path: root/include/mpc86xx.h
2008-12-19mpc8[56]xx: Put localbus clock in sysinfo and gdTrent Piepho
Currently MPC85xx and MPC86xx boards just calculate the localbus frequency and print it out, but don't save it. This changes where its calculated and stored to be more consistent with the CPU, CCB, TB, and DDR frequencies and the MPC83xx localbus clock. The localbus frequency is added to sysinfo and calculated when sysinfo is set up, in cpu/mpc8[56]xx/speed.c, the same as the other frequencies are. get_clocks() copies the frequency into the global data, as the other frequencies are, into a new field that is only enabled for MPC85xx and MPC86xx. checkcpu() in cpu/mpc8[56]xx/cpu.c will print out the local bus frequency from sysinfo, like the other frequencies, instead of calculating it on the spot. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-06-1083xx/85xx/86xx: factor out Freescale Localbus defines out of mpc83xx.hAnton Vorontsov
This patch moves Freescale Localbus defines out of mpc83xx.h, so we could use it on MPC85xx and MPC86xx processors. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2007-05-01Conditionalize 8641 Rev1.0 MCM workaroundsJames Yang
Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-08-22Cleanup even more poorly introduced whitespace.Jon Loeliger
2006-04-27Cleanup whitespaces and style issues.Jon Loeliger
Removed //-style comments. Use 80-column lines. Remove trailing whitespace. Remove dead code and debug cruft.
2006-04-26Initial support for MPC8641 HPCN board.Jon Loeliger
