <max.krummenacher@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-19i.MX6: nand: add nandbcb command for imxShyam Saini
Writing/updating boot image in nand device is not straight forward in i.MX6 platform and it requires boot control block(BCB) to be configured. It becomes difficult to use uboot 'nand' command to write BCB since it requires platform specific attributes need to be taken care of. It is even difficult to use existing msx-nand.c driver by incorporating BCB attributes like mxs_dma_desc does because it requires change in mtd and nand command. So, cmd_nandbcb implemented in arch/arm/mach-imx BCB contains two data structures, Firmware Configuration Block(FCB) and Discovered Bad Block Table(DBBT). FCB has nand timings, DBBT search area, page address of firmware. On summary, nandbcb update will - erase the entire partition - create BCB by creating 2 FCB/DBBT block followed by 1 FW block based on partition size and erasesize. - fill FCB/DBBT structures - write FW/SPL on FW1 - write FCB/DBBT in first 2 blocks for nand boot, up on reset bootrom look for FCB structure in first block's if FCB found the nand timings are loaded for further reads. once FCB read done, DTTB will load and finally firmware will be loaded which is boot image. Refer section "NAND Boot" from doc/imx/common/imx6.txt for more usage information. Reviewed-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Signed-off-by: Shyam Saini <shyam.saini@amarulasolutions.com>
