path: root/include/mtd
2010-12-17cfi_flash: Add optional config register write to cfi-detectionStefan Roese
This patch adds the possibility to (optinally) write to the flash configuration register. The Intel style CFI chips support such a register that can be used to configure the operation mode to a non-default value. This method will be used by the t3corp board, which needs to configure the DS617 Xilinx flash for async read mode. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-10-28cfi: Add weak default function for flash_cmd_reset()Stefan Roese
Currently the CFI driver issues both AMD and Intel reset commands. This is because the driver doesn't know yet which chips are connected. This dual reset seems to cause problems with the M29W128G chips as reported by Richard Retanubun. This patch now introduces a weak default function for the CFI reset command, still with both resets. This can be overridden by a board specific version if necessary. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Richard Retanubun <RichardRetanubun@ruggedcom.com>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 7/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
