path: root/include/mtd/cfi_flash.h
2017-09-26mtd: cfi: Add support for status register pollingMarek Vasut
The status register is optional in the AMD command sets, but it's presence can be checked by reading out CFI table entry 0xc bit 0. If the register is present, prefer using it's bit 7 to determine if the flash is busy over reading the flash ; this is needed ie. on Hyperflash memories. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-08-22mtd: cfi: staticize functionsMarek Vasut
Staticize a few functions and variables which are no longer exposed. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2015-10-27cfi_flash: use specific width types for cwordRyan Harkin
This patch changes the cword union to use specific length types that are architecture indepented. This patch also renames the members of the cword union to represent their usage, i.e.: c -> w8 s -> w16 l -> w32 ll -> w64 Where "w" stands for "width" in bits. I discovered this problem when enabling CFI flash on vexpress64. cword.l was an unsigned long int, but it was intended to be 32 bits wide. Unfortunately, it's 64-bits wide on a 64-bit system, meaning that a 64-bit system fails when attempting to use 32-bit wide CFI flash parts. Similar problems also existed with the other cword sizes. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-30cfi_flash: Add prototypes of overridable functionsMasahiro Yamada
This commit adds some prototypes into include/mtd/cfi_flash.h. These functions are defined with a weak attribute in drivers/mtd/cfi_flash.c. This means they can be overrided by board-specific ones if necessary. When defining such functions under board/ directory or somewhere, cfi_flash.h should be included. This makes sure that board-specfic cfi functions are defined in a correct prototype. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Stefan Roese <sr@denx.de>
2013-05-23cfi_flash: Fix unaligned accesses to cfi_qry structureAndrew Gabbasov
Packed structure cfi_qry contains unaligned 16- and 32-bits members, accessing which causes problems when cfi_flash driver is compiled with -munaligned-access option: flash initialization hangs, probably due to data error. Since the structure is supposed to replicate the actual data layout in CFI Flash chips, the alignment issue can't be fixed in the structure. So, unaligned fields need using of explicit unaligned access macros. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Reviewed-By: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-12Revert "mtd: cfi_flash: Fix CFI flash driver for 8-bit bus support"Stefan Roese
This reverts commit 239cb9d904cfa8ab50d840a47b3306189d695c75. Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-02mtd: cfi_flash: Fix CFI flash driver for 8-bit bus supportaaron.williams@caviumnetworks.com
This commit is based on that patch from aaron.williams@caviumnetworks.com with same commit title. pulled the same code changes into current u-boot tree. http://patchwork.ozlabs.org/patch/140863/ http://lists.denx.de/pipermail/u-boot/2011-April/089606.html This patch corrects the addresses used when working with Spansion/AMD FLASH chips. Addressing for 8 and 16 bits is almost identical except in the 16-bit case the LSB of the address is always 0. The confusion arose because the addresses in the datasheet for 16-bit mode are word addresses but this code assumed it was byte addresses. I have only been able to test this on our Octeon boards which use either an 8-bit or 16-bit bus. I have not tested the case where there's an 8-bit part on a 16-bit bus. This patch also adds some delays as suggested by Spansion. If a part can be both 8 and 16-bits, it forces it to work in 8-bit mode if an 8-bit bus is detected. Apart from the pulled changes, fixed few minor code cleanups and tested on 256M29EW, 512M29EW flashes. Before this fix: --------------- Bank # 1: CFI conformant flash (8 x 8) Size: 64 MB in 512 Sectors AMD Standard command set, Manufacturer ID: 0xFF, Device ID: 0xFF Erase timeout: 4096 ms, write timeout: 2 ms Buffer write timeout: 5 ms, buffer size: 1024 bytes After this fix: -------------- Bank # 1: CFI conformant flash (8 x 8) Size: 64 MB in 512 Sectors AMD Standard command set, Manufacturer ID: 0x89, Device ID: 0x7E2301 Erase timeout: 4096 ms, write timeout: 2 ms Buffer write timeout: 5 ms, buffer size: 1024 bytes Signed-off-by: Aaron Williams <aaron.williams@caviumnetworks.com> Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Tested-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2012-08-13cfi_flash: add support for Spansion flash PPB sector protectionAnatolij Gustschin
Erasing flash sectors protected with persistent protection bit (PPB) mechanism on Spansion flash chips doesn't work. Add sector protection status checking and sector lock and unlock commands to fix this. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-17cfi_flash: Add optional config register write to cfi-detectionStefan Roese
This patch adds the possibility to (optinally) write to the flash configuration register. The Intel style CFI chips support such a register that can be used to configure the operation mode to a non-default value. This method will be used by the t3corp board, which needs to configure the DS617 Xilinx flash for async read mode. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-10-28cfi: Add weak default function for flash_cmd_reset()Stefan Roese
Currently the CFI driver issues both AMD and Intel reset commands. This is because the driver doesn't know yet which chips are connected. This dual reset seems to cause problems with the M29W128G chips as reported by Richard Retanubun. This patch now introduces a weak default function for the CFI reset command, still with both resets. This can be overridden by a board specific version if necessary. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Richard Retanubun <RichardRetanubun@ruggedcom.com>
