path: root/include/mpc5xxx.h
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2012-09-01mpc5xxx: add pci_mpc5xxx_init prototype to common headerAnatolij Gustschin
Add pci_mpc5xxx_init() prototype to the header file, so board .c files do not need to add extern pci_mpc5xxx_init() declaration. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-10-12A4M072: Added support for the board.Sergei Poselenov
This patch provides support for the A4M072 board with the following features: UART NOR flash FEC Ethernet External SRAM I2C EEPROM CompactFlash cards on IDE/ATA port USB Host PCI initialization The 7-segment LED indicator is not yet supported. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2010-01-18mpc5xxx.h: Add structure definition for XLB arbiter block.Detlev Zundel
2009-06-14mpc52xx: Add SPI driver.Grzegorz Bernacki
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2009-03-27mpc5xxx: Add structure definition for several more register blocks.Detlev Zundel
2009-03-23Add define for mpc5200 CDM_CLK_ENAJon Smirl
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
2008-08-21Adding bootlimit/bootcount feature for MPC5XXX on TQM5200 BoardsAxel Beierlein
Tested with TQM5200S on STK52XX.200 Board Signed-off-by: Axel Beierlein <belatronix@web.de>
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2006-11-01- Add MPC5XXX register definition MPC5XXX_WU_GPIO_DATA_I and change theBartlomiej Sieka
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with MPC5XXX_WU_GPIO_DATA_O for affected boards. - Add defintions for some MPC5XXX GPIO pins.
2006-09-01Added interrupt handling capabilities for mpc5xxx processors.Detlev Zundel
Also added Linux like BUG() macros.
2006-08-18Add support for WTK FO300 board (TQM5200 based).Marian Balakowicz
2006-03-29Set SDelay register in the DDR controller for the MPC5200B chip.Rafal Jaworowski
2005-08-19Add new board specific commands for TQM5200/STK52XXWolfgang Denk
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005
2005-03-14INKA4x0: Allow initialization of LCD backlight dimming fromwdenk
"brightness" environment variable.
2005-03-06Add port initialization for digital I/O on INKA4x0LABEL_2005_03_06_0225wdenk
2004-07-11Patch by Mark Jonas, 01 Jul 2004:wdenk
Added support for Total5100 and Total5200 (Rev.1 and Rev.2) MGT5100 and MPC5200 based Freescale platforms.
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2003-09-16* Modify XLB arbiter priorities on MPC5200 so all devices use samewdenk
priority; configure critical interrupts to be handled like external interrupts
2003-09-13* Patch by David Müller, 13 Sep 2003:LABEL_2003_09_13_2100wdenk
various changes to VCMA9 board specific files * Add I2C support for MGT5100 / MPC5200
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
2003-08-28* Fix ICU862 environment problemwdenk
* Fix RAM size detection for RMU board * Implement "reset" for MGT5100/MPC5200 systems
2003-08-05* Fix PCI support for MPC5200 / IceCube Boardwdenk
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
