path: root/include/mtd.h
2018-10-02cmd: mtd: add 'mtd' commandMiquel Raynal
There should not be a 'nand' command, a 'sf' command and certainly not a new 'spi-nand' command. Write a 'mtd' command instead to manage all MTD devices/partitions at once. This should be the preferred way to access any MTD device. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2018-10-02mtd: uclass: add probe functionMiquel Raynal
The user might want to trigger the probe of any MTD device, export these functions so they can be called from a command source file. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2018-10-02dm: drop unused helper in MTD headerMiquel Raynal
include/mtd.h might be included by files even if CONFIG_DM is not enabled. In this case, the call to dev_get_uclass_priv() would trigger a build error. Because this helper has no user, let's drop it off. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2015-11-12dm: implement a MTD uclassThomas Chou
Implement a Memory Technology Device (MTD) uclass. It should include most flash drivers in the future. Though no uclass ops are defined yet, the MTD ops could be used. The NAND flash driver is based on MTD. The CFI flash and SPI flash support MTD, too. It should make sense to convert them to MTD uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
