path: root/include/mtd/ubi-user.h
2019-10-16ubi: provide a way to skip CRC checksQuentin Schulz
Some users of static UBI volumes implement their own integrity check, thus making the volume CRC check done at open time useless. For instance, this is the case when one use the ubiblock + dm-verity + squashfs combination, where dm-verity already checks integrity of the block device but this time at the block granularity instead of verifying the whole volume. Skipping this test drastically improves the boot-time. Adapted to U-Boot by Stefan Roese. Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Quentin Schulz <quentin.schulz@bootlin.com> Cc: Boris Brezillon <boris.brezillon@bootlin.com>
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 7/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
