path: root/include/msc01.h
2017-11-28Update Paul Burton's email addressPaul Burton
MIPS is no longer a part of Imagination Technologies, and as such my @imgtec.com email address will soon cease to function. This patch updates occurrances of it with my new @mips.com email address, and adds an entry in .mailmap such that git (& tools such as get_maintainer.pl when examining history) will use the new address. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de
2013-11-09malta: support for coreFPGA6 boardsPaul Burton
This patch adds support for running on Malta boards using coreFPGA6 core cards, including support for the msc01 system controller used with them. The system controller is detected at runtime allowing one U-boot binary to run on a Malta with either. Due to the PCI I/O base differing between Maltas using gt64120 & msc01 system controllers, the UART setup is modified slightly. A second UART is added so that there is one pointing at the correct address for each system controller. The Malta board then defines its own default_serial_console function to select the correct one at runtime. The incorrect UART will simply not function. Tested on: - A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both with and without an L2 cache. - QEMU. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
