path: root/include/mvebu_mmc.h
2015-01-06MVEBUMMC : Speed up access timeGerald Kerma
Get about 40x faster access on SHEEVAPLUG MMC Fix some SD type compatibility Changes in v3: - fix the HW_STATE (from linux mvsdio) - review delays and timeouts Changes in v2: - increase number of loops - remove initial delay Changes in v1: - review all loops, delays and timeouts Signed-off-by: GĂ©rald Kerma <drEagle@doukki.net> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-08-01ARM: kirkwood: add mvsdio driverDrEagle
This patch add Marvell kirkwood MVSDIO/MMC driver and enable it for Sheevaplugs and OpenRD boards. Signed-off-by: Gerald Kerma <drEagle@doukki.net> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
