path: root/include/mpc85xx.h
2008-06-1083xx/85xx: further localbus cleanupsAnton Vorontsov
move the BRx_* and ORx_* left behind in mpc85xx.h The same is needed for mpc8xx.h and mpc8260.h (defines are almost the same, just few differences which needs some attention though). But the bad news for mpc8xx and mpc8260 is that there are a lot of users of these defines. So this cleanup I'll leave for the "better times". Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-1083xx/85xx/86xx: factor out Freescale Localbus defines out of mpc83xx.hAnton Vorontsov
This patch moves Freescale Localbus defines out of mpc83xx.h, so we could use it on MPC85xx and MPC86xx processors. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-1485xx start.S cleanup and exception supportAndy Fleming
From: Ed Swarthout <Ed.Swarthout@freescale.com> Support external interrupts from platform to eliminate system hangs. Define CONFIG_INTERRUPTS board configure option to enable. Enable ecm, ddr, lbc, and pci/pcie error interrupts in PIC. Remove extra cpu initialization redundant with hardware initialization. Whitespace cleanup. Define and use _START_OFFSET consistent with other processors using ppc_asm.tmpl Move additional code from .text to boot page to make room for exception vectors at start of image. Handle Machine Check, External and Critical exceptions. Fix e500 machine check error determination in traps.c TEXT_BASE can now be 0xfffc_0000 - which cuts binary image in half. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2006-03-12Add (some) definitions for the MPC85xx local bus controllerWolfgang Denk
Patch by Murray Jensen, 08 Jul 2005
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
