path: root/include/mpc8xx.h
2018-04-06powerpc: mpc8xx: Change CONFIG_8xx to CONFIG_MPC8xxChristophe Leroy
CONFIG_8xx doesn't mean much outside of arch/powerpc/ This patch renames it CONFIG_MPC8xx just like CONFIG_MPC85xx etc ... It also renames 8xx_immap.h to immap_8xx.h to be consistent with other file names. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
Improve and fix various things in the MPC8xx FEC driver: 1. The new 87x and 88x series of processors have two FECs, and the new driver supports them both. 2. Another change in the 87x/88x series is support for the RMII (Reduced MII) interface. However numerous changes are needed to make it work since the PHYs are connected to the same lines. That means that you have to address them correctly over the MII interface.
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-10-19* Patch by Steven Scholz, 18 Oct 2003:wdenk
Fix AT91RM9200 ethernet driver * Patch by Nye Liu, 17 Oct 2003: Fix typo in include/mpc8xx.h * Patch by Richard Woodruff, 16 Oct 03: Fixes for cpu/arm925/interrupt.c - Initialize timestamp & lastdec vars. - fix timestamp overflows. - fix lastdec overflow. - smarter normalization to allow udelay() below 1ms to work. * Patch by Scott McNutt, 16 Oct add networking support for the Altera Nios Development Kit, Cyclone Edition (DK-1C20) * Patch by Jon Diekema, 14 Oct 2003: add hint about doc/README.silent to README file
2003-07-27* Patch by Scott McNutt, 21 Jul 2003:wdenk
Add support for LynuxWorks Kernel Downloadable Images (KDIs). Both LynxOS and BlueCat linux KDIs are supported. * Patch by Richard Woodruff, 25 Jul 2003: use more reliable reset for OMAP/925T * Patch by Nye Liu, 25 Jul 2003: fix typo in mpc8xx.h * Patch by Richard Woodruff, 24 Jul 2003: Fixes for cmd_nand.c: - Fixed null dereferece which could result in incorrect ECC values. - Added support for devices with no Ready/Busy signal hooked up. - Added OMAP1510 read/write protect handling. - Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock for non-JFFS2. - Switched default ECC to be JFFS2.
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-06-28Merge from "stable branch", tag LABEL_2003_06_28_1800-stable:wdenk
- Allow to call sysmon function interactively - PIC on LWMON board needs delay after power-on - Add missing RSR definitions for MPC8xx - Improve log buffer handling: guarantee clean reset after power-on - Add support for EXBITGEN board - Add support for SL8245 board
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonnière, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2002-09-17Initial revisionwdenk
